Question about Seiko S149 Stopwatch/Printer
Paper will not feed or advance - Seiko S149 Stopwatch/Printer
How do I change date on my Invicta 7352 ?
Usually, after unscrewing a *****-down crown, pulling the stem out one click will allow the date to be advanced by turning the crown in one direction or the other. Depending on the movement, a clockwise turn of the crown may advance the date and the counter clockwise turn might advance the day of the week, for example.
If all else fails, pull the stem out two clicks and advance the watch hands 24 hours for each day you wish to advance the date.
Jan 13, 2015 | Invicta Signature II Series Watch 7300
I cannot set the time on a wr165
here's a simple instructions of setting your watch
Watch setup instructions
for the Armitron Instalite All-Sport :
Mode B / \ C Date
Light A \ / D Alarm
_____________________________________
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Press C again, Date flashes, press D to advance...... [suggestion from Chikita]]
Activating/Deactivating Hourly Chime
1. From "Normal Time Mode", press and hold "D" (Alarm) and
at the same time press "C" (Date) once. Hourly chime symbol,
( a house shape) appears in "chime" windows to indicate
the hourly chime will beep every hour.
Activatin/Deactivating Alarm
2. With "D" (Alarm) still pressed, press "C" (Date) again. Alarm symbol
( a clock shape with waves above it) appears in the
upper right to indicate the 24 hour alarm is now activated.
[I assume this "toggles" between off and on states,
so performing it again should turn off the alarm]
i hope this will help you.
Jul 22, 2011 | Armitron All Sport Digital watch
How do I set the time on my Pink armiton WR165 45-6967 watch?
  1. From Time Telling Mode, press 'A'.Seconds flash. Press 'C' to zero out seconds.
    NOTE: Zeroing out 30 or more seconds automatically adds one minute to time.
  2. Press 'B'. Hours flash. Press 'C' to advance the Hour.
    NOTE: Pressing and holding 'C' will advance digits rapidly.
  3. When 12 Hour Format is selected, 'PM' indicates 'p.m.' times; there is no indicator for 'a.m.' times.
  4. Press 'B'. Minutes flash. Press 'C' to advance the Minutes.
  5. Press 'B'. The Month flashes. Press 'C' to advance the Month.
  6. Press 'B'. The Date flashes. Press 'C' to advance the Date.
  7. Press 'B'. The Day of Week flashes.
  8. Press 'C' to advance the Day of the Week.
  9. Press 'A' to end set sequence and return to Time Telling Mode.
Mar 08, 2011 | Armitron Digital Sport #45/6967PNK Watch
Hi, My watch shows the day as i 1day in advance.For example if today is Monday it will show Tuesday. Though i can change teh time and date but not able to change the Day of the week. Cananyone...
THE SETTING FOR THE DAYS ARE AUTOMATIC DEPENDING ON THE YEAR YOU FEED. IT MAY SOUND ODD BUT PLEASE CHECK THE YEAR YOU ARE FEEDING I.E IS IT 2010 OR 2011. IF IT IS 2011 THE DAYS WILL BE ONE DAY ADVANCED. IF STILL THE PROBLEM PERSISTS ASK THE RETAILER /COMPANY TO REPLACE THE WATCH, IF IT IS UNDER WARRANTY PERIOD.
Dec 24, 2010 | Watches
Instructions for setting time & date of armitron watch 44/1001?
Nov 08, 2010 | Watches
Can't set the date or the day
the date was on the31st of in a 30 day month, I advanced the hands of the watch till it advanced the day to the 1st of next month it usually advances to the next day about 1:00 am, and date both the date and the day will advance together
Sep 30, 2009 | Bulova Watch
Anne Klein chronograph watch
The button advances the numeric day. After the numeric day is advanced one full month, the month dial advances to the next month. I just about got a blister pressing the button enough times to advance the month from January all the way around to December. Then I had to advance the numeric day to the current numeric day. The previous person told you by turning the dial 24 hours you can advance the alphabetic day of the week by one day (Sun, Mon,etc.).
Sep 04, 2008 | Casio G-Shock G7100D-1V Wrist Watch
Ultrak 499 printer
yes I still needed help on my Ultrak 499 printer
Feb 05, 2008 | Ultrak 499 Professional Stopwatch with...
Seiko S149 Stopwatch/Printer Logo
Top Seiko Watches Experts
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
