Question about Panasonic Lumix DMC-TZ3 Digital Camera
How do i unlock the memory card on a DMC-TZ7
HOW DO I UNLOCK THE MEMORY CARD
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on May 11, 2014
leecom72
  • 4806 Answers
SOURCE: How do you unlock the memory card on the Panasonic
Make sure the write protect lock is off by taking the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Hope this helps.
Good luck
Posted on Jun 22, 2009
xscrewdriver
  • 246 Answers
SOURCE: memory card locked
There is a switch on the SD memory card, slide the switch to unlock position before you insert the card into your camera.
More detail, see here How to fix a ‘card locked’ problem
Posted on Jul 02, 2009
  • 11967 Answers
SOURCE: How do I unlock the memory card in a panasonic
Move the slide switch on the side of the card.
Posted on Dec 15, 2009
SOURCE: our lumix dmc-fs3 camera says the memory card is
It should have a little switch on the side. You slide it down to lock, up to unlock.
Posted on Feb 12, 2010
nikonian2
  • 154 Answers
SOURCE: How do I unlock the memory card for Panasonic
take the sd card out , there should be a loch on the left side when facing the card with the label up, slide the lock down and try agian or try a different card or else remove all power , wait 30 min , insert battery and try to see if the camera goes on (most pansonics have built in memory , so check if you can record a picture if yes then try the card agian )
Posted on Apr 30, 2010
When I turn on my Panasonic DMC-TZ7, the screen displays "This memory card is locked" How do I unlock it?
Pull the card out of the camera, look on either edge of the card, there should be a small sliding tab on either side. Push it up or down to unlock.
Mar 05, 2011 | Cameras
Can i use my SD HC 8 GB memory card which I already have and use in me Panasonic DMC-TZ7 camera, in my DVR. Is it the same as the SD card they say to use in their Easy guide instructions
This shouldn't be a problem, I'm sure the DVR should create a separate folder for storing data in, It shouldn't reformat the whole card, But be sure to back up data on card to Hard Drive as a precaution.
Jan 23, 2011 | Cameras
Panasonic lumix dmc tz7 has message no valid picture to display. Can someone please help? This is not a new memory card , it has been in use for a few weeks.
Have you got the switch on the rear of the camera set to camera and not playback? My camera displays this message if I have no images on my memory card and try to play them back.
Nov 29, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
My 4gb card in my lumix TZ7 shows max. of 672 shots. same card in canon G9 shopws 2200 shots - both at max resoluyion
HI there i think your lumix camera still in inbuilt memory mode. Make sure you set the default memory as memory card. After that check the setting for Photo pixel. For exam 4mp/7mp/10mp etc. Which is set as per your Canon camera. After that check out & i hope the problem will solve, Thanks & waiting for your feedback.
Apr 04, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
I have a DMC-TZ7 and purchased a SDHC memory card RP-SDW08GE1K as this is shown by panasonic to be compatible with this camera. When the card is inserted all I get is "memory card error- please check the...
Well, a Panasonic card should work in a Panasonic camera, if they say it will, so ...
First:
Check that the write-protect switch on the card is not set to read only. It should be toward the contact edge of the card.
Next:
Put the card in and try to format it in the camera.  If it takes the formatting then you should be OK
Finally:
If the above does not work, then check that your camera works with a smaller cheaper SD card (say a 1gb size).  If the camera is happy with that then take the SDHC card back to where you bought it and ask for a refund or replacement. Take the camera with you.
Feb 27, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
I have a panasonic tz7 camera I can download
Use a card reader to download the video to a folder you create on your desktop.
Feb 04, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
I have recently been given a panasonic DMC-TZ7. I
Copy and paste this address into your browser: http://www.youtube.com/results?search_query=Panasonic+Lumix+DMC-TZ7&search_type=&aq=f
Jan 22, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
New 16GB SDHC class 6 card not recognized by my lumix TZ7
You a correct...your camera can use the card. Is the slide switch on the side of the card in the unlocked position? Go into the camera menu without the card and find "reset"...follow the on-screen instructions. Then try to format the card again. Let me know what happened.
Dec 18, 2009 | Panasonic Lumix DMC-ZS3 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
110 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
