Question about Craftsman Garden
Where can I get a Repair manual for Craftsman 358.764960 blower?
How do I change the fuel lines on the 358.764960 blower/vac?
rwvanlue
  • 486 Answers
SOURCE: Need a repair manual 2c Craftsman Gasoline Powered
the numbers you have provided do not come up under Sears Parts look up. Can you double check please.
When you have double check you can go to
http://www.searspartsdirect.com/partsdirect/index.action
see if this helps locate what you need
Posted on Nov 21, 2009
rotorcrafts
  • 302 Answers
SOURCE: Craftsman 2 cycle blower stalls.
Most Probably the problem lies in the adjustment of the carburettor. There are two needles in the carb one for lowend adjustment and one for high end adjustment. Your lowend adjustment seems fine. The highend needle needs to be adjusted. Following are some very detailed procedures for adjusting these types of carbs
http://tech.flygsw.org/walbro_tuneup.htm
http://www.drystacked.com/Walbro%20Carburetor%20Theory%20ebook1.pdf
If your machine has a carb other than a "Walbro" dont worry the procedures are same. I am sure if your engine has not completed its life span this will solve your problem.
Posted on May 19, 2010
  • 885 Answers
SOURCE: I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
Posted on Nov 02, 2010
  • 458 Answers
SOURCE: The assy-fuel pick-up on my Craftsman 25cc 200MPH Blower/Vac Model No. 358.797550 has come of and loose in gas tank. How do I repair it?
Mine did the same thing,also sucked trash into the carb.You will have to get the weighted pickup/filter out of the tank(long needle nose pliers or a parts grabber claw).The hose is long enough to pull it out of the fill cap.Cut the end off as straight as possible,and remove the broken line from the filter.Push the line back on,and drop the filter back in the tank.
Posted on Jun 14, 2012
hunter19_46m
  • 7482 Answers
SOURCE: Need a diagram for replacement of fuel line on a blower/vac model # 358.798980
Hi jfkunz
I think this is what you are looking for.
Please rate me
Bud
Posted on Oct 13, 2012
Where can I find a Diagram for a craftsman blower/vac carbuerator
Go to searspartsdirect.com and enter the model number and it will give you a diagram for the carb. Hope this helps.
Aug 13, 2014 | Craftsman 4 Cycle Blower/Vac
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Hi jfkunz
Please rate me
Bud
Oct 12, 2012 | Craftsman Garden
Both lines from carb. are cracked..358.797550 craftsman blower/vac how hard is it to replace the 2 lines and I know one is for fuel, what is the other line for and where does it connect to from the carb. ...
Thin line is the fuel intake and is attached to the fuel filter. The other is the return, and should be placed on the tube below the primer bulb of the carburetor.
Sep 13, 2011 | Craftsman 4 Cycle Blower/Vac
I need fuel lines for craftsman 358.797290 leaf blower
Whenever I cant find the exact stuff I need, try a local motorcycle shop. The fuel lines and such are very similar, often times you will end up with a higher quality fuel line for a few pennies more. Hope it helps!
Jun 22, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman leaf blower
Hi
Check the fuel lines,fuel filter and clean the fuel tank.Disassembly the carb and clean it carefully.Diafragm type carb has a fuelpump,pay attention to it ,has to be tighten not folded.When the engine gets warm ,the fuelpump cannot keep the right proportion of fuel and the air/fuel mixture is changing.It has to be changed.
regards savumihai71
Nov 09, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
