Loud clacking sound from the washing machine as spin cycle starts
Loud clacking sound from the washing machine as the spin and rinse cycle starts. There is also evidence of a burning smell. The machine washes ok but cant spin to empty the machine of water. Dont think its the water pump as this makes a differnert sound and i fixed that last year. Any thoughts??
    President:
  • 744 Answers
Yes you either have a whirlpool or kenmore...since you didnt mention the make I guessed :) It sounds like you have a bad coupling, have included a link giving you instructions for replacing the coupling and a link where you can buy the coupling.
http://www.thisoldappliance.com/howto/Motor_Coupling.htm
p.s you don't actually have to remove the cabinet, the motor, pump and coupling can be accessed by tilting the machine back and wedging something under it so it does not fall on you while your working on it.
you can purchase the part from:
http://www.appliancepartspros.com/part_details.aspx?part_id=3963893
Hope this helps.
Posted on Jun 23, 2009
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
Free service repair manual
Bad transmission (gearcase). broken connector rod inside unit is causing noise. also causes slow spin and drain. unit will usually be trying to agitate as it spins. Replace transmission.
Jan 26, 2018 | Whirlpool Washing Machines
Spin cycle in the washer just started making a loud clacking sound. It also seems to stop much more abruptly than it did before. Seems like something may be rubbing, but spin speed still seems good
i think it is like u havent got the lip down propley i used to have washing maschine like and it made that exact noise what i did was remome less clothes and just give it a kick with ur foot
Jan 13, 2013 | Washing Machines
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Rinse cycle does not work on washing machine
Sounds like a belt or clutch issue. What is the make and model #?
Nov 02, 2017 | Kenmore Washing Machines
Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I own a Maytag Performa 4 Speed/24 cycle Washing machine. it is 4 years old. Problem: A very LOUD grinding sound when washer engages into wash, rinse, spin cycles. The Tub does agitate - but I don't...
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
Jul 11, 2008 | Maytag Washing Machines
Washing Machines Logo
289 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
