How to troubleshoot a white wing ww1? - Computers & Internet
Small duck with white stripe on wing
What color are the wings? Is the stripe only visible in flight.
Apr 03, 2017 | Car Audio & Video
Can you please tell me about the Battlefield 1 game's compatibility with different operating systems?
BF1 Hack is one of the best game that makes you feel what soldiers of first world war do. As the game is on the theme of WW1 and it also uses many of the vehicles and hacks that are used at the time of WW1. You can play this game in many platforms as it is compatible with - Windows 7, Windows 8, Windows 10 and it is compatible with 64 bits systems only.
Nov 23, 2016 | The Video Game Consoles & Games
Wiring diagram for a vw sharan 2000 x reg wing mirrors
your mirror control switch has 9 wires.,your drivers door mirror has 5 wires color coded .from your mirror control switch to your drivers siide mirror / 0.5 black .0.5 brown. 0.5 brown. 0.5 black. 0.5 black.
your passenger mirror wires are 0.5 blue/black .0.5 blue/grey. 0.5 blue/white. the passenger mirror has a ground cable 0.5 brown.
the passenger mirror wire 0.5 green/white connects to a 5amp fuse/F25 onto F31 5amp to a wire 0.75 green/yellow.back to the mirror control switch.
Sep 11, 2012 | Cars & Trucks
What kind of battery does a chase-durer wing commander x watch take?
Well, since NONE of these answer the actual question I will.
Battery size - 370
Source - I own the watch
Jan 28, 2012 | Chase-Durer Wing Commander XVl Chronograph...
My tmobile wing won't turn on
If you have an SD card in your phone take it out and try turning it on. You can take it out when you see it going back to the white t-mobile screen. Once the device is on and to the home screen you can insert the card again.
Oct 28, 2008 | T-Mobile Wing™ Smartphone
Tmobile wing screen searching for SD card
ok first you need microsoft sync on your pc second you need to download the wing update from t mobile it will walk you through the process the bars you are seeing means it is in flashing mode this software will fix the problem any questions e mail me at blok420@yahoo.com
Oct 05, 2008 | T-Mobile Wing™ Smartphone
My wing has a blank white screen with a black scratch
i think your solution to your problems is the T-Mobile Wing Flex Cable that must of gotten cut.it is the ribbon cable that allows you to move lcd up and down, the installation of replacing the cable is very hard if you dont know what your doing, trust me your lcd is not broken.
Jun 14, 2008 | T-Mobile Wing™ Smartphone
Won't Turn On
Mine was a simple fix. Hope yours is too.
You need to take the unit apart to get to the cord reel. If you don't know how to take your unit apart, here are some instructions on how to take apart most of the Miele canister units.
http://www.sannerud.com/house/miele.html
Once it is apart, you will need to take out the cord reel. There is a small rubber hose which needs to be removed on the outermost part of the reel. Then there is one small silver screw that you must remove as well. One these two items have been removed, carefully lift the entire cord reel assembly upwards. When you are doing this, ensure that you are also lifting the black and white wiring along with the reel - just make sure that you're not yanking it and possibly breaking the connectors off. As you lift the entire reel assembly out, you can also remove the white wiring harness which connects to the main switches on the vacuum.
Now, here is the trickiest part - not really that tricky if you are good with your hands.
First, make sure that the cord is retracted fully. Then, start pulling the white plastic cord reel away from the black plastic assembly about 1 inch or so. Between the black assembly and the white reel, you'll notice a copper-like metal spring which is attached to the white reel. Make sure that as you are removing the white reel further, that you are maintaining visibility with the copper-like spring. DO NOT LET THE SPRING OUT OF ITS OWN WHITE REEL (the spring has its own reel which is difficult to wind up again, so be very careful!).
Make sure that the spring is fully retracted at this time. If it is not, wind the reel so that the spring is not wound up anymore around the white reel. Carefully slip the spring out of the white reel and leave the spring as-is ensuring that it does not unwind itself out of its own reel.
Now that you have the white reel off the black assembly, inspect the inside of the inner part of the white reel. You'll see two copper rings with 'wings' on them. These wings transfer power to the vacuum. There may be some grease (black) which you should wipe off with a paper towel. Also wipe the metal rings on the black assembly which touch these 'wings'. (the wings touch the metal rings to send constant power to the motor. The wings are there so that as you wind and unwind the power cord from the vacuum, there is always constant contact with the metal rings on the black assembly.
Now, carefully pull the wings up and out. If you can picture it in your head, what you're doing is ensuring that there is a good contact between the copper wings and the metal rings on the black assembly. Do this for all 4 wings on both the inner and outer copper rings within the white reel. Make sure that the 4 pads are clean and grease/dirt free.
Once you've done this, it's time to put the white reel back on the black assembly. Do everything you did earlier, but in reverse.
Carefully take the copper spring and align it to the white reel - you'll see a specific slot where the spring slides and grabs onto on the white reel. You'll probably have to place the white reel slightly onto the black assembly rod in order to achieve this - again, you must be good with your hands to do this without breaking anything.
Once the copper spring is attached to the white reel, press the rest of the white reel onto the black assembly. HINT: turn the white reel slightly so that you're applying some tension on the spring - this will make sure that the spring doesn't fall out of the white reel.
Reassemble the cord reel assembly (black and white parts) back into the vacuum. Make sure that the black and white power cables are out of the way. Once seated, wrap the black and white cables around the assembly and reseat the white wiring harness. Reapply the black rubber tube to the cord reel assembly and replace the silver screw to hold the entire harness down.
Close the vacuum casing, replace the control panel (power and cord buttons). Close the unit, plug it in, and power it on!
If it worked for you, congrats! If it didn't, sorry, you've got a much bigger problem with your unit.
Dec 23, 2007 | Miele S514 Solaris Turbo Plus Vacuum
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
