How do I get iTunes on the surface - Computers & Internet
When i plug my ipod on to itunes it wont show up
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue.
Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> http://www.itunes.com/ b> http://www.apple.com/support b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page Apple.com and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
Jan 29, 2013 | Apple iPod touch Second Gen (8 GB,...
Tip
Ipod problems? start with these 5 solutions!!!!!
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If that doesn't solve the problem lets try another USB port
connect your iPod with a different USB port to your computer, not a USB port on your keyboard or hub.
If that doesn't solve the problem lets try restarting your pc and also make sure you have the latest itunes installed
you can get the newest itunes from
www.apple.com/itunes/download
If that doesn't solve the problem lets try reinstalling itunes, skip this if you just installed the newest version from the link I gave.
And the last thing to try is a restore
Restore
  • Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your itunes Library.
How to restore your iPod:
For Windows:
  • 1. Make sure you've reinstalled the latest version of itunes.
  • 2. Open itunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in itunes.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main itunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt itunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, itunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the itunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
on May 01, 2008 | Apple iPod MP3 Player
My ipod wont show up on the bar when i plug it in the itunes
Need to reset my ipod touch to factory settings
1. Plug your iPod 4G into your computer with its dock connector USB cable.
2. Install the most recent version of iTunes and open iTunes. Wait a moment for your iPod to appear in the side bar.
3. Click on your iPod in the side bar and select "Restore." A pop-up window will ask if you're sure you want to clear your iPod and restore to factory settings. Click "Continue" and enter your password, if prompted.
4. Leave the iPod untouched and on a flat surface while it restores to original settings. It's important that you don't try to disconnect or use the iPod while it's restoring. You'll see a progress bar either on the iPod or your computer that indicates how far along the process is.
5. Select your new syncing settings (automatic sync or manual) when prompted after the restore is complete.
Aug 07, 2012 | DisegnoShop Computers & Internet
My apple ipad wont charge or turn on
With iPad Magic, you can transfer photos, videos, music, books, etc. between iPad, iTunes and computer at ease. Moreover, it also enables you to convert audio and video files, rip CD and DVD discs, download online videos, make ringtones and more. Also, it works well on iOS 7 and iTunes 11.
http://www.youtube.com/watch?v=8ALYybIAL3k
Supported iOS Devices:
iPad, iPad 2, The New iPad, iPad mini, iPad with Retina display;
iPhone 3G/3GS, iPhone 4/4S, iPhone 5, iPhone 5C, iPhone 5S
Apr 25, 2012 | Apple Tablets & eReaders
I bought some tunes on itunes and tried to download on my nano ipod. They not only did not download, but my ipod is now stuck in the connected mode. What do I do?
Do a hard restart on the evice.
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Now connect it to iTunes. Select sync. To see if the songs did transfer, you can see whats on the device in iTunes before disconnecting it by looking at the device under itunes.
Mar 10, 2010 | Apple Computers & Internet
My computer crashed and I had to reinstall my DVDXCOPY express. I need to reactive but there is a broken link. what to do?
321 Studios first released DVD X Copy in 2003 and the company was takento court by several major studios and in February was ruled illegal bya judge. Subsequently, 321 Studios closed down and all their DVDcopying software was taken off the shelves (although some retailerscontinued selling the remaing inventory) leaving people (who haslicense copy of the software) in frustrations because they can notactivate and use the software. There is no way you can activate thesoftware now because their website no longer exist.
You may try phone activation and use the following codes:
321 Studios DVD Copy Plus v4.2.0
(Phone Activation) ID:3403029
Password: plonker
User Code 1: 282-783-539
User Code 2: 930-0068
License ID: 98709870
Activation Code: 3403029
321 studios DVD X Copy Platinum v4.0.3.8
Turn the date back to November 11th 2003.
License ID: 780658488
Phone Activation
Password: 306368780
Resulting Activation Code: 17753627
321Studios DVDXCopy Platinum v3.2.1
Phone Activation Pass: 306368780
Code1: 11111 11111 11111
Code2: 11111 11111
License ID: 416481996
SN: 85153891
Let me know if you need further assistance.
Feb 06, 2010 | 321studios 321 Studios DVD X Copy (Backup,...
Not syncronizing
Does the ipod show up in itunes? If not, can you see your (safely remove hardware) icon in the lower right hand of windows when your ipod is connected? If still a no, I would check to see if the ipod says (charging) or (connected do not disconnect)
If the ipod does not connect to the computer at all, I would first try to reset it. I have posted a step by step below just in case you are unsure how that is done.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If after a reset, You still cannot get the ipod to sync or show up in itunes; I would recommend putting the ipod into disc mode to see if that will allow it to work with the itunes. If in disc mode the ipod finally shows up in itunes, (provided the above steps did not help) you will need to restore. Below i have done as before and added information on both putting the ipod into disc mode as well as restoring.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Putting iPods with a Click Wheel into disk mode Before placing the iPod into disk mode, you should verify that it is charged. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
Before a restore, you should make sure your itunes software is up to date as well.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
I hope this resolves your issue. If you need further assistance, please let me know
Apr 30, 2009 | Apple iPod nano
My Computer and iTunes does not recognize my iPod
If your ipod is not recognized by either the computer or itunes try putting the ipod into disc mode and reconnecting the ipod.
Make sure you have the latest version of itunes by opening itunes and in the top tool bar click on Help; you will then click on About itunes. If it is not itunes 8, you will need to update that first.
Here are the steps to putting an ipod into disc mode...
Once you have gotten the ipod into disc mode go ahead and connect it to the computer. It should show up in itunes at this point. So long as it does you will want to restore it, and just in case your not sure as to how to do that here are the steps for that as well...
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option 3: Use Newest Version - Restores with the latest iPod Software available. Restore Option 4: Restore and Update - Restores with the latest iPod Software available. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models). Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models). During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
After completing the restore process, eject the ipod and disconnect it. Reconnect it and see if it shows up normally again. I hope this resolves your issue :) CHEERS
Apr 23, 2009 | Apple iPod mini M9160LL/A MP3 Player
Ipod won't sync with itunes on windows operating system
An iPod formatted to a mac will not sync with a PC. (I'm not sure why the rep told you it should) However an iPod that is formatted for a PC can be used with both the mac and PC hardware. The only difference you should notice when using with your mac is that it will load slightly slower, and it will not be able to be updated on the mac. To reformat it simply restore using itunes. If it will not show up in itunes at all then you will want to place the iPod into disc mode before connecting to the computer. Below I have posted a step by step on getting the iPod into disc mode as well as restoring just in case you need the information. :)
Having your antivirus active during an iTunes installation can in fact cause download errors though. If you do not have iTunes version 8.1.1.10 you will need to update your software before proceeding. If you are unsure on how to check, simply open iTunes and click on Help in the top toolbar. then select about iTunes. This will tell you what version you are running.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If this does not resolve your issue please do let me now. I am eager to be of assistance
Feb 20, 2009 | Apple iPod nano
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
