Question about Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure Washer 020489
How to fix recoil starter?
Starter rope will not recoil.
  • 37 Answers
It appears that the recoil spring is broken or has come away from its anchor position. It means opening the unit (usually 4 screws) and re-seating the recoil spring and rewinding the recoil spring so that it will recoil the starter rope with the correct tension. It may take a few attempts to get it right. If you do get it right, don't over-extend the starter rope when starting the washer. Someone was over-zealous!
Posted on May 11, 2014
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
Pulled starter rope, it's now stuck and won't recoil
Cool!
A Project.
Remove the spark plug lead just so you can't have it accidently fire.
Remove engine cowlings as necessary to get at recoil starter.
Remove recoil starter (that's the bit that the pull rope is attached to.
Dis-mantle it until you can find what is wrong. Fix or replace.
Put it all back together.
or
Take it to a small engine repair shop and pay a bunch.
Mar 06, 2016 | Bolens 31cc 2-Cycle Gas Cultivator BL410
Rewind starter cord
How To: Rewind a Recoil Rope (Fix a Broken ... - YouTube
? 2:52
https://www.youtube.com/watch?v=J0KJuqsJJ_k
Feb 16, 2012 - Uploaded by Champion Power Equipment
How To: Rewind a Recoil Rope (Fix a Broken Recoil Rope) .... Back off until rope hole in pulley lines up ...
How to Repair a Small Engine Recoil Starter - YouTube
? 4:49
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jul 15, 2011 - Uploaded by eReplacementParts.com
How to Repair a Small Engine Recoil Starter ... Would like to now use the pull cord on the mower but it won ...
Nov 28, 2015 | Garden
HOW TO FIX BROKEN STARTER PULL ROPE ON TB65SS WEED EATER?
You need to remove/disassemble the recoil starter assembly to replace the rope. Be carefull the spring does not get away from you if you do take iot apart.
Sep 21, 2014 | Garden
I have a 3hp briggs & stratton//the pull rope pulls freely//it does not engage the engine and turn the engine over
You probably need to replace the starter recoil. This is not a very expensive fix. Just be aware that this problem is usually caused by having to pull the starter rope excessively because of some other starting problem. Once you replace the recoil, keep your engine running properly.
Sep 07, 2014 | Garden
Husky power washer 2600 Tried fixing starter
I'll send you a link to a great video of how to recoil a starter spring, so you wont lose and fingers or eyes. :)
Aug 01, 2013 | Garden
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    How do I fix/replace the starter rope on a TB20CS (Tuffy Troy Bilt String Trimmer) that's broken? Do I need any special tools?
    Probably no special tools needed. Take the starter assy off. Turn the recoil in the direction it will turn if you are pulling the rope. When it gets tight, hold it there and install the new rope. When it is installed, let go of the recoil and it will draw the rope in.
    http://www.mylawnmowerforum.com/forum/
    Aug 09, 2010 | Troy Garden
    Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure Washer 020489 Logo
    207 people viewed this question
    Top Troy-Bilt XP Garden Experts
    CrisO
    Ron Durham
    Bill Boyd
    Are you a Troy-Bilt XP Garden Expert? Answer questions, earn points and help others
