Question about GE JVM1790SK Convection/Microwave Oven
How to replace the nightlight on GE Microwave JVM1790SK?
4 Suggested Answers
  • 3 Answers
SOURCE: The nightlight bulb burnt out. I replaced it but
flick the switch!
Posted on May 18, 2009
Controlfrk
  • 304 Answers
SOURCE: I have a Ge jvm1790sk and while the microwave is
Unplug unit before entering.
The light bulb is behind the air vent at the center top of the microwave. Remove two screws at the very top front of the microwave and pull the vent cover forward at the top. Sliding left is sometimes necessary to release the bottom tabs of the vent cover. The light fixture will be behind this cover.
Good Luck. Reverse the above process to reassemble.
Posted on Sep 06, 2009
  • 65 Answers
SOURCE: Model JVM1790SK 01 Where/how do you change the
This is a pretty bad design, sometimes you can just remove the upper grill and access the light assy. If the panel is to tight to work in to change the light,you get to take the whole micowave down and remove the outer wrapper to change the light bulb. This is also not a standard bulb (part #WB25X10019). You may be able to get one from Lowes or Home Depot actually Sears would be a better bet, otherwise you will need to order one from an appliance parts outlet. Hope this helps and sorry I didn't design the thing I just fix them.
Posted on Jan 24, 2010
Over the range Danby Model dom16a1wdb surface light replacement
a screw at the back side when removed get access to the bulb.Usually 40Watts bulb with1/2 " threaded
Mar 28, 2014 | GE JVM1790SK Convection/Microwave Oven
Dead ge microwave
magnetrons work only when the unit is cooking
it smells like an insulation from overheating wire so could be a fuse and failing transformer
take it in for a proper diagnosis and quote but if it is over 2 years old the cost to repair could be more than a replacement unit
May 26, 2017 | GE JVM1790SK Convection/Microwave Oven
I need to replace my ge microwave zmc1095. what is a comparable microwave?
You can call GE customer service to see if they have "drop-in" replacement.
Otherwise, you can refer to your owner's manual for the specifications to compare to new ones.
Jan 15, 2013 | GE JVM1790SK Convection/Microwave Oven
GE microwave/convection oven 1790 there is a #8 displayed in the right upper corner of display
HELLO.
When the F8 code appears,it means that electric control requires replacement because the relay drive circuit has been lost.
Attempt to clear the code by pressing Cancel and cutting power to the range for 30 seconds.
If the code cannot be cleared, replace the electric control.
thanks.
Sep 21, 2011 | GE JVM1790SK Convection/Microwave Oven
No power to microwave JVM1790SK ...checked outlet and it is live
HELLO.
Since the outlet is live,the power problem is from the microwave.
check on the back of the microvave to locate the fuse that control the supply of power to the microvave.
Change the fuse because it is unable to control power supply.
Then plug the microwave to the outlet.
Thanks .
Sep 19, 2011 | GE JVM1790SK Convection/Microwave Oven
While changing nightlight bulb, it twisted off and short circuite
In all probability, the short took out the relay on the control board and the control board will need to be replaced.
I hope that helps.
Mar 16, 2010 | GE Microwave Ovens
I have a GE jvm1790 microwave that when its pluged in, the magnatron fan runs with the interior light is on constantly. I can't start either the microwave or convection. Everything stops when the door is...
The megatron tube is not working. The microwave should turn off when the door is opened for safety. If it is still under warranty, return it. If not, you may consider replacing the unit. I know its expensive, but its just taking up cabinet space tonight.
Nov 06, 2009 | GE JVM1790SK Convection/Microwave Oven
My GE JVM1790SK
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 You may have a bad door switch. We also have a file on door switches at our site.
Feb 15, 2007 | GE JVM1790SK Convection/Microwave Oven
Open Questions:
GE JVM1790SK Convection/Microwave Oven Logo
16 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
