Question about Refrigerators
Changed the water filter on my Kenmore 596 50692000 model but now I there is no water flow. I have changed the filter before without a problem. What could be wrong. Someone mentioned that the line might have air that prevents the water flow. How can I fix this?
    Habit-Forming:
  • 76 Answers
You have clogged the water inlet solenoid valve. It is located in the water line and will need to be taken apart and cleaned or replaced. When you change a water filter you always need to bleed it into a bucket before attaching the outlet end to the water line, to evacuate all the carbon impurities.
Posted on Jun 23, 2009
Kenmore washer water not filling
there is a inline mesh filter at the tap end of the hose but it is more that likely that the tap washer need replacing
it is possible that the inlet solenoid valve is not operating properly
if you have separate hot and cold water hoses and taps then either tap should produce a full flow when set if no taps get a full slow when selected , indicates a problem power board
Nov 05, 2017 | Kenmore Washing Machines
Slow water flow
I would try the backwash as you suggest. Also, I had to run a few gallons of water through a new filter, for it to work properly..
Hope it helps.... good luck!
Jan 12, 2014 | Frigidaire Refrigerators
Jen Air Refrigerator (JCD2290HEW) developed problem with having low water flow at water dispenser and water hammer after changing water filter and depressing water dispenser to remove air. Have changed the...
I understand the correct manufacturers number for the PuriClean II water filter for your refrigerator should be UKF8001 or UKF8001AXX, that you have the correct filter, and you have plenty of water out of the dispenser when the filter is not installed. If all that information is accurate you have 30 pounds or more water pressure (although the minimum is 20 pounds the higher the pressure the better for flow will be), then I would try holding the filter under the faucet to be certain the water flows through the filter without a lot of resistance. If that checks out, I would look for a gasket or some other part from the old filter that is stuck in the filter housing.
Nov 03, 2013 | Jenn-Air Refrigerators
Water dispence slow
do you know if it is a whirlpool made model, 27ft french door, ice maker in ceiling, they had issues with a seal between ice compartment and ref side- leaks freezing air to water tank area, freezing tank. other wise if its not the filter -then water flow to unit. ck where it connects to ref, if good( should have steady stream with press. replace ref valve if bad look at your valve in wall or at sink.
Sep 14, 2012 | Kenmore Refrigerators
Fridge water filter replaced now flows very, very slow
Hi .. first I would try and eliminate the filter as the problem. Remove the filter and try the water again. If the water flows strong, then the filter is the problem. If the water stills sputters and is low flow, then there is a partial blockage in the internal tubing , or a problem with the supply. If you roll the fridge out to get at the suppl. you could shut it off and disconnect the supply tube from the fridge, then turn the water on slowly to check the flow at the supply. If the flow is good there , then the blockage is internal.
May 03, 2010 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore refrigerator-model#59582998 serial#514037483 I would like to operate my refrigerator without a filter due to the taste of the water by using filters. Is it permissable to remove the filter and not...
I would suggest , home depot , or , a hardware store , which supplys a filter , with replaceable cartridges . Usually runs about $ 50.00 . This filter , will mount to the wall , and not the appliance itself . If you " bypass " the filter , it may stop the dispensor flow , and / or , the ice maker water flow .
With the new filter , you can use , calcium filter , charcoal filter , or calcium filter replacements . Even lime , I believe , is available .
As far as removing the filter , I suggest , trying , to see if the water / ice maker still works , after removing .
Dec 15, 2009 | Kenmore Refrigerators
How do I know when the filter needs changed
water filters are usually see through, if you see dark brown, it should be replaced, if its been a couple of yrs
it should probably be replaced
Oct 10, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water dispenser won't stop dispensing water!
Hi I dont have the knowledge of your fridge, but I'm just going to throw this idea your way , please forgive me if im wrong :)
Perhaps the problem is due to syphonage, the discharged liquids are creating a vacuum along the line.
Did you reposition the height of any supply hoses ? none of them should be above/higher the outlet source itself.
You could also try installing a inline reverse flow suppressor
(small plastic filter that only allows one-way direction of flow.
Jun 10, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser reader not responding
no water flow is caused by the icemaker valve
on the back of the refrigerator
the water line is connected to it.
if it is stuck it will not let water through to the
icemaker
May 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have the opposite problem
You may have air in the system. When you actuate the dispenser it opens an electric valve in back to start the flow of water. When you release the dispenser air in the system expanding will cause the water to continue to flow until the pressure equalizes.
Refrigerators Logo
203 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
