SOURCE: Changing the main hose on a Dyson DC15 Animal
Hi Bob.
If you look carefully where hose & elbow jount enter machine you will see a slot.
Rotate elbow so that lug on elbow aligns with slot & pull off.
http://dysonmanuals.llc.nu
SOURCE: how to release the hose from the dyson dc07 vacum cleaner?
look care fully around the handle
SOURCE: This is embarassing, but I have just looked at the
Hi the wand release button is located directly above the the Cylinder release button. The wand release button looks like the picture below. In order to releease the wand you must firstly make sure the Electrical cable is not wrapped up for storage. So unwrap the electrical cable. then find the item as in the picture. Press this button in and at the same time lift the wand. This will realease the wand from the spine of the Dyson.
SOURCE: Hi. I have a Dyson
I think I figured this out. If the hose gets twisted too many times while being used, the pole has a hard time going in and out for removal. (Kind of like how old phone cords got all twisted up after use for a while) To get it out, lift the pole out as far as you can then tug on the hose pulling it down & out ways until you can work the pole all the way up to get it out. Once out, detach the hose from the wand and turn it a few time (I had to go counter clockwise) to un twist the hose a little. Seemed to fix this problem for me.
SOURCE: When I try to release the handle on my Dyson DC28
I'm sorry to hear you're having difficulties with your DC28. The cleaner should recline easily into the vacuuming position when one foot is placed on the cleaner head, and the handle is lowered. If it's not doing this, check the clear u-bend at the rear of the machine for obstructions. For guidance on doing this, please see the link to our Support page below:
http://www.dyson.com/support/help.asp?article=1236&product=DC28-ANIMAL
After removing any blockages from the u-bend, stand the cleaner upright, and try reclining it again. It might be worth using a little more force than usual, in case the upright lock mechanism has jammed. If this doesn't help, or if you're reluctant to try this, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and provide further assistance. You can call us free on 1866MYDYSON - or if you email your details to [email protected], someone will be in contact as soon as possible.
Kind regards,
Jack
Dyson Online Customer Support
