Question about KitchenAid KGRC608LSS Gas Kitchen Range
Kitchenaid KGRC608 oven is working off and on, rangetop always works, but oven usually starts heating up very slowly and we get a gas smell. We turn it off right away and sometimes it will turn on no problem a few minutes later. We thought it was the igniter, but sounds like if igniter is bad then no gas should be coming in...Help?
4 Suggested Answers
  • 82 Answers
SOURCE: Wolf Sealed Rangetop Stopped Igniting
Do any of the burners click? If not, you may need a new spark module. If only one isn't clicking you may need a new ignition switch that is just behind the knob. I have also seen wires get pinched,stopping the flow of electricity. It may also be a computer board issue which is rare. Sooo you really need to call for service.
Posted on May 28, 2009
  • 61 Answers
SOURCE: ge profile full gas convection
when you determine the part i reccomend checking out www.appliancepartssolutions.com cheep parts!
Good luck
Posted on Jan 21, 2010
heatman101
  • 43501 Answers
SOURCE: KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on May 15, 2010
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Control panel works, no error code, fan runs but oven won't heat?Can't find pilot light info in manual. kgrc608
there is no pilot light on this model. It could be the bake igniter. May also be the control board. I would go with the igniter since they fail more often (even if glowing) than any other component.
Aug 20, 2014 | KitchenAid KGRC608LSS Gas Kitchen Range
My Kitchenaid combo convection/mw works on convect but has a loud humming and no heat on microwave.
A loud humming noise in microwave mode will usually be a shorted high voltage diode or bad magnetron.
Sep 16, 2013 | KitchenAid Architect II KHHC2090S ...
Kitchenaid kgrc608
Try this,
FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
per wiring diagram before performing the following steps:
STEP 1 Power off and wait 5 seconds.
STEP 2 Power on and wait 5 seconds.
STEP 3 Press the following keys:
CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
STEP 4 Press START.
STEP 5 Make sure Timer ID is the same as the oven.
STEP 6 Press CANCEL to exit.
Nov 27, 2012 | KitchenAid KGRC608LSS Gas Kitchen Range
My oven does not work on my KitchenAid range, model 9754287
The first place to start is the heating element that feeds the oven. It sounds like it is bad and needs replacement.
Sep 26, 2012 | KitchenAid Kitchen Ranges
OVEN WON'T HEAT
You have a thermal cutout, usually, behind the back access panel, which is known to cause this problem. It may or may not be resettable but I recommend replacement either way.
Nov 08, 2008 | KitchenAid Architect Series KEBC107KSS...
My oven won't work
most likely cause of no operation is a faulty gas ignitor, simple enough to chsnge 2 wires and a few screws mounting unit to the side of burner bar under the oven floor
May 13, 2008 | Magic Chef CER3740 Electric Kitchen Range
My oven won't work
Replaced ignitor on mine, fixed it.
Nov 18, 2007 | Magic Chef 9122 Gas Single Oven
Oven not heating KitchenAid KERC506HWH3
if this cooker is fitted with a clock check that it is not set to delay start mode(auto) if it is reset clock and this will resolve problem
Jun 13, 2007 | KitchenAid KERC506HBS Electric Kitchen...
KitchenAid KGRC608LSS Gas Kitchen Range Logo
245 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
