Question about Powr Flite Vacuums
I cannot load the sand paper?
Need instructions for loading the sandpaper
How do I load the vacuum bag in the Electrolux power plus 2000w
If your Electrolux vacuum cleaner uses paper bags, the instructions should be printed on the bag.
Dec 03, 2014 | Electrolux Vacuums
The floor head is no longer working. The canister works, there is suction, but the floor head is dead. No lights, suction control switch inoperable, no headlight, nothing. It just stopped one day during...
Hi poohbear4760...
Check your wiring going to the vacuum head, some vacuums have a problem with corrosion on the plugs...take your connections loose and lightly sand with fine grit sandpaper the metal ends.
Plug the wires back together and see if it works...if not then it may be that you have a faulty motor in the drive head.
Please take time to rate me
Sep 04, 2011 | Vacuums
We have a new pink steamglide iron Model No18160. The sole has a stain which I cannot clean. The instructions recommend using vinagar which I tried and which did not help. Can you help advice?
There are many products on the market which can be used to clean stubborn stains from the iron sole.
However, for realy stubborn problems I would use very fine sandpaper with a grit of aproximately 1200.
With a fair amount of rubbing or sanding it should be possible to remove any stain or mark from the bottom of the iron & provided you use a very fine sandpaper it wont leave any scratches.
Best wishes,
Graeme.
Mar 22, 2011 | Vacuums
I have a white B&D toaster oven. Something burned in the oven and the smoke came out the door and scorched the white part above the door. What's a good way to get rid of the stain.
you need to sand that stain down with sandpaper and then re-paint the area with a high temperature paint......hardware stores should sell it....it's trade name is called...."mr. touch up"......it is speciffically made for microwave ovens but is also very good for your oven.....the paint must be high temperature type since your oven is high temperature.....good luck
Dec 04, 2010 | Black & Decker Vacuums
What's the best way, if any, to clean the carbon deposit on the E Series armature?
Use a scouring pad, or emory cloth. Do not use sand paper, or a wire brush. That will cause too deep of scratches, plus you may get sand in the motor components, or damage sealed coil wires, and ruin your motor.
Let me know if you have any more questions,
Ralph
Aug 03, 2010 | Rainbow 75th Anniversary Canister Vacuum
Loaded with soapand water but nthing happened. lost instructions, might be forgetting something
If the soap and water is not coming out that means that you need to replace the pump belt. Here is a link to the belt you need and the a manual you can view:
Bissell 1697-7 Belt and Manual
Mar 02, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
I have a new steam vac power max without instructions I need to know how to operate it
Hiyas ive found you an online downloadable manual go to this site and after its loaded look where it says product manual and click on that then click on the product manual again and it should open a new window showing the manual, when this window is fully loaded click on the disk top left to save a copy to your computer for printing
http://home-solutions.hsn.com/hoover-12-amp-steamvac-powermax-carpet-cleaner_p-2750224_xp.aspx
Jul 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell pro heat advantage 12 amp
You can download the instruction manual at the Bissell.com web site.
Jun 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to attach sand paper to the Kirby Turbo Sander attachment?
There is a plastic guard around the edges that comes off. Then, there are clamps that hold each end of the sandpaper. If you can't see the clips, then the guard is still on and needs to be removed. Hope this helps...
Marci
Jun 23, 2008 | Kirby G5 Bagged Upright Vacuum
I need a user manual for S30.
Try going to the manufactors site, if it available, you can down load it from there.
Apr 18, 2008 | Vacuums
Vacuums Logo
12 people viewed this question
Top Powr Flite Vacuums Experts
JoeVacs
Are you a Powr Flite Vacuum Expert? Answer questions, earn points and help others
