Question about Maytag Refrigerators
Hi, how can i fix maytag refrigerator gt1626bas and it doesn't defrost, ice was all over, I melt it, and I checked the heater,but it's cold, few days ago it stoped working completely but in the back
Hi, I have a maytag refrigerator gt1626bas and it doesn't defrost, ice was all over, I melt it, and I checked the heater,but it's cold, few days ago it stoped working completely but in the back I found a part with 4 wires has like timer, I used a screw driver and turn it till clicked, then fridge worked but not defrosting, what I have to do to fix it?. thank you in advance. Mike
    Problem Solver:
  • 12 Answers
IS THE TIMER MOVING TO ACTIVATE A DEFROST CYCLE? IF SO THE HEATER MAYBE OPEN CIRCUIT; OR DEFROST SENSOR IS OPEN CIRCUIT EITHER WILL STOP A DEFROST CYCLE HENCE LOADS OF ICE!!!!!
Posted on Jun 02, 2014
  • 1 more comment
  • mike sam Jun 02, 2014
    Thank you Frank, actually i fixed it a while ago, the heater as you said was open circuit, i removed it and it was broken from one side of the wire connection, all what i did, i just crimp it with a connection and now thank God works fine.. thank you again
  • mike sam Sep 07, 2016
    Hi, i have a maytag frididge/freezer model number GT1626BAS, i removed the faulty timer but i forgot to mark the 4 wires, do you have a picture showing the 4 wires order, the timer located in the back of fridge and doesn't have a plug to reinstall in the right order, but ih has just 4 wires, if you can email me the 4 wires location in that timer , i have blue, yellow , white and purple, so which one goes to number 1,2,3 and 4? thank you in advance.
    mike000000@hotmail.com thank you
  • 116 Answers
SOURCE: Maytag Refrigerator MSD2756DE Coils are icing up
Please disconnect power from your refrigerator before attempting the following! You will likely need an adaptive defrost board for your refrigerator. The defrost thermostat and heater is only available as an assembly and can be checked while the unit is freezing by checking the resistance with a multimeter. there should be some resistance to the heater assembly but not infinite. If the resistance is high then the heater assembly will have to be replaced. Your model has an adaptive defrost board located in the upper right hand back portion of the control panel in the refrigerator side. This cover is removed by placing your fingers in the 2 indentations at the back of the cover one on the left and one on the right and pulling down and forward. Once the cover is off there are a couple of screws directly above the lights which have to be removed and a couple of hex head screws behind the number faceplate and on the back wall near the water filter. Once these are removed the whole housing will come down the board is at the far back right. It will either be a bare circuit board or a small white box. Just unplug it and replace it with a new one. This will correct 99% of the defrost problems on this line of refrigerators.
Posted on Mar 11, 2007
  • 90 Answers
SOURCE: ge side by side refrigerator
what is your serial #
Posted on Jan 07, 2008
22yooper
  • 828 Answers
SOURCE: GE Profile SxS Refrigerator wont defrost after new heater installed
If one coil was burnt out and you replaced the heaters and defrost terminator switch I would recheck the continuity through the defrost heaters. You can do this with an Ohm meter with the refrigerator unplugged. If you had an open coil in one of the heaters you did not have to replace the thermo disk. If you have a complete circuit through the heaters try using the old thermo disk. If you have a meter you can check the voltage from the heater connection on one side to the inlet side of the thermo disk with the refrigerator running in the defrost mode. You should read 115-125 Volts on the meter. This reading tells you that the defrost timer is supplying power to the heater circuit.
Posted on Apr 30, 2008
  • 111 Answers
SOURCE: GE side by side fridge TFX22JR not staying cold
You need to unplug the unit and check continuity with a meter across the defrost heater/s. If they are open, that's your problem. The defrost termination thermostat HAS to be below 20 degrees (varies model to model) to close. If at room temp it will read open. Doubtful it is your defrost timer.
Posted on Dec 16, 2008
  • 105 Answers
SOURCE: Kenmore C978-66792-1 fridge: defrost ices and stops fan
It should just be your ice maker wires and wouldn't be the issue with this fridge
Posted on Feb 10, 2009
Maytag side by side msd264rheb freezer works frig isn't cold. We found ice on bottom freezer side and did melt it with a hair dryer. Frig vent is letting in, now a little cool air, but not a lot.
If you found ice in the freezer then there is usually a lot more behind the back plate. If you let it defrost completely it should work good for a couple days until the ice builds up again. you more than likely have a deefrost issue. There are usually nthree components in a typical defrost circiut. The heater, defrost thermostat and a defrost timer or control. one or those is bad.
Jul 28, 2014 | Maytag Refrigerators
Why does The freezer side stays cold but the refrigerator side gets warm
Your problem is more than likely a defrost issue. There is ice building up in the freezer coils and when it gets blocked with ice the cold air cant blow into the fresh food section. When you shut it off the ice melts and it gets cold again for a few days. remove the freezer back panel and check the defrost heater and defrost thermostat. if they check OK then check the defrost timer. It is best to replace all three components at the same time. This way you will be starting out with new components rather than one failing then the other.
Jul 16, 2014 | Kenmore Side by Side Refrigerator
Side by side refrigerator will not cool on refrigerator side plus a build of ice temp control, model # psb2151grw
It sounds like your freezers' evaporator coils are not defrosting normally.At least once a day ,a refrigerator automatically defrosts the coils in the rear of the freezer compartment.In most cases ,the electric heater that is activated by a timer circuit,comes on and melts any ice buildup .If that heater doesn't come on for several days,the ice builds up into a solid block,and it doesnt allow any air to pass thru to the refrigerator side of you box.
