Question about Acer Aspire Computers & Internet
Remove battery from motherboard - Aspire Acer Computers & Internet
    Top Expert:
  • Acer Master
  • 5,149 Answers
You will need to open it up todo that
Posted on Mar 29, 2015
Were is cmos battery located
removing cmos battery doesnt work no matter how long you leave cmos battery out been there done that , you have to locate cmos jumper on motherboard , remove main battery & memory cards , peel back clearish foil on motherboard near where memory cards install , should see jumper points on motherboard , take bread tie touch jumper contact leave main battery out stand up like book plug in power adapter , and turn on only until boot screen then shut-off , install memory card , remove jumper and try starting laptop , if it hasnt cleared password , remove memory cards and try jumping it again
Mar 07, 2014 | Acer 4220-2346 Notebook
How do i remove or reset the bios password on an acer aspire 5741
The only way to reset your bios password is to remove your cmos battery. It is a small battery found attached to your motherboard. Most cmos battery is like button cell like this akshay163.gif
If you cannot locate your cmos battery then refer your motherboard manual. If you're computer is using a coin cell battery similar to the above example picture. Removing the battery is relatively simple. use your fingers to grab on the edge of the battery and pull it up and out of the container holding it. Some motherboards have a clip holding the battery down. If your computer has this clip you may need to use one had to move the clip up and the other hand to pull the battery out.
Unfortunately, not all CMOS batteries are removable; some manufactures will only allow a replacement battery to be added. If you're not using a coin cell battery and are not able to determine how to remove it refer to your motherboard or computer documentation for additional assistance in removing the battery or how to insert a new replacement battery.
After removing the battery then replace it.
Your bios password should now have been reset.
Good Luck
Jul 11, 2011 | Acer Computers & Internet
Hi how to reset the bios password of cc820 intel motherboard. i removed the battery but it didnt work.
Removing the BIOS battery for a short period will not normally work. Try removing it for 20 mins before inserting the battery back.
Apr 26, 2011 | Intel Desktop Board CC820 (KCC820PAK10)...
I want to my bioes reset.how?
take off the battery and turn on computer then turn off , back the battery to its place again and turn your computer on , it will be reset
if you see that is helpful please don't forget to vote me
best regards
Apr 25, 2011 | Intel D945GCLF Motherboard
Hello, Is it possible to reset the BIOS without removing the battery? The battery is on the other side of the motherboard.
If you have attempted to change something in your BIOS so you cannot alter or change any settings because the computer won't boot up properly, unless you have a CMOS reset button on your motherboard the only other way if you can't get into BIOS is to remove the CMOS battery, the CMOS battery is never on the otherside of the motherboard because all the connectors are always on one side of a motherboard
the CMOS battery is a silver flat battery, much like a thing watch battery, remove this battery for 15 seconds so there is no residual power left in the motherboard and then reinsert and reboot your computer
if you can get into BIOS there should be a restore to factory defaults settings in there somewhere.
Mar 20, 2011 | Jetway Mini-TOP HBJC600C99-52W-BW Intel...
I want to reset bios password of My Asus TUV4X, because I forgot the pasword instead.
remove all power from the motherboard. then remove the round back up battery from the circuit board. if the battery has a metal clicp on top it's best to gently slide a piece of paper between the arm and the battery as those clips are easy to break. some motherboards actually have a jumper you move to another position to accomplish this. i do not have the manual so this is the next best bet. wait about ten to fifteen minutes before removing the piece of paper and reapplying power. the password should be removed.
p.s. don't count on this working on a dell system
Sep 28, 2010 | ASUS TUV4X (TUV4X/533/PA/6P-UAY)...
D850MV Motherboard: Hi, I have HCL P21 PDC Laptop and it has been l...
just remove the battery place inside not your normal battery its fitted in your motherboard remove battery for 10 mins place it again .....wow cmos is rset and no passowrds or jutdownload hiren boot cd
May 17, 2010 | Intel D850MV Motherboard
I need bios 4 dell latitude c610
If you can't find the jumper to flash the BIOS or if such jumper doesn't exist, you can remove the battery that keeps the BIOS memory alive. It's a button-size battery somewhere on the motherboard (on elder computers the battery could be a small, typically blue, cylinder soldered to the motherboard, but usually has a jumper on its side to disconnect it, otherwise you'll have to unsolder it and then solder it back). Take it away for 15-30 minutes or more, then put it back and the data contained into the BIOS memory should be volatilized. I'd suggest you to remove it for about one hour to be sure, because if you put it back when the data aren't erased yet you'll have to wait more time, as you've never removed it. If at first it doesn't work, try to remove the battery overnight.
Important note: in laptop and notebooks you don't have to remove the computer's power batteries (which would be useless), but you should open your computer and remove the CMOS battery from the motherboard.
Jan 15, 2009 | Dell (0Y4801) for Inpsiron 600M, Latitude...
Pvm 800 moterboard bios
some motherboards will switch on and run after removing the cmos battery also but in some motherboards it is not possible it depends on the manufacture design ...
try changing the cmos battery with the new one that cmos battery might have lost it s power ...
after that also if you face the same problem then there may be some dust particles accumulating in the processor fan due to that it might not be able start clean them and refit and try it ....
if you still face the same problem then if you are using UPS then remove the connection from that and give the direct connection this may solve your problem if there is some problem in the UPS battery ....
any doubts you can reply me
regards
-Dileep
Nov 07, 2008 | Intel Motherboard
Startup problems
Have you considered it could be the battery has died. Have you tried external power? If the battery is OK then check the battery contacts to make sure they are clean. Has your power supply died and it won't power the laptop or charge the battery? It could be the motherboard but I'd put my money on it's power supply or battery. Without more details being supplied.
Jul 20, 2006 | HP Compaq Motherboard
Computers & Internet Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
