Question about Toshiba Satellite A45-S151 Notebook
Toshiba satellite a45-s151 bios reset
Pls help me to reset the bios pawword
    Top Expert:
  • Toshiba Master
  • 1,144 Answers
The Machine
  • 788 Answers
SOURCE: keyboard key not working
If it is just one letter then you most likely have a bad keyboard.
Try an external keyboard, if the 'c' is still not working with the external then it's probably some weird software issue. But, if the 'c' is ok on the external you will probably have to replace the keyboard. Replacement keyboard are pretty easy to find on ebay or the web and are usually very easy to replace.
Posted on Jan 14, 2008
MikeyMooo
  • 34 Answers
SOURCE: BIOS Access
try pressing the delete button when the bios shows on screen. if that is not the button, try pressing F2. If you are not seeing the post screen (the one that tells you what button to press) press the TAB key when you turn it on and a picture comes up telling you "toshiba something something"
Posted on Aug 19, 2009
Testimonial: "Knows the Toshiba A45-S151 well."
parrotheadpc
  • 2600 Answers
SOURCE: cmos battery location
Below is the link just copy and paste in the browsers address bar. Scroll down to chapter 4.15 which is the RTC Battery. Good luck, ParrotHead PC Repair
http://tim.id.au/laptops/toshiba/satellite%20a40.pdf
Posted on Sep 05, 2009
  • 3 Answers
SOURCE: cant find where the cmos battery goes in my
On a Toshiba Satellite A45-S151, the CMOS battery (also called the “real time clock” or RTC battery) is located under the wrist rest to the right of the trackpad. This means that you’ve got some major surgery ahead of you in order to replace this battery.
Disclaimer: I’m a hobbyist, not a Toshiba-certified service tech, so the procedure I’m about to detail is based on the Toshiba maintenance manual for A40 Series laptops—there may be a shortcut method to accomplishing all this (though I’ve not found one).
Before you start, download a copy of the Toshiba maintenance manual for A40 Series laptops (http://tim.id.au/laptops/toshiba/satellite%20a40.pdf)—thanks for that link, parrotheadpc!
You might as well also order your replacement battery (Real Time Clock (RTC) Battery, Nickel Metal Hydride, DC3.0V 17mAh, Toshiba #P71035017110). The best deal I could find online in Oct 09 was at www.sparepartswarehouse.com for $25 (including shipping; FYI, they automatically ship 2-day air). I called every computer repair store (and Radio Shack) in our area, but couldn’t find anyone who carried this battery in stock.
Tools & supplies you’ll need:
  • Precision screwdriver set—at a minimum, you’ll need a #0 Phillips head driver. Don’t try to use a #1 or larger screwdriver—you’ll only end up stripping a screw head (or two or three or ten) or at some point. If you don’t already have a set (they’re really useful for working on laptops), Sears has them for less than $15 (<$10 on sale). If you have a Harbor Freight Tools store in your area, you can also find a cheap set there.
  • Pair of small needle-nose pliers (the precision screwdriver set at Sears includes one); I really don’t think that you’ll be happy with standard-size needle-nose pliers.
  • A “micro” screw extractor (needed if you find that any screws are stripped; this could happen during original assembly or prior service work). I have the Craftsman screw extractor set (model 52157), available from Sears; the “M3” size extractor is just right for removing small case screws. This set’s not cheap (unless you get it on sale), so you may want to look for a less expense set that has the M3 size in it.
  • Power drill w/ adjustable chuck (for using the screw extractor). I used a full-sized cordless VSR drill, but if you have a VSR rotary tool with a chuck, that would be a lot easier to handle.
  • Flashlight or good work light.
  • Roll of Scotch “magic” tape (you’ll see why in a moment).
