I've got a hoover elite 1205 washing machine model A 6564-009 and i need to take the lower gearbox out because I have to replace the seal, but i cant take the gearbox out, can you tell me how I do tha
How to get the gearbox out of the hoover elite 1205 washing machine
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: i need a new lid for my hoover elite 1205 washing
Please post a complete model number when submitting questions. This makes it easier to locate parts and determine how your appliance is configured.
You can usually find replacement for nearly any brand at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service. Prices vary, so shop and compare. The first three sites on the list also offer excellent exploded view diagrams to assist you in parts location/identification.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Jan 14, 2010
SOURCE: Hoover Elite 1205 washing machine
Does an Hoover elite 920 gearbox fit the hoover elite 1205 thanks
Posted on Jul 13, 2010
walesarumi
  • 6993 Answers
SOURCE: Hoover elite 700 washing machine won't spin
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
# A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
# 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
# 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
# 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
# 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
Regards.
Posted on Jan 05, 2012
My washing machine is leaving dirty marks on my washing can you help?
Looks you have aleakage of grease form a damaged bearing in the drum.
If you have the technical preparation, you should remove the drum and check those bearing. See some interesting youtube videos about issue:
How to remove washing machine Drum tub 1 of 4
How to Replace Washing Machine Bearings
How to replace washing machine bearings on Candy Hoover Otsein Zerowatt
Dryer Repair Replacing the Lower Front Drum Felt Seal GE Part WE9M30
YOU EVEN MIGHT FIND MUCH MORE ON THEME DOING GOOGLE REARS ON
Youtube repair drum
Some other brands are similar to Hoover
Aug 22, 2015 | Hoover Washing Machines
Hoover 960 elite washing machine
contact manufacturer they should be able to help you
Aug 25, 2014 | Washing Machines
Hoover elite washing machine
FIXYA has no idea of any parts for hoover machine . contact hoover direct
Oct 23, 2017 | Washing Machines
Hoover 700lc is putting grease on clothes
The only part of the washer that has oil or grease is the transmission. This is a very bad sign because it says the transmission is leaking and the center seal is also letting the oil grease come through. I would start looking at new machines because it wont be cost effective to repair if you pay a service comapny and if you've never done one its not something you want tot learn on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 28, 2012 | Hoover Washing Machines
I need a new lid for my hoover elite 1205 washing machine toploader!
repairclinic.com
Jan 14, 2010 | Washing Machines
Lost user manual for my washing machine
Try this, in your browser bar, type in: HOOVER AFTER SALES SERVICE.
This should help you.
Please rate my solution.
Thanks.
Aug 30, 2009 | Hoover Washing Machines
Sep 18, 2007 | Washing Machines
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
