Question about John Deere Garden
How to change pto shaft on a 4520 from 1000 to 540
1970 4520 john deere how to change the pto 1000 to 540
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I remove the PTO clutch from a John Deere
Locate and disconnect the power supply cord from the clutch. Remove the bolt, washer and retainer from the center of the clutch, It should now slide off the end of the crankshaft provided you have previously removed anything such as body parts or braces that would be in the way. In some instances penetrating oil must be used to help free it up. When you reassemble it, it is a good idea to use a little bit of anti-seize on the engine shaft in case you have to remove it in the future.
Posted on Oct 30, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
wireguy212
  • 1627 Answers
SOURCE: need the pto to work on a 6300 john deere tractor
If you have tried a new sensor and a new switch the the next step is to replace the pto solenoid valve.If that proves fruitless then the b.c.u.needs to be replaced or bypassed.The solenoid valve will cure your problem 90% of the time.If that does not work,let me know,i can tell you how to by-pass the b.c.u..
Posted on May 08, 2010
8130 John Deere pto code 1883.01
Rear PTO Underspeed. Make sure correct shaft is installed. Restart vehicle and select proper PTO engagement rate in the CommandCenter. If code returns, have your John Deere dealer repair as soon as possible.
OMAR259982 8130 8230 8330 8430 and 8530 Tractors Block File OURX935...
Last website shows to me what appears to be a sensor just to the right of the icon A pointer, identifying the snap ring, in the top right photo. http://manuals.deere.com/omview/OMAR259982_19/gif/RW55322A.gif
Best of luck.
Dec 16, 2015 | John Deere Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
How do you replace a broken pto shaft in a 1979 2840 john deere
drill into it and use the biggest easy-out you can get your hands on.
Apr 16, 2012 | Garden
Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
May 17, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
Does a 1978 john deere 2130 have a 2 speed pto and how do you change speeds
Remove the clip from the pto shaft by squeezing it shut,push it in some then pull it out.Turn the shaft around and put it back in making sure the clip snaps back in place.
Nov 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 445 pto will not start Smoke from
If smoke is coming from solenoid on rear top side of trans then internal windings are bad but usually it will blow the fuse.Remove plastic nut from solenoid,slide solenoid off shaft then engage PTO.If solenoid does not smoke slide screwdriver or something like it into solenoid and see if there is any Magnetic force.If smoke comes from deck check idlers and spindles for movement.Be sure to ckeck gearcase oil level on the deck.
Aug 09, 2009 | Garden
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