A word on “screw management”: You’re going to be removing a whole boatload of screws to separate the top half of the laptop shell from the bottom half—keeping track of the many screws (in different sizes) is a real pain. My way of handling this is to take a small piece of Scotch tape, fold over one end about 1/8” to make a tab (for later easy removal), and to use it to secure each screw in place as I remove it (with some exceptions, which I’ll mention as we go). For case screws that are inset in wells, a piece of tape over the top of the screw well will keep it in place. For exposed screws, you can usually loosely tape a screw in place after it’s been screwed out—just don’t push it back into the hole’s threads, as that will defeat the purpose of removing the screw. As you go through the procedure, if you find that the parts you’re trying to separate seem stuck together, you may have a screw that dropped back into place—just look for the likely screw, pull up the tape, screw it back out again, then put the tape back in place.
About stripped screw heads: You can hope that you won’t encounter any of these, but with over two dozen screws to remove, your chances are at least fair of having at least one stripped screw head—I recommend being prepared.
About cleaning out your laptop: While you've got it opened up, this is a good time to give it a blow-out with a can of compressed air--you may be surprised where you'll find clumps of dust hiding!
Here’s the procedure (citing the relevant pages of the Toshiba maintenance manual):
  1. Remove the main battery pack (p. 4-8).
  2. Remove the hard drive (p. 4-13). The covers is secured with both screws and plastic "snaps," so you'll need to use something with a thin blade to gently (!) pry it loose with after you remove the screws; I used one of the flathead screwdrivers from my precision screwdriver set.
  3. Remove the heat sink and CPU covers (p. 4-16)—just the covers, not the heat sink or CPU themselves. These covers are also secured with both screws and plastic "snaps."
    Note: While you’re here, this would be a good time to take some compressed air and blow the dust out of the heat sink fins and CPU fan (remember to not overspeed the fan).
  4. Remove the optical drive (p. 4-20). I’m not sure that this step is really necessary, as I can’t see how the optical drive would affect the shell disassembly, but it’s easy to do—if nothing else it removes a lot of weight, and will make the laptop easier to handle later. Since the case holes have no threads, I just threaded these screws into the holes in the optical drive itself in order to keep track of them.
    Note: Before reassembly, I gave the full system a thorough blow-out with compressed air; a lot of dust came out through the open optical drive bay, so that may be reason enough to remove it now.
  5. Remove the keyboard (p. 4-23). Do also remove the “keyboard hold plate” and “keyboard support plate” and set them aside; note how they are oriented, so that you can put them back in place correctly later. Be gentle when pulling out the keyboard cable from the mainboard connector—I used a side-to-side shimmy motion to ease it out.
  6. Remove the wireless LAN board cover and carefully disconnect the wireless LAN antenna leads (p. 4-28). I used the needle-nose pliers to disconnect the antenna leads from their mounting posts on the wireless LAN board—just pull straight up (gently!). Note that the black antenna lead connects to the post nearest the screen hinge, while the white lead connects to the post nearest the wrist rest. You do not need to remove the wireless LAN board itself, so just skip those steps.
  7. Remove the CD/DVD (audio) play button circuit board (p. 4-33). Disconnecting the thin ribbon cable connector looks scary, but it slips right out with a gentle tug.
  8. Remove the display assembly (p. 4-34). This is where you’ll go bugnuts keeping track of the screws if you’re not using my Scotch tape method! Note that by “display assembly,” we’re talking about the LCD screen assembly and the upper half of the laptop shell.
    Note 1: In addition to the two screws show in figure 4-20 on p. 4-35, there are two other screws that need to be removed that I can't find mentioned anywhere in the manual. These screws are located next to the memory module bay (one "above" and one in the "top right" corner; "up" means toward the screen hinge); both have "B4" marked in plastic next to their holes.
    Note 2: Disconnecting all the (tiny!) cable connectors in step #7 goes easiest with the small needle-nose pliers, grasping the plastic head of each connector and pulling straight back (I suspect that standard size needle-nose pliers will prove to have tips too thick for this delicate work). Whatever you do, resist the temptation to just tug on the wires to disconnect the cables!
    Note 3: The display assembly has plastic "snaps" in addition to screws, so you may need to do a little gentle levering to remove it.
  9. Remove and replace the RTC battery (p. 4-43). You’ll need to be careful to maneuver the “insulator” tab around the ribbon cable for the LED board, but it’s manageable without removing the LED board.