Nov 14, 2012 | Maytag Refrigerators
My refrigerator doesn't cool
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
The fan or blower has failed.
The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
The fan or blower
The timer device
The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Hoping that this will solve the problem of the refrigerator....
Aug 04, 2011 | Refrigerators
Why is my side by side not getting cold enough? No airflow to fridge and freezer not as cold as usual.
The first thing I would check is that the evaporator fan is working! The second thing I would check is the defrost circuit (defrost heater, defrost thermostat and defrost timer) functioning. If you have ice build up on and around the evaporator then you have a defrost circuit problem. You can check the defrost heater with an ohm meter (continuity means good).
If you manually defrost the unit (a hair dryer will speed things up) you can have the time to order the parts while you have use of the unit, since it will work a few days up to a few weeks before the ice builds up again.
Jul 14, 2011 | Maytag MSD2756G Side by Side Refrigerator
Freezer cold refrigerator warm
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
For most situations, unplugging the refrigerator and allowing it to defrost on it’s own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
  2. The timer device
  3. The electric heater coil
Take care.
Aug 11, 2010 | Maytag Refrigerators
My Maytag MSD2756GES freezer coil is completely iced over and fridge is not cooling. I think the defrost element is not working. Need a part #.
Defrost problems can cause the fresh food section not to work. You need to find out why it’s not defrosting. There are three things that cause a defrost problem: defrost heater, defrost thermostat and defrost control.
If you have an older refrigerator, it probably has a mechanical defrost control. Find it and turn it clockwise until the refrigerator cuts off. (Note that the defrost control is normally located either in the refrigerator near the cold control or at bottom behind the kick plate). If your refrigerator is newer it will have an electronic defrost control and you won’t be able to turn to defrost so just continue without doing so. Now that it’s in defrost, wait a few minutes. If the defrost heater gets hot, replace defrost control. If it doesn’t get hot, then the problem is either the heater or the thermostat.
At this point, you need to melt the ice. The best way to melt the ice is to use either a hair dryer or by using hot water (this will be faster but will make a mess).
Once the ice is gone, you can check the heater by unplugging wires and using an ohmmeter to check for continuity. If you have continuity, the heater is good and you should replace thermostat. If you don’t replace the heater, at this point you won't be able to check the thermostat but if the heater is good replace it. Defrost parts can be found at AppliancePartsPros.com
If you have a GE refrigerator made after the year 2000, do not replace the defrost thermostat. Trust me the thermostat is not your problem. 99.9% of the time it will be the heater. Sometimes it is the main board or the thermistor.
Also note that
It's possible that the defrost terminator is bad.
If it doesn't have an electronic adaptive defrost control, then the mechanical defrost control is bad.
In the future, avoid ALL appliances that use electronics. They fail very very regularly and are expensive to replace.
Just think if you had a fridge with a TV in it, and the tv went out. Who would you call? A TV repairman or an appliance repairman?
Buy a Whirlpool refrigerator with the least amount of electronics you can get.
Also, there is a door switch that goes to the freezer section. It controls the light and the adaptive defrost. If the switch is bad, that too can cause the problem.
Lastly, do not buy anything made by electrolux corporation (frigidaire is one of them for example).
They have cheap evaporators that leak and can't be fixed, thus causing you to buy a new fridge every year or so.
Hope this helps your problem......
Jul 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
I just replace the defrost control unjit now cold air does not come into refrigerator side
check motor first, than air ways - could be blocked with ice or just closed...
check if defrost is working you should hear sound of heater and ice melting...
appliancesrepairla.com
Jun 27, 2010 | Maytag MZD2766GES Side by Side...
MSD2656GEQ The coils on the freezer side ices up, then does not cool the refridgerator side
Hi, It's a common problem with no-frost refrigerators, you have a defrost problems, two scenarios. (1) hot air entering freezer/refrigerator, examples. hot summer days, regular openings, high room temperatures, hot foods and broken door gasket, leaving freezer/refrigerator doors slightly open overnight, could cause your evaporator (coils) to freeze/ice up. cases like this, unplug/disconnect your refrigerator, remove produce, clean and let it defrost, for an hour, make sure all ice melted. plug or reconnect your refrigerator let it work/ run empty for another hour, then put back your produce. sure it will work perfect for the next 3-4 days. (2) next type of defrost problem could be faulty defrost heater, defrost thermostat, you will have to open back panel on freezer side to check. check your defrost heaters, defrost thermostat and defrost timer, it's better to change defrost timer and defrost thermostat together, or change faulty ones independently. but before you change any parts, clean and defrost refrigerator first, could just be regular openings, hot days, etc. if after 3-4 days it started to ice up, then check following parts. defrost heater. defrost thermostat and defrost timer, let me know if icing occurs after 3-4 days then we can check those parts i suggested. remember to always disconnect/unplug your refrigerator, before attempting any repairs. good luck
Aug 21, 2009 | Maytag MSD2656G Side by Side Refrigerator
Maytag Rerigerator
Something has stopped the cold air being ducted from freezer side to refrigerator side of things. Possibly duct blocked due to ice build up, evaporator not self defrosting etc. Turn unit off for a few days till it melts and then turn back on. If it was because a door has been left slightly open you will be ok. If for any other reason you will want to have it serviced in the next week or so.
Jan 09, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
111 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
