Question about Elna Quilter's Dream 6003Q
Feels like it seized up. Turns hard - Elna Quilter's Dream 6003Q
  • 69 Answers
You could have some cotton wrapped around your take-up arm. If you remove the cotton it should go again.
It could be needing oil on the upper shaft bush close to your flywheel. Maybey a drop of oil behind your bobbin case.
Does that model have a plastic or metal Bobbin case?
Posted on Jun 28, 2009
    Problem Solver:
  • 7 Answers
Never worked on this machine,but normally when you cannot turn the wheel,it is because there is a piece of thread trapped in the race. take race cover off [where the bobbin case sits] and take out shuttle.check the wheel now to see if it is free.look inside where the shuttle sits and check for thread ends or any other debris. if the machine has a rotary sewing hook this is more difficult for a novice.take both needle plate screws out and remove plate ,check for tread in the raceway,if it is still tight you need a mechnic to dismantle sewing hook dismantle it and reassemble.
Posted on Jun 24, 2009
Singer sewing machine model number 337 troubleshooting
Appears to be an older mechanical machine. Could be a belt is shot or possibly the machine has seized due to old oil that has dried. Seizing is very common in older machines that have not been cleaned and oiled regularly. AVOID trying to run the machine until you can address the problem. It could burn up the motor or break some parts. You can try repairing it yourself or take it for service.
Wheel on right side that controls the needle up and down is very tight...
Mar 18, 2018 | Singer Sewing Machines
Bernina pressed foot doesn't move. The wheel doesn't work
An older mechanical Bernina? Most likely seized due to dried out oil. Take it for a thorough cleaning and oiling.
If you feel adventurous and have some mechanical ability:
Feb 26, 2017 | Bernina Sewing Machines
E6 code for brother xr7700
E6 means the machine is seizing somewhere and the motor is working too hard to turn the hard-to-turn machine. Get is serviced before it seized completely and the cost of repair goes even higher.
Apr 03, 2014 | Brother XR7700
I have a Singer serger pro4d that the wheel on the side is hard to move and when it sews its sluggish. What is wrong with it?
It is SEIZED!! Take it in for service. Sergers should be seviced annually as they are notorious for seizing. It's an easy fix and your machine will be unrecognizeable upon it's return
Machine Tech
Oct 20, 2013 | Singer Tiny Serger TS380
Why does the bobbin case on my Baby Lock Elegante seize and pop up?
Sounds like you have a burr. Examine both the case and the bobbins for burrs. (use your fingernail... feel for thing that catch your nail) File them off carefully with fine grit sand paper.
Burrs can happen when a needle bends and breaks... stabbing the wrong area... sometimes it's manufacturer defect in the plastic bobbins.
Nov 17, 2012 | Sewing Machines
Machine stop moving . i opened the plastic cover and visually everything is OK.The motor is working when untighted, but stop moving when the tensioner is tightened. Plese, help !!!
Something in the drivetrain is seized. My first step would be to release the clutch knob (as if you threading a bobbin) and see if the motor will turn. If the motor turns with the drivetrain disengaged, it will be necessary to isolate the seized portion of the machine. You can either obtain a service manual and go through all the operations that are engaged by the drive train, or take it to a qualified service technician.
May 11, 2011 | White Sewing 1866 Mechanical Sewing...
Hand wheel is hard to turn
If you take out the bobbin case and slide off the needle pate, you can inspect the bottom area for a thread jam. The black post that the bobbin case slides onto is called the thread hook. It should have a loose feel to it when you gently move it around, it should not have a "solid feel".
Another area that sometimes wraps the thread is the take up lever area.
(the lever that moves really fast up and down as the machine is sewing)
If the lever has been pushed to the left, it's possible the thread has wrapped up in that area.
If those two areas are o.k. you'll need to take it in for service.
Oct 16, 2009 | Husqvarna Viking 1
Siezed motor
Well, AC/DC motors do "seizing" quite well in fact.
If you were supposed to oil it prior to the failure, they most likely will not work now! (Bearings are shot)
BUT.....Lady Luck is always hiding, so you never know.
Tear that dude down, and give it some 7-in-1 oil. Spin the motor BY HAND. See if she will "free spin". If she feels like a 6 year old fighting a catfish, it will be a "no go, no fix".
But if she WILL spin after that......give her a couple of drops extra, put it back together, and see how long she lasts.
And then keep on oiling it.
Granted, I can't tell you exactly WHAT seized your sewing machine up, OTHER than motors are motors, and bearings fail when they get dry. In this case, you might get lucky!
May 29, 2009 | Brother Sewing Machines
Sewing Machines Logo
401 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
