Question about LG Flatron L1710M 17" LCD Monitor
My monitor is problem when i open that time is come power saving mode?
My monitor is problem when open that time is come power saving mode
    Top Expert:
  • LG Master
  • 74,383 Answers
The problem post of your's is difficult to understand. What is the problem you faces with this monitor? Provide more details, please. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on May 11, 2014
  • 65 Answers
SOURCE: LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Hope that helps. Good luck
Posted on Feb 16, 2010
  • 252 Answers
SOURCE: I have a LG W2361VG monitor and I can't get it off
These are just suggestions, not sure if it will fix your problem (not listed in any order but only do one at a time)
1. Change BIOS battery (reset BIOS)
2. Clean out machine (dust, reseat cables, cords etc...)
3. Try removing the power cord from the monitor, hold the power on button for ten seconds then put the power cord back on
4. Try reseating the video card.
Hope this helps.
Posted on Oct 21, 2009
SOURCE: LG LCD monitor goes in power saving mode
press fn + F5 buttons, screen will appear
Posted on Dec 21, 2008
  • 18 Answers
SOURCE: monitor flashes POWER SAVING MODE.. monitor dosnt turn on
A quick Google tells me this is a VGA analog interface monitor. Have you another monitor to test with, to see if the problem is the PC or the monitor. If another monitor works (esp. a CRT) your L1730s may still be fine. Set the refresh rate of the graphics adapter to 60HZ. then test your LCD again. Some monitors just blank the screen when they get a refresh rate they cannot handle. p.d.
Posted on Jan 14, 2007
  • 4 Answers
SOURCE: Flatron L1719S
I think your monitor is unstable. Is it showing power saving when you boot your PC? Does it show something when the Windows XP splash appears?
Posted on Jun 05, 2007
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
Have a Dell E228WFP monitor keeps going into power save mode.
does it go into power save mode with your actually doing something. Like for instance if your typing does it go into power save mode? If its going into power save mode when your not doing anything on it then its as simple as a setting either on the monitor itself or in the power settings within your computer accessible by the control panel and screensaver
Jul 22, 2012 | Dell E228WFP LCD Monitor
My monitor won't come out of power save mode. How do I get it out of power save mode?
Problem is not with Dell E197FP LCD Monitor, it happens sometime and the culprit usually is an empty battery on the motherboard. The motherboard battery is used when the mains power is off. When your computer detects an empty battery, it goes into a low-power mode.
The computer will then display as message, like "Power save mode - press any key on keyboard or move mouse".
Better to replace battery:-
  • open the case of your computer;
  • visually scan the motherboard for a button-cell battery (it looks like a digital watch battery, but a bit larger);
  • remove this motherboard battery from your computer;
  • restart your computer: it should now power up normally (you may get some warning messages but ignore them);
  • set the date and time of your computer using the "Date and Time" control panel;
  • you can now use your computer normally, but you will lose date and time settings when you disconnect the computer power cord, since there is no motherboard battery present to store them;
  • replace the battery or buy new;
  • install the new battery in your computer;
  • restart your computer, and set the date and time again; the settings will now be saved using motherboard battery power.
Dec 09, 2010 | Dell E197FP LCD Monitor
Hi ,My dell screen goes to sleep mode after a long wait of not being used, say an hour, ..............but the pc sleep is not set ? The message comes up to move mouse ,or press any key ,but this does not...
please check your monitor settings may be sleep time is defined there. secondly check your system sleep time again. and also check window power saving mode. may be your system goes to power saving mode.
If you like this rate me kindly
Oct 12, 2010 | Dell E153FP 15" LCD Monitor
My monitor goes into power saving mode all the time!
Three years old will more likely to hav bad caps by now, common problem on ALL brands, see example of failed monitors due to bad caps, you need to open it up and see, http://s807.photobucket.com/home/budm/allalbums
Feb 13, 2010 | Computers & Internet
Every time i turn on my daewo monitor it saying "POWER SAVING MODE' then turn off power auto.
Hi this means your Monitor is in power saving mode , it is trying to save power when you dont use it, Change your power saving settings and it will work perfectly
Thanks
Dec 28, 2009 | Computers & Internet
When i switch on the machine ,the monitor displays monitor is in power save mode
Click start- open control panel then open power option then disable power saving mode from threre.
I hope that this has been very helpful for you
Nov 27, 2009 | Sun Microsystems Ultra 5 Power Supply (p/n...
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
How do we turn off the POWER SAVING MODE on the monitor screen?
Try going into your Start Menu then going into your control panel...then clicking on your "power options"....then switching the options to 'always on'..if this does not work..(as it seems you may not be seeing this because the monitor is in power saving mode) try fiddling with the setup option on your monitor and find a possible powersaving mode enabled function and disable it. every monitor is different so I couldn't really help you here...if this doesn't yield results try another monitor to see if it's the monitor having the problems or the computers video card...the video card could very well be the culprit...
Apr 08, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
LG Flatron L1710M 17" LCD Monitor Logo
81 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
