Question about Lexmark X656de AllInOne Laser Printer
X656de reset maintenance kit - Lexmark X656de AllInOne Laser Printer
How to reset maintenance kit for HP printer 600m 602
Hello Dear
1. Press the Home button on the printer's control panel.
2. Open the "Administration" menu.
3. Select "Manage Supplies".
4. Select "Reset Supplies".
5. Select "New Maintenance Kit".
6. Select "Yes" to reset the maintenance kit counter.
May 09, 2017 | HP Office Equipment & Supplies
Reset fuser HP 5035
Hi
first you have to check the physical stage of the fuser is this good or damaged.
if damaged replace it with a new one.
second you have to perform a reset of the maintenance kit with the following step:
1. in main panel will the option of the Administrator;
2. click Administrator and go with the down arrow until Reset option;
3. Reset In going with the down arrow until Reset Supplies
4. Choose New Maintenance Kit option and confirm with OK
Jun 04, 2014 | HEWLETT-PACKARD Hewlett Packard Premium HP...
How to reset fuser kit on X656de
  • 01: Lift the paper bail, and then remove the fuser wiper cover
  • 02: Remove the top rear door
  • 03: Open the fuser cover
  • 04: Remove the fuser
  • 05: Remove the new fuser from the packaging
  • 06: Insert the fuser
  • 07: Close the fuser cover
  • 08: Attach the top rear door
  • 09: Lift the paper bail, and then insert the fuser wiper cover
Or watch this video
Lexmark Product Videos
click on Service Maintenance
then click on Replacing the fuser
Manual X651de X652de X654de X656de X656dte X658d X658de X658dme X658dfe...
May 11, 2014 | Lexmark X656de AllInOne Laser Printer
Maintenance reset
Reset the maintenance-kit counter
1. Turn the product power off and then on.
2. When XXX MB appears on the control-panel display, press and hold down the OK button until all three control-panel lights flash once, and then stay on. This might take up to 10 seconds.
3. Release the OK button and press the up arrow to scroll to NEW MAINTENANCE KIT.
4. Press OK to reset the maintenance-kit counter.
May 22, 2013 | HP Laserjet P4515x Printer
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
Lexmark x656de erro 929.03 service toner sensor
Please try to use a spare toner, if you have tried using the spare toner and you still get the same error, this maybe a sensor issue (40X4370 Sensor).
If you need further assistance, please contact Lexmark Technical Support.
Oct 11, 2011 | Lexmark X656de AllInOne Laser Printer
Where is the maintenance kit on hplaserjet 4345mfp
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE
item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
configuration page or a supplies-status page
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
Mar 24, 2010 | HP LaserJet 4345mfp Printer
Phaser 8560 warns to replace the maintenance kit
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
Sep 26, 2009 | Xerox Phaser 8560MFP Laser Printer
The printer is showing ready maintenance on the screen
The printer keeps track of how many pages you have printer and will notify you when you need to install a maintenance kit and perform a maintenance reset. You can order a kit here and there is a video on how to install and perform the reset.
http://www.fastprinters.com/dell-fusers-maintenance-kits.asp#W5300
Mar 17, 2009 | Dell W5300N Laser Printer
Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Jan 15, 2008 | Xerox Phaser 8500/DN Printer
Lexmark X656de AllInOne Laser Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
