Question about GE GTD120 System
What Is the code entry for a GE Gtd 120 remote control
3 Suggested Answers
SOURCE: I have a GE GTD 120, but I don't have the remote.
how do I get sound from speakers w/o a remote?
Posted on Nov 26, 2009
SOURCE: how too connect dvd (GE)GTD 120 player to older sanyo tv
how do you find the parental control code if it was forgotten?
Posted on Feb 26, 2010
I have a ge gtd 120 home theatre surround sound.for some reason, my volume is stuck on one level.. I haven't had a remote for it for a while, just used the knob to adjust the volume.someone plz help!
Unless the system has some kind of automatic volume control on it, that can only be adjusted by the remote. I think you might have a faulty volume/tone control circuit. These days many amps have a single IC that will control the volume. If that goes the volume can get stuck on one level. Since the control knob you are turning is simply sending a signal to that IC. So if the IC has died the signal is not being received.
If you want to repair it yourself just follow the wires back to the board from the volume control. You should see a large multi pin black box that if your lucky is marked on the board volume control.
Jun 10, 2016 | GE Audio Players & Recorders
TVRC4 - RS remote code for HD DVB - S2 1201
0028,0048,0027,0018. Check these codes. If you wish to get more codes to GE and some other popular brands of remote controls; check these two links.
Feb 23, 2013 | GE JASRM24912 Remote Control
I purchased a GE Universal remote and I do not know the code to set up for MV20FM4. Please help.
HelloHello
You haven't given the model number of GE remote you have purchased. Yet I hereby give you some universal remote codes for Toshiba TV/VCR combo. Try with these. If you fails to synchronise with; inform me the model number of your GE Universal remote:
Four digit codes for Toshiba TV/VCR combo are: 0260 0358
Three digit codes for Toshiba are: 013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK. Thanks for using Fixya.
Apr 07, 2011 | Toshiba MV20FM4 20 in. TV/VCR Combo
I have a GE universal r emote control. I need the codes to control a 2006 Toshiba TV.
Hello;
According to the site located at http://www.eliztech.com/remotes/ge-4digit-codes.php , GE Universal Remotes operate on 3 and 4-digit codes. Furthermore, the 3-digit codes are sub-categorized as "old" and "new". So depending on how you classify your tv and whether your remote uses 3 or 4-digit codes, the codes for a Toshiba TV are:
3-digit (old) 049, 071, 072, 089, 105, 109, 117, 118, 160, 162
3-digit (new) 012, 013, 049, 089, 095, 105, 109, 117, 118, 120, 141, 159, 170, 178, 181, 260, 358, 394, 902
4-digit 0159, 0178, 0109, 0120, 0181, 0105, 0049, 0095, 0170, 0260, 0358, 0394, 0924, 0012, 0095, 0117, 0141
Hope these are the right codes.
Mar 19, 2011 | GE RM24911 Remote Control
How too connect dvd (GE)GTD 120 player to older sanyo tv
Dec 25, 2008 | GE GTD120 System
I NEED CODES TO A GE RC24964-C REMOTE CONTROL
I lost entry code for remote I need a Code for Toshiba tv thanks
Sep 01, 2008 | Televison & Video
Surround sound problems.
Dolby 5.1 is not supported via either of the Aux inputs. Be sure to check your main menu/audio setup screen to ensure that "stereo" is not selected. If it is, DVD's will not downmix, giving you only 2.1 stereo.
Dec 07, 2006 | GE GTD120 System
GE GTD120 System Logo
51 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
