Vulcan gas heater comes on and stays on for a few minutes. Unit then comes off and on intermittently but blows cool air instead of hot. The remote control asks us to reset but when. We do it just does the same after a few minutes. Had a technician to fix it yesterday worked fine for 24 hours but when we got in today rc says reset although it was still blowing hot air this time. Any ideas?
  • Heating & Co... Master
  • 1,873 Answers
Sounds like it needs a good maintenance. What did tech do to fix it?
Posted on Jul 23, 2017
  • 189 Answers
SOURCE: Limit Switch
It is rare that a limit switch goes bad. It is a safety control. If it is shutting off your furnace there is a problem that it is protecting you from.
If the limit switch is shutting the unit down your furnace is overheating. Check the filters. Check for any obstruction in the blower assembly. Check to see if you can raise the blower speed. Make sure all registers are open in the house. Your evaporator coil could be obstructed if you do not take good care of your filters.
Posted on Mar 08, 2009
  • 252 Answers
SOURCE: my fridgidaire gas furnace is blowing cold air
Today’s furnaces are controlled by a computer which constantly monitors for problems. When it detects a problem it will shut off the burners. Depending on the problem and the specific furnace it will either “lock out” the furnace or cycle it through a purge (to rid it of un-burned gas and excess heat) and then attempt to re-start it. If the problem continues to occur then it will “lock out”. Depending on the problem and the furnace it may again attempt a re-start after several hours. In any case if the problem was not detected/caused by a sensor which requires a manual re-set, when the power to the computer is interrupted or the call for heat is interrupted the computer is reset and it will again attempt to re-start the furnace. The most common problems are:
· Low or lack of flame sense. Different furnaces use different methods to detect a flame – often these “flame sensors” become dirty and have to be cleaned (usually with sandpaper or steel wool).
· Bad igniter. (Doesn’t light at all).
· Clogged combustion air intake or exhaust.
· Clogged condensate drain. (90+% efficient furnaces).
This is not a complete list, only the most common!
Depending on where you live your HVAC system runs more than anything else you own (including your car). All furnace manufacturers “recommend” “regular maintenance” of your furnace. In fact, all that I am aware of state in their warranty that the warranty may be voided due to lack of “regular maintenance.” The industry has defined “regular maintenance” as yearly (in fact, some manufacturer’s warranties state yearly). Due to safety, liability, and the need for many other things to be checked, cleaned, and/or adjusted (2-page checklist where I work) to ensure safety and efficiency. Due to the large number of furnaces and the differences between them. Moreover, due to the terms of this site, I WILL NOT AND CAN NOT give you specific instructions on how to perform repairs on your furnace. I suggest that you contact a local, reputable, HVAC service company for (a tune up, preventive maintenance, general maintenance, yearly service call, general service, or whatever they call it).
While I may not have told you how to fix your furnace yourself, I have told you how to fix it. Please rate my answer.
Posted on Mar 14, 2009
  • 22 Answers
SOURCE: Bought 44155c hunter thermostat air won't turn on.
If unit worked before you tryed changing t-stat then its possible the t-stat wires are shorting each other out.take t-stat back off cut back wires a good 6 to 10 inches or if you dont have that much wire to play with just cut back as far as you can and make sure there is no bare wire touching each other ,then just to test unit to make sure its working ok twist yell.,red,green together this should bring both units on and should blow cold.if this works up to this point on the new stat read directions closely there might be a jumper wire in the stat that needs connected usually from y1 to w1 you would install a jumper wire .see if this helps if not write back i have 1 other solution.i hope this helps
Posted on Sep 15, 2009
  • 79 Answers
SOURCE: gas heater doesn't stay on longer than 5 minutes.
It sounds to me that your air flow is restricted somewhere. The first thing to check is your air filter. If that gets real dirty your restricted air flow will cause the hi-limit(hi temperature limit switch) in your heat exchanger compartment to over heat and open up your gas valve electrical circuit,thus, shutting off the gas to your burners. After the hi-limit switch cools down the furnace will go back to heating again then it will overheat again(you get the picture?) If it keeps cycling on and off like that the house will never get warm if it is cold outside. If your air filter is reasonably clean(you should be able to see light thru it easily) then the secondary heat exchanger could also be dirty, this is located above the indoor fan housing, you would need to pull the indoor blower assembly out of the furnace and look up above. The secondary heat exchanger looks similar to a radiator will fins. You can use a medium stiff plastic brush to brush the dirt,hair, whatever off of it. Another problem spot would be the cooling evaporator coil (if you have central airconditioning) located most likely above the furnace in the plenum(if your furnace is in a basement). This usually is difficult to access if an access cover wasn't installed when the airconditioning was installed. I would recommend an experience service tech to clean it for you. Also make sure all you supply air registers and return air registers are open . These are the things I would check first. Good luck!!
Posted on Nov 20, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my heater blows cold air. any ideas?
Your unit has a diagnostic light on the circuit board. You need to look thru a small viewing port to see it. Once you count the number of b links, remove the lower panel and look at the wiring diagram for an error code chart. Then read the following to give you some ideas what to do.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Dec 01, 2009
In AC mode the cooler fan doesn't turn on and after a little while the warm air starts to blow instead of cold air. Any ideas
Sounds like a bad or stuck reversing valve. Typically r.vs. are energized in cooling, verify 24 volts to valve, if yes , bad valve
Sep 30, 2016 | Whynter ARC-14SH ECO-FRIENDLY 14000 BTU...
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Lound vibration when running
Check gas control valve.
Good luck,
Marty
Feb 18, 2013 | Rinnai Water Heaters
My 1999 Chevy Malibu runs hot? It started when it overheated. We changed the thermostat, then water pump, then temp sensor gauge and the temp gauge goes high but only when the heater stops blowing hot...
Air pockets will make the guage do that, and also cause your heat to come and go. Also, a poor radiator, as in rotting, or plugged up, will cause high temperature issues.
Sep 20, 2011 | 1999 Chevrolet Malibu
Pilot lights but won't stay on in my older style vulcan space heater. thermo couple was replaced last year.any ideas that i could try thanks
Most common cause of pilot light problems is air movement. If your space heater exhausts gas through the roof, ensure the cap is on and level. If not, outside air movement will blow out the pilot. If you do not have an exhaust gas duct, check that the unit is positioned so that it does not blow air back onto itself from walls, furniture, etc, and ensure no other devices that move air are aimed towards the unit. The unit also needs to be placed away from central ducting, including return vents.
Hope this helps!
Aug 09, 2010 | Vulcan AUW230A Heater
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
Vulcan Quasar 40 air issue
Hi the problem you have is your heater is cutting out due to the over temp switch getting to hot the reason for this is that your fan is not working thus not enough air flow is getting through the heat exchanger to keep it cool
your heater is designed to not exceed a certain temprature so as not to become a fire risk
to solve your problem you will need to replace your fan
this will solves your problem
Jul 27, 2009 | Heating & Cooling
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
