Question about Samsung Refrigerators
Deoderizer light is on what does this mean - Samsung Refrigerators
Where can I find jovan musk deodorant for men
Without knowing the zip/city/state/country/reigon/hemisphere you reside in, I'd have to say Amazon.com
Apr 04, 2012 | Jovan Coty Jovan Ginseng Nrg Cologne Spray...
I have used this deodrant over several years and now seem to have difficulty finding it in the stores here. I really like this product and thought you could give me the locations that I can purchase it....
Hello, Jane -
I hope I am correct in assuming you are asking about a particular type of Almay deoderant. It seems Almay makes several different kinds.
I suggest you contact Almay directly and ask if they still make the particular version of deoderant you like and if they do, where you can purchase it in your area. See this web page:
http://www.almay.com/contact-us.aspx
Jan 09, 2018 | Almay Health & Beauty
My AC smell bad how do i fix it
you can buy an aerosol specifically made to deoderize/kill nasties,from most good motor stores....and its easy just to press a button .....even i can do it....(with practice.)
Sep 07, 2010 | 1997 Dodge Dakota
Meat spoiled over three week period in standup deepfreeze. Odour Contaminated freezer and general area with meat and fruit spoilage. Have cleaned everything with bleaches disinfectants and commercial...
use a strong solution of clorine bleach(in a spray bottle) to get into every nook and cranny/drainholes/drip trays/door seals and wipe dry(clorine is a gas and will dissipate within an hour or so)then wipe over interior with a damp cloth and plenty of bicarb,leave to dry and leave any bicarb residual inside fridge as this will absorb any smells left.leave door open for about a day in a warm (ish) room, this is the only way of deoderising......
Aug 20, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
There is a dead mouse in the air ducts and smells like hell, How do I get it out?
you have to remove the heater unit try to get the hose of your dustmachine as far as posible in the hole you may try this at both ends to get the rotting air out your car buy some car deoderant or a toilet deoderant block under the heater unit if there is a space for it you may have to fix it to hold it on its place just before the main hole i hope this something to try out.
Jul 30, 2009 | 2008 Kia Spectra5
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Audi a6 wont start
HI,COULD BE ONE OF FOUR THINGS,1-PUMPS DO BURN OUT TRY A 12V DIRECT FEED TO TEST 2-FUSE? 3-FUEL PUMP CUT OFF SWITCH ,IF FITTED NEEDS RESETTING .4-FUEL PUMP RELAY GONE (COMMOM) THANKS.
Jan 02, 2009 | 1999 Audi A6
I need a circuit board for my dependable 92 propane furnace model#GMPN120-5 How much?
Have you checked the fuse on the circuit board first, and then the transformer before shelling out big money? JUST like the underarm deoderant, "BE SURE""!
Sep 13, 2008 | Comfort-Aire Heating & Cooling
Smelly air
What do you do ,when your under arms smells, you wash it and add deoderant! thnk-you very-much!
Aug 19, 2008 | Whirlwind FH-778 Air Conditioner
Refrigerators Logo
81 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
