Question about Samsung Computers & Internet
How to fix Syncmaster 2494hs touch menu problem?
Syncmaster 2494hs Occasionally the screen brightness options menu come up by itself and cycles through all the options continuously. The only way to stop it is to turn the monitor off at the switch and on again. Also the touch menu wont respond, so i cannot adjust any settings.
  • 398 Answers
Have you tried doing a factory reset on the monitor? If the problem persists, then it could be an electronics fault or a stuck button.
Posted on May 11, 2014
Chintu-KPV
  • 202 Answers
SOURCE: ViewSonic 27 inch N2750W monitor
There is a hardware problem in your monitor. Probably a loose contact or burt out connection of solder on the main board. Try calling someone who has some knowledge on the main board electronics (try some good friends). Atmost, u may have to change the controller / main board.
Good luck.
Have a nice day.
Posted on Jan 26, 2008
  • 9 Answers
SOURCE: no power light and flickering screen
http://dell-driver.driveray.com/dell-drivers/r_1_1.shtml
Posted on Sep 26, 2008
  • 118 Answers
SOURCE: I have a Samsung Syncmaster
I have a SyncMaster as well, and it has been fine for 5 years. What you are describing sound like the backlight is getting dimmer, which is either a power supply or control board, neither of which are easy to replace. With good monitors getting below $150, I would have a hard time spending too much money to get an old monitor fixed.
Posted on Nov 18, 2008
jubag14
  • 89 Answers
SOURCE: trying to adjust brightness with the control buttons on the bottom right of monitor. I can get to the brightness control but can't change the % of brightness.
what pc do you have then i will be able to help
Posted on Apr 20, 2009
  • 7 Answers
SOURCE: Cannot set the brightness, contrast. Locked menu. Dell LCD.
Niceeeee! this really fixed the issue after 15 seconds with the menu button preessed down the lock became unlocked. MAGIC!
Posted on Mar 25, 2010
I cant click on the brightness option in on the iiyama monitor with id nr E2282HD
If you are configuring the menu option displayed on the monitor itself, there is no control clicking any options with the mouse cursor. You have to adjust the brightness settings touching the buttons on the monitor it self.
Sep 18, 2016 | iiyama Computers & Internet
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
Samsung syncmaster 2433bw , suddenly went out of colour. Tested it with a ps3 but I found a setting that shows me colour .. its the dynamic option under magic colour
Samsung Sync Master 2433BW has the brightness rectangule and monitor menu in one corner of my screen. How I disable/remove that rectangul?
Oct 21, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
My montiour makes auto adjust and shows it's menu & it also change brightness without I touching it's buttons (need help)
open case remove little plug from back of switches kepp it out close case ....fixed but no power light or buttons picture is fine ; )
Aug 06, 2010 | Samsung Syncmaster 17" 720N Monitor
A lot of line on the screen & black cycle appear under left corner of the screen.But, we can use Excel and other application .
This happens if you have any strong magnetic field near by the monitor like speakers etc.
I suggest you to keep that a bit far from the monitor as the magnetic field of it will affect the monitor screen.
And press menu button in monitor and search for the degauss option (Most of the monitors have this option), press degauss option, this must fix your discoloration issue.
Regards
May 24, 2010 | Samsung SyncMaster 720N Monitor
It has a very dark screen, I can barely see my
Check the pins on both end of the connector, make sure they're straight other wise, reposition it with fine long nose pliers. Make sure the connectors are push and screwed tight also. Let us know!
Oct 10, 2009 | Samsung SyncMaster 205BW LCD Monitor
Returned from vacation: Screen on SyncMaster 174v is dim
Look for a brightness control on the monitor itself. If so, use some contact spray to clean it,
Feb 02, 2018 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Screen menu auto-adjust ghost
never try to fix crt monitor you need a new one cos thay are so cheep cost you lots for reppers ,bye an lcd ,,,,nice
Apr 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Brightness automatically going low when the brightness is at 100
hello, please make sure the magicbrite option is not set to "dynamic contrast" as this will change the contrast levels by itself, change the settings by pressing the down arrow touch key on the monitor, change it to any other setting, game mode is blinding on my one (when the monitor works, but thats another story!!!) good luck with samsung customer care centre 0870SAMSUNG (uk)
Apr 04, 2009 | Samsung SyncMaster 2493HM Monitor
Problem with brightness of monitors SyncMaster 710n
HelIo! right after computer inclusions on the monitor screen have a tablet with the message which disturbs to work. The message: brightness of the monitor of 100 %! A problem: how to clean from the screen this tablet so she prevents to read the information. I have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another? have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another?Thanks and sorry about my bad english. Afzal.
Sep 06, 2008 | Samsung SyncMaster 710N 17 in. Flat Panel...
Computers & Internet Logo
81 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
