Question about Pool & Spa
Starite sr400lp runs fine no errors, however water to pool is not hot, or barely warm
Hello all I have sta-rite sr400lp heater, it runs fine with one exception the water going into pool is not hot, it is barely warm, so i am wasting fuel trying to heat the pool. I have no error lights, codes or anything suggesting ANY problems. anyone have any thoughts? help is most appreciated. Joe
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Soulds like maual bypass is stuck letting too much water flow through heater and doesnt have enough time to heat it the spring is probably stuck
Posted on Jun 10, 2014
5 Suggested Answers
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
jharwell668
  • 640 Answers
SOURCE: sta rite pool heater error r=5?
The users manual for these pool heaters has a chart that walks you through, step by step, a troubleshooting guide. That is the best way to find a solution to your problem because it asks pretty specific questions that you have to be looking at your heater to answer. Here is a link to the pdf file.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Posted on Aug 16, 2010
jharwell668
  • 640 Answers
SOURCE: Sta-Rite Max-e-Therm pool heater shows error code
These pool heaters have a detailed users manual that has a great troubleshooting guide. I would try there first. They ask alot of questions that you have to be looking at the heater to answer. Here is a link to an online version.
  • 5 Answers
SOURCE: I have a e05 error
check the sensor that is on the exaust
Posted on Sep 09, 2010
Starite sr400lp runs fine ,no errors however water to pool is not hot or even barely warm
With heater running put your hand by the exhaust and see if the air being expelled is hot. It will be if heater is producing heat. Depending on the size of the pool this heater can take some time to heat the water.
May 11, 2014 | Pool & Spa
Water barely lukewarm
is the heater running ? did u raise the temperature higher that the existing water temperature in pool ? are u running the pool pump long enough to achieve the temperature that you want ? IF CHECK (OK) 1- check the internal flow valve control is located between the cold and hot water little black cap, check the condition ,make sure no calcium deposit build inside, 2-is the water temperature in the heater is the same as the pool temperature ? is the pump got full prime with no air ? is the filter is clean ? is this heater propane or natural gas ?
Jun 12, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
Water Isnt Getting Hot
Could be that the plumbing got clogged while the system was idle
May 13, 2013 | Sta Rite Pool & Spa
Replaced flue stack sensor still have code e05 starite sr400lp
ignition turn off reset unit check safety circuit then gas pressure if overheated if ok check for cobwebs if burn tubes possible fenwal overheated if no voltage to ignitor
Mar 09, 2013 | Sta Rite Maxi Therm 400k Btu Propane...
What does R* mean
Where is this "R" if it is the one in the model SR400LP That is Rite, SR Sta-Rite, 400 is btu's in thousands, LP is liquid petrouliem or propane.
Jun 24, 2010 | Sta Rite SR400LP Max E Therm Pool Spa...
Pool & Spa Logo
60 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
