Question about Kyocera wild card Cellular Phone
HOW TO PUT THE SIM - Kyocera wild card Cellular Phone
How to change sim
if your mobile is an unlocked one which can use any providers sim , you should be able to put any sim you wish to in but if you've put a sim lock code on the sim your using you will have to put in the code you will then be able to turn off your mobile and remove your sim and replace it ,turn on mobile then if asked sim pin code enter the one you used before removing old sim . hope this helps you.
Jan 04, 2016 | Cell Phones
Why when Samsung TAB 5 works with Vodafone sim but when I put Telasta sim it just say insert sim
To use the Telasta sim you first have to get an unlock code from Vodafone.
Look in your contract when they have to give you the sim lock release code
Jul 27, 2014 | Samsung Cell Phones
When i put sim fail and always say no sim mode and same sim when i put it in other phone work also i put another sim in my phone worked the problem that samsung not play this sim the name of this sim card...
u will need to reset the phone firmware. i will give u a code. Make sure U remove ur memory card and put in a sim u dnt use often,ok. At main screen, dial: *2767*3855#
Mike
Apr 20, 2011 | Samsung Jet S8000 Cell Phone
I put my sim card into my phone and it says enter special sim code
i put my sim card into my phone and it says enter special sim code
May 20, 2010 | Sharp Sidekick LX Smartphone
This is a question M FRIEND HAS A SAMSUNG WITH A T MOBILE SIM CARD my friend is going to sell me his phone but he wants to keep his sim card when he takes his sim card out and i put mine in Virgin will...
In most cases putting in your sim card will in fact lock the phone. but it's not permanent. So try it. put your sim card in.. if the phone works, then you don't have to worry about unlocking it. If it does lock the phone, just put back his sim into the phone and it will be fine. There are many places that you can unlock phones or even purchase unlock codes. This is NOT illegal, phone carriers just make it difficult to do. Good luck and let me know of the results.
Ciza
Oct 30, 2008 | Cell Phones
New Razr v3 Sim Phone address transfer
It's not anywhere in the literature. Before you remove the sim from the old phone copy the address book into the old sim. Then take the old sim out of the old phone and then put it in the new phone. Copy from the old sim into the new phone. Then take out the old sim and put in the new sim and copy from the new phone into the new sim. Your all set.
Oct 11, 2008 | Motorola Mobility RAZR V3
HTC Tilt When I put my sim card in the phone it tells me "Sim Card Missing" and When I put the sim card in another phone it works fine.
when i put my sim card in a at&t tilt phone it tells me to enter a sim block code. when i enter my puk number it tells me its invalid. what code should i enter
Sep 12, 2008 | Lands Phones
Sim card
sim block try pin code ..switch off your mobile put new sim enter pin code 12345.
Feb 05, 2008 | Motorola Mobility L2 Cellular Phone
Inactive sim
I have the same problem since I got O2 to block my phone when i lost it. Now it's found it says "Inactive SIM", even though the SIM works in other phones.
Nov 28, 2007 | Sony Ericsson K800i Cellular Phone
Kyocera wild card Cellular Phone Logo
19 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
