Question about Ariens 21 In Classic Walk Behind Push Lawn Mower ()
How to replace an ariens 21 lawn mower cord
Replace pull cord
5 Suggested Answers
  • 391 Answers
SOURCE: kids broke pull cord
Remove the entire housing and do not drill the rivets unless you can replace them with the same size.
Posted on Jun 07, 2010
SOURCE: need owners manual
http://www.ariens.com/corporate/pages/customerservice.aspx
Posted on Jul 18, 2010
philwalker78
  • 605 Answers
SOURCE: i need to know what type of oil to add to my
Hi, if it has a Briggs and Stratton engine you need sae 30 engine oil. Regards Phil.
Posted on May 01, 2011
jdhnmi
  • 143 Answers
SOURCE: hello, I have a ariens kw
you need to clean your carbourator out i have a couple of post on it look at some of my other post on repairing the carb you could have to get a repair kit with new gaskets for the carb i have at least three or four fixes for this with a little more instruction
Posted on May 02, 2011
Pull cord broke of mower starter
Go buy part at Home Depot or wherever. Remove top cover. Remove pull cord housing. Install new pull cord housing. Replace cover.
Oct 09, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Model #911503 ,serial #000278 The pull
Here a couple of links with instructions on replacing your rope... Text Good Luck
Jul 03, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Pulled the cord out of the mower trying to get it back.
you have to remove the top of the mower and you may need to buy a new spring depending if it broke or not, then wind the spring up and slide the rope back through the holes and tie a knont in the rope and let the spring wind the rope back in. reassemble the top on to the engine.
Jun 16, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Have never used the lawnmower and the pull cord seems locked or stuck. I can't pull it at all. Is there a button or lever that needs to be pushed before intial use of machine?
There is a brake lever that stops the motor and blade when it is released. This is usually parallel to the handle and would normally be squeezed against the handle when you operate the mower. When released, it is a safety mechanism to immediately stop the spinning blade. You have to squeeze that lever in order to start or run the mower. You can see that lever in the image at the top of your question. Good luck, Al K
May 22, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
I need to know what type of oil to add to my ariens a173k22 lawn mower
Apr 30, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Problem: How to start the mower (Ariens A173K22). The mower sat all winter. I have gassed it up and checked the oil. Pulled the cord. Nothing happens. I bought the mower new in the fall and used it...
For initial start up, I suggest removing the air filter off of the intake to the carburetor. Then get an aerosol spray can of carburetor/choke cleaner at auto parts store or Walmart. Your next step is to open the choke and the throttle of the mower and spray a couple shots into the carburetor throat. Then, choke the carburetor and immediately pull the starter cord.If it fails to attempt to run, repeat the process. I would get your manual, but I need the serial number off of the mower. You provided the model number, try to find the serial number and input that info here to download a manual. I think you can order a printed one from here as well.
http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=0.20814049373188065&Site=ARIENSS
Apr 13, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
What spark plug is needed for an Ariens 21 lawn mower
spark plug.
21543600 (911160,161,162,163,164,165)
21540800 (911133,134)
hope this helps.
Aug 13, 2010 | Ariens 21 In Classic Walk Behind Push Lawn...
Kids broke pull cord
Jun 07, 2010 | Ariens 21 In Classic Walk Behind Push Lawn...
''ariens 21'' self going -or need mix petrol and oil?
you shouldnt need a petrol oil mix in the tank on a lawn mower
May 08, 2010 | Ariens 21 In Classic Walk Behind Push Lawn...
Ariens 21 In Classic Walk Behind Push Lawn Mower () Logo
49 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
