Question about Microsoft Computers & Internet
My iphone battery died so l got another battery but the problem is that when i try to charge it some strange blue light flashes and the normal red one when it charges so whats with the blue light and
My iphone battery died so i got another battery but when i try to charge it a strange blue light flashes so what is the blue light and and why wont it turn on after mostly i want to know how to turn it back on
tamilselvan
  • 45 Answers
SOURCE: My phone will not show it charging and will not turn on, red light flashing
dear
you have mentioned that ur phone is charging and not getting on. that means ON\OFF path is having problem .due to dry solder of ON\OFF switch its happening. please resolder it and then check it
Posted on Nov 07, 2007
SOURCE: My Iphone wont turn on
listen to solution number 4..I tried it and it worked. Hold the power and home button until the apple logo pops up and your golden
Posted on Dec 30, 2007
  • 5 Answers
hold power button and home key as soon as u see apple logo let go of power button but keep holding home key this will put iphone in recovery mode then sync n recover
Posted on Apr 12, 2008
SOURCE: Compaq evo n610c battery not charging
Dear All,
As per your asking that question the conclussion is there is an problem with battrey not on mother borad either problem is in Adpter connector please check out that adpter conncetor or else in the power connector in your computer iam telling you that there is an no problem in mother borad 100% suerly i tell you,
Regards
Vishwanath.K
Posted on Mar 11, 2009
vortash
  • 431 Answers
SOURCE: My battery wont charge.
Hi I am Vortah The red light is usually an indicator that the battery is charged however in this instance as you are saying it isn't the battery has possibly gone short and you will need to replace the batteries . They have a type of internal memory and only charge a certain amount of times before they no longer accept charge and merely overheat during charging .. But I have to say it may be possible the charger is faulty as if the internal rectifier that charges the battery has gone short that may also bring the red light on in some chargers .. so try the battery or as I would do take it along to your nearest dealers and get them to check it . it may save you money in the long run you could be buying a battery you still cant use when you actually need a charger .. Hope this helps regards Vortash
Posted on May 29, 2009
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Inspiron 600m laptop flashes the red light at the bottom of screen as if it needs charged, but it is 100% charged and is not hot or anything. It flashed red three times then green. I powed down unplugged...
when you use battery power, does the laptop work or does the battery die right away try letting the battery die itself, like use the laptop till it dies then charge it up again
Apr 05, 2010 | Dell Inspiron 600M Notebook
I Can`t switch my headset on, and it stops charging after 20 secs
Move the call control button up or down, the indicator light will flash blue if it's paired or blue and red. If it flashes blue and red you need to pair phone with the headset. the passkey is 0000.
Jun 17, 2009 | Plantronics Explorer 340 Wireless Headset
Plantronics voyager 500a
With these units, if the earpiece battery is allowed to run down, it will switch off. When the earpiece turns off the base station starts to search for it, which is indicated by the flashing red power light. Also the blue light on the top of the base will turn off. The first step, which you have already done, is to charge the earpiece. Next, hold down the little black button that is on top of the earpiece for about 5 seconds. You should get a slow flashing blue light on the mic boom. Wait for about 10-20 seconds and the base should automatically find the earpiece. The red power light on the base will be steady and the blue light on top of the base will come on.
Sep 12, 2008 | Plantronics Voyager 500A Deskphone Adapter...
Flashing red light
If the sequence is 4 red, green, 4 red, green and so on- that's a code that indicates your battery is failing and is only providing less than 25% of its normal charge capacity.
That would mean your battery is basically dying and will probably keep headed downhill in a hurry. You should probably go ahead and start looking at getting a replacement.
Dec 27, 2007 | Dell Inspiron E1505 Notebook
When i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
Jun 11, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
Computers & Internet Logo
14 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
