Question about Dell 924 All-in-One InkJet Printer
How do I attach the cartridge holder top? The springs and cover came off, nothing broken.
I have a hard time seeing well enough, to see how and what I do first to replace springs and cover back on. The printer cannot work without. Does the printer cover move further back than when just lifted up to change ink cartridges? It would help to see in there better. Thanks!
SOURCE: Dell 922 All In One Printer wont print
I have this exact same problem, but when I replaced the black ink cartridge it worked for 3 days. Now it isn't recognized. The printer icon has a big question-mark over the black ink cartridge. Replacing it with another cartridge does nothing.
My solution. Throw out the darn thing and buy a laser jet.  Paying for ink is too expensive anyway.
Posted on Oct 13, 2007
  • 31 Answers
SOURCE: ink cartridge carrier jam
If possible, shut off the printer completely and manually move the ink carriage to where the cartridges can be swapped out. turn it back on and try again. try to see if some mechanism that holds the missing cartridge in place has swung down and is bumping into something, preventing the carriage from moving past a certain point.
Posted on Aug 21, 2008
SOURCE: How do I manually center the ink cartridges on my A960 ?
The ink cartridge had jammed the carrier and prevented it from moving. I stuck my little finger in the bottom of the carrier, pushed the cartridge up a bit, freed the carrier and was able to move it manually. I replaced the cartridge and all the messages went away. The printer now works as it should. Must have been a bad cartridge.
Posted on Nov 11, 2008
SOURCE: Ink cartridge stops at the middle of my printer.
Problem : An error occurred while communicating
Afteryou install a print cartridge, the attention light begins to flash red.The printer will not print. One of the following messages may appear onthe control panel:
or the Printer stops Printing in the middle .
Cleaning the Still Rode on which the Cartridge Move, may solve your Problem
Check this Video - This may help you a Lot VIDEO
Check the following steps as well for connection steps .. and also the process of refilling the Ink to the Cartridge
* Color or Right Print Cartridge is not compatible
* Incorrect Print Cartridge(s)
* Print Cartridge Problem
* Incorrectly Installed Cartridge(s)
* Black or Color Cartridge(s) Failed
Solution :
Tosolve the problems related to Cartridge Errors we can do the following4 steps. Which could help us to get the issue resolved
Step 1: Remove, inspect, and reseat the problem cartridge
Step 2: Clean the problem cartridge contacts
Step 3: Repeat reseating and cleaning steps
Step 4. CONTACT TO HP SUPPORT
Step 1: Remove, inspect, and reseat the problem cartridge and Clean the problem cartridge contacts..
a) Make sure the printer is on. Press the Power button if it is not lit.
b) Open the printer cover, then wait until the print cartridge carriage is idle and silent
c) Press down lightly on the end of the problem cartridge to release it.
d) Slide the cartridge out and inspect it:
* Check the Copper electrical contacts (the Copper Part which touch the Connector inside)
* Clean it with the pirit or wet cotton)
* Check the Nozzles - Clean it with the worm wet cotton
* Wait for 2 to 5 min befour you connect them back
* Clean the contacts in the carriage, inside the product (Printer)
* Reinstall the cartridge.
* Reconnect the product to the electrical outlet.
* Close the product cover.
NOTE: you can also check the print cartridge label and make sure it iscompatible with your printer. Compatible print cartridges are listed inthe Printer Reference Guide supplied with your printer.
Note : If the cartridge is compatible, reinstall it in the printer:
* Cartridges marked with a triangle go into the left carriage slot.
* Cartridges marked with a square or pentagon go into the right carriage slot.
If issue not resolves Repeat repeating and cleaning steps
How do i refill my INK Cartridge ?
There are 2 distinct method
1) Black has a bladder
2) Color contains sponges - we need 3 sirenges with needle
to fill the Color cartridge with sponges - simply punch
COLOR CARTRIDGE
1. If you see the Cartridge turn it round and locate the filler holes by removing the plastic top cover of the cartridge.
You may need to pry plastic top or hole cover off using a thin metal blade.
please make sure that you do not damage the sensors on the back of the cartridge whilst doing this.
2.Using the picture(on the cartridge which shows you the 3 differedcolored spots), fill syringe with the corresponding color ink.
3. Insert the syringe into the correct hole of the color being filled and push all the way down.
Notes : You will feel resistance as there is a sponge inside.
So Slowly inject approximately 8ml of ink until you can just see the ink surface on the top of the sponge, any more and it is over-filled.
If this happens simply draw back on the syringe a little.
4. Rinse the syringe and needle thoroughly before proceeding then repeat the process for the other colors.
8. Re-attach the cover securely with adhesive tape and continue using the cartridge.
BLACK CARTRIDGE
1. Fill the syringe with approximately 20ml of black ink.
2.Push the syringe all the way into the filling hole and SLOWLY injectall the ink into the cartridge or until the reservoir is full.
3. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
4. If necessary leave cartridge in printer for up to 24 hours. (This allows ink to flow to the print head).
Posted on Jan 04, 2010
  • 96 Answers
SOURCE: the holder for the ink cartridge is broken. Do I
Buy a kodak for 99.00 and the ink is under 5 dollars
Posted on May 28, 2010
Ink cartridges will not move in place error # 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 - Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont...
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn't move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Jan 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
It wont print and everytime i try to print it says error #1200
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable2_bing.gif to reveal the gold screw beneath
7. Remove the ink cartridges2_bing.gif out of their carriage.
Figure 6 - Displays ink cartridge2_bing.gif carriage with ink cartridges removed.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
9. Lift the front cover open (if not already open) and plug in2_bing.gif the X4270. Cartridges should move to center as if preparing for replacement.
Click Here for the Documents
May 03, 2010 | Lexmark X4270 All-In-One InkJet Printer
Error 1203
Hi there
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted by LEH at 5:39 AM
Labels: Lexmark x
1 comments:
MarCrazy said...
Lexmark X4270 Error 1200 Fix - Use link below to see how to fix
Text version below use link above to see pdf with images.
5. Cont…
Apr 07, 2010 | Lexmark X4270 All-In-One InkJet Printer
I get a 1200 error when trying to fax
5. Remove the screws underneath the front cover (6 screws), back ofprinter (2 screws), and bottom of printer (1). View the images below tofind where to remove the screws.
5. Cont…
NOTICE: The ink cartridges are all the way to one end. If the X4270 isplugged in, the cartridge carrier is stuck and doesn’t move. Afterfurther investigation a noticeable small black plastic lever ispreventing the ink cartridges from moving. Photo below shows lever upand down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200.Image on left displays lever up. Image on right displays lever down.
9. Lift the front cover open (if not already open) and plug in theX4270. Cartridges should move to center as if preparing for replacement.
Note: The cause of this problem is the spring slides out of place overtime, probably because of ink shed on one end of its loop and loopattachment.
12. Place spring in loop attachment and use hot tip of heated toolto melt top of loop attachment to prevent further errors. Melt top ofloop attachment similar of that to a mushroom top.
Feb 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
The drum got loose because the one of the top drum springs got unhooked. The spring holder on the plastic drum cover is broken. It was noticed in time and turned off. So it seems that nothing else is...
will the plastic ring in the second ring move to the other ring . the danger is if you put the spring in the second ring the drum may not be line up straight when you look from the top (the motor may be further back) causing the motor and back to rub on the back plate when loaded might be better to drill new hole ?
Feb 11, 2010 | AEG Lavamat 88840 Front Load Washer
Cartridge error 1203
or
Labels: Lexmark x
1 comments:
MarCrazy said...
5. Cont…
February 27, 2010 10:27 AM
Feb 06, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error 1203
or
Labels: Lexmark x
1 comments:
MarCrazy said...
5. Cont…
Feb 02, 2010 | Lexmark X4270 All-In-One InkJet Printer
Cartridge error No. 1203 - LexmarkX7170 All-In-One
or
Labels: Lexmark x
1 comments:
MarCrazy said...
5. Cont…
13. Reattach the lever to the bottom assembly and slide back into place inside the X7170
15. Reassemble X7170 using steps 3-7.
Jan 21, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Putting in the ink cartridge
It is a little hard for words to be easier to follow than pictures, but I will try to help. The connection is not as "concrete" as you might be accustomed to with other equipment, a there is not a box-like holder to place the cartridge in. Below, the "head" of the cartridge is the end with the ink openings.
When you lift the printer cover and it locks into place, the cartridge holder will move to the far left side of the printer. The cartridge fits into the right side of the cartridge holder, and what you probably see in the diagram as a holder is actually a depiction of where the cartridge will end up when it is properly positioned. It actually attaches at the back - along the back side (the head) for the ink nozzles, and at the top of the back to a small piece that juts out and has a V-like projection downward that snaps onto the cartridge and holds it in place.
When you have taken the tape off, hold the cartridge with the head tilted slightlty upward, at about a 20 degree angle. (Be careful NOT to put the cartridge in with the head downward.) Using your left hand, your thumb would be just under the front outer edge (facing you), and your index finger on top. Slide it in slowly on the right side of the holder until the head comes in contact with the strip for the nozzles. At this point, the top should also be contacting the top piece referred to above, just behind the V-like downward projection.
Move your index finger to the top of the machine just above the back of the cartridge area, and use your thumb to lift the front (the side facing you) up until it clicks. You should feel/hear it snap into place. Then you can proceed to close the cover and go on with your use/setup of the machine. Hopefully this explanation will help you enough to be able to understand how to get the cartridge in, especially with the pictures to supplement.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 06, 2008 | Canon FAX-JX200
Hp Office jet print cartridge error
Remove the cartridge and look at the cartridge holder. There should be a spring sticking out from the right side of the holder. The spring on these often breaks loose and will not allow the cartridge to seat properly. (Look at the left holder and compare it to the right one. They should look alike.) If the spring is loose, meaning the holder is broken, the holder needs to be replaced. I've tried gluing the spring in place but did not have good luck with this.
Feb 20, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
