Question about KitchenAid 27 in. Built-in Microwave/Convection Oven
Kitchen aid error codes F5 E 1 in Kitchen Aid gas convection oven. What does that mean?
Kitchen aid gas convection self clean oven won't work. The readout states F 5 E 3. What does that mean?
Powerman
  • 68 Answers
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
  • 272 Answers
SOURCE: kitchen aid oven is'nt working and giving code
Here is a page with all of the error codes for your oven.
http://www.appliancetimers.com/index.php?page=failure_code_page&manufacturer=ka&type=r
Your code is 2 parts, F2 is oven temp is too high, and the E0 wants you to test the relay contact operation. In simpler language make sure the connections are tight.
Posted on May 09, 2009
tbirdfan1
  • 3051 Answers
SOURCE: my kitchen aid oven has error codes f3 e1 what do
Hello there:
F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor
Now if it is just a f-3 and nothing else3 f 3
Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse
Posted on Jan 22, 2010
  • 949 Answers
SOURCE: Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
Posted on May 10, 2010
SOURCE: we installed kitchen aid microwave convection oven
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Posted on Jul 03, 2010
My convection oven ring does not work
These tend to crack and "unzip" because they are such a tight circle... Kill the power, and meter the ring element for ohm's resistance. If the element tests ok, check the wires to the element for overheating, and if those look fine, remove the control board and look for burnt solder joints where the relays are mounted. Multimeter DM10T
Feb 22, 2015 | KitchenAid Kitchen Aid KEBS177SBL Single...
I need a user manual for a kitchen aid convection/ microwave oven combo ser # kems307dbs6
Hello & Welcome to FixYa
Please click on this link to download the manual for your Kitchen Aid. Please get back to me if you have any other questions.
Kevin
Dec 26, 2010 | KitchenAid Ovens
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Error code F2 E3 r:02 E:03
Kitchen Aid Error Code F2-E3
Called kitchen aid, they said you need a new control board part #9782455.
Mar 16, 2010 | KitchenAid KEBC107 Electric Single Oven
Will not come on after self cleaning
this is a common occurance with many self clean ranges, especially slide in and wall oven units. the kitchen aid ranges usually have a non reset hi-limit. meaning it opens one time and needs to be replaced, sadly.
to replace the thermostat can be tricky to do if you're not experienced, so if you have any reservations about taking you range apart, call a qualified tech in your area. if you decide to take a go at it, well first things first.
**FIRST unplug from the wall or shut off the breaker**
*the other issue is not knowing what model you have.
I can tell you most recent kitchen aid units made by whirlpool have a fixed hi-limit at the back outer oven wall. remove the rear panel, and the hi-limit should be easily accessed. that part # 8300802
hope that helps,
good luck
Sep 28, 2009 | KitchenAid Ovens
Kitchen Aid Double Convection Oven blows circuit breaker
the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
Feb 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Self Clean does not work
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
KitchenAid 27 in. Built-in Microwave/Convection Oven Logo
24 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
