Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Instructions on how to change a 1970 John deere tractor pto from 1000 rpm to 540 rpm
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
bbreton
  • 437 Answers
SOURCE: need instructions for changing a drive belt on a John Deere LT155
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Posted on Oct 14, 2009
  • 8404 Answers
SOURCE: John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
Posted on May 02, 2010
wireguy212
  • 1627 Answers
SOURCE: need the pto to work on a 6300 john deere tractor
If you have tried a new sensor and a new switch the the next step is to replace the pto solenoid valve.If that proves fruitless then the b.c.u.needs to be replaced or bypassed.The solenoid valve will cure your problem 90% of the time.If that does not work,let me know,i can tell you how to by-pass the b.c.u..
Posted on May 08, 2010
John deere x495 tractor pto problem.
dami ko po pinag hirapan dito tapos mahahack lang pala Sana namn ma ibalik niyo plsssssssss mahawa na kayo sayng lang pera ko ito user:chageword12345 Pass:09464290212Angelica Inbox x
Jul 18, 2016 | John Deere Garden
Is it possible to convert my 735 Moco from 1000 PTO RPM to 540 PTO RPM?
you do mean a 100 rpm pto up to a 540 rpm pto correct ?
tractors that have the wrong rpm are difficult to speed up as your going to have to give up shaft power (Horsepower) to do this so if your implement is already drawing your hP down , adding a speed increaser is going to make things worse
some out of the "normal" box things ive seen folks using the belly mower take off instead of rear pto , belly mower take off's are sometimes a higher speed but again have less power than rear pto points
Nov 03, 2015 | Garden
How do I change from a 1000 to 540 rpm PTO shaft?
The tractor we had we had to adjust the engine speed so it didn't rev so high.
Jun 07, 2015 | Garden
3010 gas tractor idles fine , but spits and sputters when a load is placed on it . what could cause this ?
bad carb got dirt in it do carb rebuild on it also look for water in gas ingas before you do it i would clean tank and fuel filter to
Sep 04, 2014 | John Deere 3010 4010 Pto Shaft 540
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Jul 12, 2009 | Garden
Engine starts and runs Great. When I engage the Pto leaver on my John Deere L100 the mower fails.
at the point of lowering the pto it's trying tosuck more air to mix with the gas .you might just need to change the air filter.
Jun 07, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
