Question about Vehicle Parts & Accessories
Toyota starlet if i access my ignition barrel is there a code on it too get a key cut from scratc?
  • 3,204 Answers
No only the key can be cut barrel and key are made at the same time to match no code on barrel just 2 digit number to match key number and code. if key lost you can get a new key on the pass code you get with the car 4 digit number that controls the cars ecu etc. but it depends on the age over 10years it gets harder to get the numberd parts.
Posted on Sep 12, 2014
Is there keys already cut that starts a 1998 honda accord v6 for sale or do i need to buy a new ignition switch. Lost mine
talk with a locksmith as there is a key code on the barrel of the switch and he should be able to cut a key to that code
if no code he will be able to remove the barrel and cut new keys from the tumbler positions
the only thing is that although he can cut keys , if it needs keys that work an immobilizer they can be expensive
if you are buying this car , then the seller should have the keys
Oct 31, 2015 | Honda Cars & Trucks
I have a broken key for my 98 Toyota Camry can't find the other half how do I get the ignition cylinder out when I can't put it in ACC
Contact Toyota and either give them the vehicle vin number or the serial number from the ignition barrel and they might be able to cut a new key from that......failing that drill the barrel out!
Oct 14, 2015 | Toyota Cars & Trucks
What type and size is the screw that holds the (white plastic) ignition module onto the end of the ignition cylinder in a 1991 toyota corolla?
6mm 8mm or 10mm depending on engine put a sharpen pencil in hole turn it will cut threads on pencil this will help to get right screw
Sep 19, 2017 | Toyota Cars & Trucks
1990 Camry ignition will not go under "acc" position.
In a Camry this age it is most likely that the key and lock both are worn. Toyota ignition key barrels are known to wear. Both old Toyotas I have had did this.
Go to an auto locksmith and explain that you want a key cut with a little extra metal on the profile, due to wear, and see if that works.
If not you need a new ignition key barrel (just the centre, not the electrical bits). It can be made to fit the old key, however you might decide not to bother doing that as it isn't much trouble to have 2 keys for the car.
Mar 04, 2013 | 1990 Toyota Camry
Toyota starlet key won't turn in ignition
It could be the key is worn out. A locksmith or dealership can cut a new key from the key code that came with the car when it was new. If you are a second (third, fourth...) owner. You may need a new lock cylinder - with new key.
Dec 22, 2012 | Ignition System for Toyota Starlet
1994 Toyota Corolla can't get key in ignition
with the age of the car its probably a worn barrel try getting a new key cut if not its a new barrel
Aug 14, 2012 | 1994 Toyota Corolla
I have an Isuzu Rodeo and the key is stuck in the ignition any idea how to get it out? Year 2000
replace the whole ignition barrel with new key and get key programmed by dealer
can remove barrel and key by removing steering column covers turn ignition to on position and with small shank screw driver push in hole in outer top rear section of barrel assembly then pull out ignition lock barrel with key in it. fit new lock barrel and key, program new key into system and can get door lock barrels coded to suit new key or get code for old key and cut new key so it fits mechanical locks on the rest of the vehicle (just wont turn in ignition) 2 keys for vehicle.
Jun 13, 2010 | 2000 Isuzu Rodeo
The key will not turn in the ignition
ignition barrel worn or dirt, need a new barrell, try another key or get 1 cut to try and turn, a cut key wont start it, u have to hold the original key very close to barrel to get the code
Aug 15, 2009 | 2006 Chevrolet Equinox
I lost my keys for my 2003 rodeo
you will have to get a dealer to cut new keys to code that dealers have access to and then get them to program to car but also erase old keys so vehicle wont start with old keys
or next more expensive option is new keys, ignition barrel and door barrels replaced which are differently same coded key and locks as well as programming and erasing old keys.
Jun 27, 2009 | 2003 Isuzu Rodeo
Need to change ignition lock cylinders
Fig. 7 Steering column & ignition switch assembly. Exc. 1984 Corolla 41767877
  1. Disconnect battery ground cable.
  2. Remove steering wheel, if necessary, steering column garnish, if equipped, upper and lower covers, Fig. 7. On Starlet models, remove upper cover.
  3. Disconnect electrical connectors from ignition switch.
  4. Turn ignition key to ACC position and remove ignition key cylinder.
  5. Remove screw and ignition switch.
  6. Reverse procedure to install.
Mar 23, 2009 | 1986 Toyota Pickup 4WD
Vehicle Parts & Accessories Logo
60 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
