Question about AOpen F2705 17" LCD Monitor
Aopen F2705 LCD MOnitor driver - AOpen F2705 17" LCD Monitor
Aopen monitor
driver not usually required; what model?
You wont get a response without a model number, this is your 2nd post
May 14, 2014 | AOpen F2705 17" LCD Monitor
Monitor will not come on
The problem is in the power supply board, one or two capacitors become open and sometimes leave a slight puff on the top killing power to the monitor.
Mar 16, 2012 | AOpen F2705 17" LCD Monitor
Monitor won't display. Everything is plugged in and power is on
Might not getting any signal from the source ,you will have to try your cpu else where with same vga cable to figure out whether its your monitor or your cpu tower.
Sep 02, 2011 | AOpen F2705 17" LCD Monitor
I recently got a new Computer machine on Windows 7, but I have kept my AOpen F205-12S Monitor. Unfortunately for some reason the resolution cannot go to the monitor's maximum. It stays on 1024 x 768 and I...
go to control panel ,display, monitor , move the slide for pixels , apply and ok
if you want bigger , there is a tick box as well 100%,150%
adjust that as well
Apr 27, 2017 | AOpen F2705 17" LCD Monitor
No signal
A number of things can cause "No Signal" on a monitor
1) Check the cable between the monitor and PC is properly connected
2) If the PC has more than one display port try changing the display port the monitor is plugged into
3) Try an alternative cable between the monitor and the PC
4) Check that the correct input is selected on the monitor
Dec 16, 2010 | AOpen F2705 17" LCD Monitor
Will my monitor work with the new windows 7 operating system?
Yes your monitor will work with windows 7 it has a generic driver for monitors installed into the system.
If your monitor has a driver cd for it, for more cababilities found on the monitor you may have to visit there web site for updates. Other than that your monitor should work fine with no problems.
Mar 23, 2010 | AOpen F2705 17" LCD Monitor
Is there a fuse? My monitor will not power up
yes there is. maybe blowned. test if it have continuity, if bad, change it. if its still the same your problem its other.
Nov 03, 2009 | AOpen F2705 17" LCD Monitor
Monitor goes black as if the light went out.
bad lamps you may check your monitor ccfl maybe or the inverter.
Nov 19, 2008 | AOpen F2705 17" LCD Monitor
AOpen F2705 17" LCD Monitor Logo
54 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
