Question about Fisher and Paykel Aquasmart wl80t65c
Why is water left in bowl machine not emptying at when it gets to the spin cycle
  • 1462 Answers
SOURCE: Fisher and Paykel (Old model) Fresh 5.0
you probably have a foreign object in the pump impellor - the favourite is bits of bra wire
Posted on May 06, 2007
juliankov
  • 13 Answers
SOURCE: F & P GW712 - bowl spins, but won't fill.
Read your user manual - but I would suggest that you may not have setup the balance properly. Check the level of the machine and adjust to be as square as possible by adjusting the feet at the bottom. If the water isnt coming in on both hot and cold sounds like a common problem - perhaps the water level sensor is playing up or something else has been knocked during transportation of the machine when you moved house. Check your user manual for troubleshooting. Sounds dumb, but check that 'delay start' isnt selected also. check both hoses filters are not blocked.
Posted on May 04, 2008
  • 82 Answers
SOURCE: Fault 37 but pump is clear and does work part of cycle
there is a blocked pressure chamber or switch remove and clean then try again / it is letting to much water in
Posted on Jul 31, 2009
GodBlessU
  • 3513 Answers
SOURCE: water leaks during final spin cycle only
The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with metal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement.
Thank you for contacting Fixya.com
Posted on Aug 10, 2009
  • 244 Answers
SOURCE: hi my smartdrive machine keeps going off balance
sure- hopefully you have a bit of room to move your appliance a bit. lay down on the floor, if able. use a flashlight. you should see 4 nylon or metal feet that the washer sits on. they'll have threaded bolts that lead into the bottom 4 corners of the washer. don't know how old your machine is, but if things look rusty, a little wd40 sprayed on them will help!
have someone help you lift the end of the washer opposite the way the axis of the drum is tilted. jiggle the drum a little and observe whether it becomes more centered. if you can, stick a piece of 2x4 , or 2x2 under that edge and turn the pads in a 'lefty-loosey' direction. this will raise one edge. take out the wood or spacer, and check the centering. you may need to mess with all 4 'feet', to get it right.
make sure your floor/platform the washer is on is solid!! if it's rotting out, check that your water connections are not leaking, and your drain hose is properly seated! good luck.
Posted on Sep 07, 2009
Not going through cycles
its prob the water heating system isnt detected so the machine stops and empties...
Mar 04, 2015 | Washing Machines
Spin cycle isnt not working
The spin cycle is reliant on the drain pump removing water from the tub.
It is a common ocurrance of objects (ie hair pins, pegs, coins etc) to be mistakenly washed through the cycle. Washing machines will often flush these objects down through the drain pump, and get caught in the little propeller of the pump.
So, it is imperative that you inspect the drain pump first and remove any obstruction within the drain pump cavity.
Turn machine power OFF at the wall and remove the power plug.
i) place an empty bucket on the floor
ii) lower the drain HOSE into the bucket - gravity will cause the water to drain into the bucket. Empty the bucket. Perform this procedure until all water has been emptied from the bowl.
iii) move the washing machine out from the wall, to gain access to the drain pump (usually a large screwcap). Place a large towel on the floor, under the screwcap - this will catch any remaining water that escapes.
iv) unscrew the drain pump cap and withdraw the cap. This cap may also contain a filter, so remove any lint/objects from this filter.
v) with the pump cap/filter removed, look inside the pump cavity and remove any visible obstruction from the impellar (little propeller thing). Then, with your finger, turn the little impellar in both directions - if you feel a 'rubber band' like resistance, then the drain pump may be ok at this point.
vi) remove all wet clothes from the machine bowl.
vii) re-assemble the drain pump cap/filter and secure it in place. Install drain hose back into your laundry tub. Plug machine back into power.
viii) fill the bucket with water and pour water back into your machine's bowl. Repeat with a 2nd bucket of water.
ix) manually select and operate SPIN cycle on the machine. Observe if drain pump functions correctly and empties water from the bowl. If yes, then you have resolved the problem.
If your pump has been cleared of all obtstructions but your machine will still not empty water from the bowl, then a full diagnostic will need to be carried out by an authorised service agent to determine which component has failed.
Let me know how you get on.....
Good Luck..
Oct 31, 2011 | GE Washing Machines
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
Wont adavace after wash cycle like its stuck replying back
Hi just read your posting. The problem appears to be your drain pump is either blocked or faulty.If you would like I can guide you throe the removal of the pump. The reason it does not reach full spin speed is there is still water under the bowl slowing it down.It is impossible to drain the machine by hand completely.Please reply If you require extra help on the pump removal.
Jun 07, 2010 | Fisher Paykel EcoSmart GWL15
I have a Samsung SW62ASP top load washing machine. I keep getting chunks of black flaky stuff turning up through my wash. I always empty the in bowl filter, is there another filter?
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution
Aug 05, 2009 | Samsung SW62ASP Top Load Washer
I have the same problem , the water filled then stopped working ,
sounds like your timer burnt out or is sticking somtimes giving the top of the controll box a firm smack will get it freed up
Jun 28, 2009 | Maytag Performa PAV2200
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Washing Machine won't go through spin cycle
To get the water out, lay the emptying hose down at floor level into a bowl, tip the water down the sink a bit at a time, then check for a blockage in the outlet filter, or the pump
Oct 24, 2007 | Washing Machines
Fisher and Paykel Aquasmart wl80t65c Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
