Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool Cabrio W10106470 has an F51 code. What
Whirlpool Cabrio W10106470 has an F51 code. What is that?
  • 39 Answers
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Posted on Jun 23, 2009
As with most things electronic, when you unplug them for 15-30 seconds, they reset themselves to factory defaults. We did this with our Cabrio washer when it displayed code F 51, because the code F 51 indicates a loss of communication between the control panel and the motor position.
This does not necessarily mean one part or the other is bad; it could be as simple as a loss of communication betweeeen the two parts. Unplugging the unit required the electronics to go searching for each other an re-establish communication. Problem solved!
Had the code reappeared after unplugging to reset the communication between the sensor and the control panel, the next step would be to get into the machine to wiggle and reseat the connectors which could have vibrated loose. I would also use a spray electronics cleaner to clean the fragile and inaccessible contacts.
If the code persisted after that replacing the motor sensor or control panel (or both) is the only option.
Posted on Aug 02, 2009
What does an error code F51 on a whirlpool cabrio washer mean?
Cabrio F51 Fault (Stored Fault Code F51) The Cabrio's F51 fault code flashes on the washing machine's display when there is a motor rotor position sensor (RPS) failure.
Check for good contact at the control Board and at the RPS. Sometimes disconnecting and reconnecting the RPS plug connection several times will clean off corrosion that may be affecting the contacts.
Here is an earlier Fixya answer addressing the query:
Whirlpool cabrio error code f51 what does it mean
Sensor is item 20 below. Clean it.
Nov 27, 2017 | Whirlpool Washing Machines
My whirlpool cabrio washer will start to spin and then stop and show code f51 or f53
check is link for a repair manual and insight:
http://www.repairclinic.com/shop-for-parts/a11b121-x776869726c706f6f6c2063616272696f/whirlpool-cabrio-kitchenaid-washing-machine-parts
Jan 21, 2015 | Whirlpool Washing Machines
F51 code
THE LAST TIME I HAD THAT HAPPEN TO ME I FOUND SOMETHING STUCK IN THE OUTER TUB...
Jul 26, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio is displaying F51 what is this
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. If you google whirlpool cabrio error code F51, you'll get an idea of what you are up against. This is obviously a manufacturer's defect. They should take care of this problem whether you are in warranty or not. If you are insistent, maybe they will. Contact whirlpool directly if you're not satisfied by your local service people. This is not a DIY job.
Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washing machine - F51 code
F51 - This is a motor Rotation Positioning Sensor failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Sep 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code on cabrio washer
Call Whirlpool at 800-253-1301 in USA. There is a recall on this washer for the F1 code. Service call and parts are free. I just did it today.
Jan 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,707 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
