Question about GE WSXH208A Front Load Washer
GE WSXH208 drum
Drum part
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
Ge washer WSXH208 drum wont turn
Take back panel off and see if the belt broke or possibly came off the pulleys. Should go from motor pulley up and around big pulley on drum back.
Apr 05, 2015 | GE Washing Machines
GE washer WSXH208 I shorted out he 2 wires (blue and white) on the bottom of the door latch assembly thinking I could hot wire it to run while the part came in and heard a click in the left side of the...
Probably a relay that you heard clicking. from what you described sounds like it's just a SPST(single pole single throw) switch and nearly impossible to hook up wrong. Good luck!
Oct 11, 2014 | Washing Machines
I have a WSXH208 ge front loader It started to fill was and then in the middle the water pumped out but did not finish and clothes were sopping wet, Drum stopped spinning. what could be wrong
all front loaders will not go into high spped spin if there is water in the tub.You should first remove the bottom panel and check the water pump for blockage.Some units have a sscrew style filter to catch debris befor it enters the pump impellor.when you unscrew the filter make sure you have a wet vac handy.
Apr 02, 2013 | Washing Machines
The rubber seal has come away from the inner seal drum after one of the shocks broke. I have replaced the shocks but the seal is off. How do I reattach the seal to the drum? model#WSXH208
You would need a special adhesive glue made to withstand the heat! But I wouldn't try. Not even Red Green's Duct tape notion could bail this issue. You would have to replace the complete seal. And that...you're probably looking...around $30-50.
Dec 17, 2009 | GE WSXH208A Front Load Washer
I have a wsxh208 washer that pounds awfully when in spin mode washer is level?????
check the shocks to see if broken.Is this item new?did you remove shipping restraints?Also check the top springs to see if there ok.Hope this helps happy thanksgiving.
Nov 25, 2009 | GE WSXH208A Front Load Washer
Does not advance from wash to rinse to spin
The washer is new and under warranty so I have asked for warranty service.
May 23, 2009 | General Electric WSXH208H Front Load...
GE Model WSXH208-How do you know if PUMP motor is not working?
Found out the motor usually don't burn out that easy...therefore, I put it all back....let it run and felt the motor warming up....then it works....guess I was just a little antsy... ;=))
Dec 31, 2008 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
15 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
