Question about RCA (DTA800B1) Video Converter
DTA800B1 remote won't allow me to use menus, how do I reprogram?
I turned off RCA converter box, when I turned it on again the only thing it does is change channels and auto powers off after 4 hrs. I can't access menus, mute, or CC any more. How can I reprogram the remote. The manual doesn't explain this issue as far as I could see.
rcirone203
  • 70 Answers
SOURCE: RCA Converter auto shut down on TV with NO RCA Converter attached
You should check with the translator system. Sounds like it is on there end.
Posted on Jul 16, 2009
SOURCE: RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Posted on Aug 12, 2009
wayneard
  • 1901 Answers
SOURCE: My Magnavox tb110mw9a converter loses programming randomly.
Badge #7067 is giving you a load of bunk. I have had one for 8 months and the only time I have reprogrammed it was when all TV was to go digital. Even when our power goes out the converter remains programmed.
I would keep calling back. Chances of getting the same guy is slim. Insist on a replacement.
You can also go online at http://www.funai-corp.com
Wayne
Posted on Sep 08, 2009
  • 4 Answers
SOURCE: how do u program it so u can control the volumn
No. I'm need TV cart install. Help me.
Posted on Mar 04, 2010
SOURCE: Magnavox converter box TB110MW9 shuts off repeatedly
Hi All,
Apparently, all of these devices do that, including mine. Magnavox is a Philips brand, and they have a long history of getting bad management in the way of otherwise good engineering. Having been an engineer at Philips, here is the solution (believe it or not, it worked for my converter): (a) disable the 'automatic shutdown' option in the menu. (b) unplug it. (c) drop it on the floor (but be slightly more gentle than the Dutch in the soccer final). (d) repeat until problem fixed. Took me three tries, now it works like a charm.
Posted on Aug 11, 2010
Can the rca dta880 record without the remote
Unfortunately, the RCA DTA800 does not allow you to access the record functions without the remote. You can change channels and turn the converter box on and off from the unit's front panel. However, you may be able to get a replacement remote from the manufacturer here: https://rcaav.com/shop/video-remotes/ . Replacement remotes are $10. Click on the select options button then choose Home Video and the model number in the two drop down menus.
Before you order though, check which version of the digital converter box you have. The available remote is for the DTA800B1. An alternative option is to find a universal remote that has codes for converter boxes. (This is a rare feature though. You'd need to check the code finder/code lists for that remote.)
I hope this helps.
Apr 02, 2017 | RCA Televison & Video
Channel change buttons on the TV set will only go to 44 and 50 I need 03 for converter box.
If you cannot change the rf frequency on the tv set to 03 or 04, there is no way you can get the converter box to work with that set..
Sorry.
Apr 18, 2015 | RCA Televison & Video
I have an rca converter box model number DTA800B1. I unpluggd it briefly and now don't have the code toprogram it
DirectTV remote model Rc64 will control the RCA model DTA8001B1 digital receiver. Set the remote's switch to unused AV1 or AV2 position, simultaneously press and hold mute and select buttons until indicator gives a double flash and immediately enter code number 00392 after which the indicator will double flash in acceptance. Works menu and it's navigation, channel up and down, and numerical keypad.
Mar 12, 2015 | RCA (DTA800B1) Video Converter
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
Sep 17, 2011 | RCA Televison & Video
Have an rca digital converter box model dta800b1 and a phillips universal remote can i program it so my box get the channels
Find the user guide for your universal remote and use the RCA cable tv/satellite codes, and one should work for your RCA DTA800B1 converter box. My Sharp Aquos remote liked the RCA satellite code.
Jun 04, 2010 | Televison & Video
Lost codes for RCA DTA800B1 converter box
rca converter box syvania tv codes please thank you robert
Feb 01, 2009 | RCA Universal Remote Control
RCA (DTA800B1) Video Converter Logo
60 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