  10. Reassemble the laptop in the reverse order of disassembly (hope you know where all the screws are!).
    Note on reversing step #7 (CD/DVD play button circuit board): The connector socket for the ribbon cable is on the bottom of the board, inset from the edge. Consequently, I found that it was easier to reinsert the ribbon cable into the connector socket before putting the circuit board back into place. Also, because this ribbon cable doesn't have a hard plastic plug on the end, I had to gently (!) grip the ribbon cable with needle-nose pliers in order to reinsert it into the connector socket (which is just a thin slot, and somewhat hard to see while positioning the circuit board). Be careful to not put too much pressure on the ribbon cable--it's relatively fragile due to its thinness.
    Note on reversing step #6 (wireless LAN antenna): The antenna leads are on the small side; while easy to position over their sockets on the LAN board, pushing them onto the sockets would be difficult to do with a finger tip. My solution was to take my needle-nose pliers, close them, then use the closed tip of the pliers to apply moderate pressure to the cable connectors until I felt them snap into place. Note that I did not grip the cable connectors with the pliers--I only used the closed tip of the pliers to apply the necessary pressure.
You should now be able to boot up the laptop (after setting the clock, of course)—unless, like the one I’m working on, there are other problems to fix…
Posted on Nov 06, 2009
I have a acer aspire 7741Z-4643 how can I reset computer to get by the password. After trying 3 times it gives me a code 11263
If you have hiran boot cd pls run it with mini xp. can't load pls use another pc or laptop. after load pls run mini tools icon and pls select password menu in programmes menu. select bios password sub menu
and run the reset tool
type the code given the bios and use the password to unlock bios password
pls visit https://bios-pw.org/
type the code
Also pls read this link http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
Apr 13, 2017 | Acer Computers & Internet
Toshiba Satellite A45-S151 Cooling Fan Needed
hello,
1. Yes there is one or maybe two fans inside. most likely 1
2. for these instructions you would need a detailed service manual possibly from toshiba.
3. www.google.com
or a local computer repair shop for example.
Jul 12, 2008 | Toshiba Satellite A45-S151 Notebook
Toshiba satelite a45-s151 bios password removal
PC BIOS toolkit is a password removal/decrypt and BIOS settings modification/backup/restore.
http://www.syschat.com/download120.html&act=down
CMOSPwd - CMOS password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
Using a computer with Internet access, download the files from these WEB sites and create a bootable CD disc to run them.
Apr 13, 2013 | Toshiba Satellite A45-S151 Notebook
The original hard drives for the satellite a45-s151 is a 2.5 or 3.5
Original hard drive for the Toshiba Satellite A45-S151
60GB hard disk drive, enhanced IDE (ATA-5) interface, 4200rpm drive rotation, 9.5mm height, 0.2lbs, service removable.
Nov 17, 2011 | Toshiba Satellite A45-S151 Notebook
Hi hello pls help me to restore cmos bios setting to my laptop model asus m3000n...pls help? & my hitachi harddisk to enabled the password...pls again help me?
Your hard disk did not set your BIOS password. BIOS passwords are of little or no value to the average person and there is no reason to set one for a private owned computer. If you did set your password and then forgot it and now need into your setup - open the case, find the battery and remove it. Wait 5 minutes and reinstall it. Turn on your computer and the BIOS will reset itself to the original default settings. You will have to set the time.
Mar 24, 2010 | ASUS M3000N Notebook
Cant find ram chips in a Toshiba Satellite A45-S151
The memory is under the keyboard on this laptop. You should be able to pry up the keyboard with a small screwdriver between the keyboard bezel and the keyboard itself.
Be very careful not to break the wires connecting the keyboard to the internals of the computer.
I hope this helps.
Feb 22, 2010 | Toshiba Satellite A45-S151 Notebook
BIOS Access
Aug 19, 2009 | Toshiba Satellite A45-S151 Notebook
Pawword reset
I have tried to find the answer to your question and all I can come up with is a support number for Bushnell. Hopefully they can help you. Here is that number:
Bushnell
1-800-423-3537
Jul 19, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Toshiba Satellite A45-S151 Notebook Logo
89 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
