After the sensing the washer goes to wash cycle and stays there, it will not complete the rinse and spin cycle. I tried taking clothes out some of clothes out and reaarranged the load loosely and tried it agsin but it still stays in the washing process. What do i do to fix the problem. I have just purchased this set on May 9th, 2014and it was installed on May 10th, 2014. I 'm getting irritated because i want it to work. Can u help me ?
danromarris
  • 101 Answers
SOURCE: kenmore series 80 washing machine spin cycle will not work
If the spin setting is not working chances are that your lid switch is bad. The lid switch is a safety feature installed that makes it so that unless the lid is closed the machine won't go into spin. This keeps from allowing the spin to shoot water all over the place if the lid is up. It is an easy fix though and very cheap. There are two panels on the side of the control panel. If you pop those off with a flat head screw driver you will find a screw holding down that control panel on each side. Remove those and then lay the panel back. Next insert the flat head under the front of the machine where the crack is at about an inch from the top of the machine. Pop it up and you will see the lid switch there underneath there. Remove it and follow to where it connects in the panel and disconnect and then install the new one. It should work fine again for you. Let me know if you have any other questions.
Posted on Jan 21, 2009
  • 1214 Answers
SOURCE: Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Posted on Feb 04, 2009
aborcass
  • 2651 Answers
SOURCE: washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Posted on Mar 02, 2009
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
  • 67 Answers
SOURCE: Admiral Washer........Spin cycle not working.
BAD LID SWITCH
Posted on May 18, 2009
LG Tromm Steam Washer Cycle is complete and the stuff is so wet that they have to wrung by hand to even put they on a clothes line. Can washer be put on spin only? How?
call a technician as it indicates that the cycle from rinse, spin is not progressing to spin only
rinse,spin is a low speed spin to facilitate the rinse and to balance out the clothes ready for the fast speed spin cycle
Feb 25, 2017 | LG Washing Machines
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag centennial washer
Most likely pressure sensing switch. What is your model #? If your model has this part # W10292584 then it is the problem.
Nov 11, 2017 | Washing Machines
My neptune washer will start and run about half a cycle and it acts like it gets stuck and on one cycle and never shuts off. I put a load of clothes in before I went to bed and next morning the machine...
What does half a cycle mean are you in Wash cycle, Spin Cycle? What does the Cycle Status LED indicate?
If you think the wash load is in a spin cycle of the wash cycle or rinse cycle place the machine in Spin Only cycle and see if it will complete.
Waht are your DIY skills? Do you want to try the repair/fix?.............Rich
Oct 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Clothes are not completely rinsed (they're soaking wet) at very end of spin cycle.
Try to fill minimum water level in your machine with out adding detergent or clothes and complete cycle and see if it is any watter inside. Could be a water pump.
Dec 29, 2009 | Roper RAX7244KQ Top Load Washer
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
Top Washing Machines Experts
