Question about Garden
Shifter assembly was broken and tiller was taken to a dealer repair shop. When it was returned the engine would stall when you tried to engage it into either forward or reverse. Shop tried again. Same problem. I have pulled the transmission apart and discovered that the spring detent and ball detent was missing from the assembly. The parts diagram shows the spring going into the cluthch cololar first followed by the ball with notheing to hold those parts in the collar. Seems like the ball should be next to the shaft and something has to hold them in the bore in the collar.
  • kenharmon Jun 23, 2009
    I am working on a rear tine tiller, not a mower. It is a 410 series transmission which is obsolete now. Partstree diagrams merely duplicate the service manual I already have in front of me. MTD tech support has the same set of drawings and apparently the guy that designed the gear box is either dead or no longer working there. Please re read the question and try again.
    Thanks.
  • kenharmon Jun 24, 2009
    What will keep the ball and spring in the bore hole of the clutch collar. As the shaft spins it seems it would throw both ball and spring out.
  • 3,600 Answers
Gravity keeps it in place and the ball should be against the shift rail and the spring pushing it into the shift rail.
Posted on Jun 24, 2009
  • 520 Answers
The only diagram I can find of the one I think you are talking about is very scetchy. It showes the shaft but the spring and ball look backwards. And there should be an indention in the shaft. Try reversing there procedure and see if this works. Please post to me and let me know.
Posted on Jun 23, 2009
  • 10,515 Answers
You can View a Breakdown of this Mower at this Addy http://www.partstree.net/parts.asp and Click Parts Look up Box. Then Select the OEM(MTD) and enter the Model Number. Then Double Click on the Model in the Search Results Area. This will Open a New Window Showing the Different Sections of the Mower. Is the Key for the Transaxle Pulley Good? Is the Pulley Worn on the Inside, Allowing the Pulley to Jump Over the Key? Is the Variable Speed Pulley Moving Freely? Check the Idlers. A Bad Idler Bearing will Give this Problem. Hope this Helps. I am here if you Require more Assistance. Let me know what Happens, Please. I enjoy knowing the Outcome. Thanks.
The link for service manual would be :-
http://www.oldgravelys.net/pdf/Pro_G_Serv_Man.pdf
Once downloaded, you can compare what he has done and what's missing.....
:)That would be the best solution.
Let me know the outcome.
Thanks for using "Fixya".
Car won't shift into gear
Broken cable ? Looking under the hood at transmission where shifter cable hooks , moving shifter selector , does the cable move trans detent lever ? If it does the next step would be to hook up a factory or professional scan tool an check internal mode switch input to the PCM/ECM - engine computer . Plus for DTC'S - diagnostic trouble codes . Your best bet mite be to have it taken to a qualified repair shop.
Jan 30, 2018 | 2006 Buick Rainier CXL
Hi, My mustand gear shifter stopped working on a moments notice. It's now stuck in reverse and the shifter seems to just glide over the gears and never engages. Please advise
this is a broken shift cable, it's an easy repair to do. go to the ford dealer parts department and they can get you the part and help you with information on how to install it.by the way the cable is not under the car its part of the shifter assembly.
Oct 01, 2010 | 2001 Ford Mustang
Have a 7.0 craftsman tiller the tines go into gear but the wheels will not engage
I have a similar unit and it will require getting into the gearbox which is not an inexpensive venture. Just to be sure though, make sure the shear pins in the axles are ok. Hopefully it is just a bent/broken shifter in the gearbox but a shop visit will still be expensive if you cant do it.
Jun 12, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
I am trying to find info for a ranch king pro rear tine tiller, the engagement cable is broken and i can't seem to find any cable to replace it with or anything about a ranch king pro tiller, the engine is...
Looks like Ranch King Pro is made by MTD. The part is probably the same, but to be safe, take your old cable off and take it to a lawn equipment service shop to match it up. Shouldn't cost more than $10 - $20.
Jun 04, 2010 | Garden
Vw 1600 fox will not go into reverse
Bring it into VW the shifter has to be reset and the hard plastic bushing that make the shifter work have to be replaced. There is a special toolVW uses to reset the shifter on these vehicles NOT ALL SHOPS HAVE IT. This is a no brainer. If the Dealer is gonna ask a fortune to repair it(Which they shouldn't) You can purchase this tool on line and with the shop manual you can do this yourself.
May 09, 2010 | 1991 Volkswagen Fox
Rear tine craftsman wont engage in any gear. feels like there in no connection from handle cable to engagement
That is correct "Only if the shifter cable isn't broken!" And if it is a linkage type, make sure all of your clevis pins are in place. And on mine even if i get it in gear...the "dead man" is cable connected for sure. Make sure when you squeeze the "safety stop" or "Run/engage" lever that it is actually moving a lever at the other end. If so? Then trans box is next to inspect. But that would have had to suffer a nasty jam to damage that. And again with other people I've seen this a hundred times with rear tine tillers. Sometimes it just "cogs out" into a state of "bad mesh" with the gears and all that is needed is to push or pull the tiller a bit while you try to engage the shifter. The wheels just got be rolled a tiny but and "Voila!" you've managed to free up the meshed gears to a state of freedom. Sometimes its that simple!
Apr 22, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
MTD Series 410 rear tine tiller. Tines won't engage.
I had the same problem. After splitting the case, I found that the shifting fork was bent and the pins that move the shift collar were worn. I made new pins for and reinforced the shifting fork, put it back together and if worked for a few minutes until it would jump out of gear while tilling. I would try to hold the external shifting rod down so that it would not jump out of gear but eventually it quit working completely. I tore it down again and the pins were already work out. I ordered a new detent ball and spring for less than $10 including shipping. This seems to have cured the problem. Apparently the detent spring was weak which allowed the shifting collar to disengage from the drive gear when under load. The original spring had been replaced with a new part number so it may have been made stronger. Tearing one apart is not easy but is certainly doable. To make it easier, put the nuts back on the bolts from where they came. Also get the parts manual picture to help with reassembly. Be careful with the case gasket. It costs a ton for a new one but since the grease is so thick, you could probably silicone it back together if you destroy the gasket.
Apr 19, 2010 | Mtd Garden
Mtd rear tine garden tiller . The wheeles will engage and turn forward and reverse but the tines will not engage. At first they would but would pop out of gear. Now they w9ont engage at all.
Could be the shifter inside the gearbox or it could be a stripped gear or broken chain. The bad news is you will have to remove the gearbox from the engine and then open the gearbox to see what is going on. This is quite time consuming but taking to a shop for this is very expensive due to the labor involved. You can do it yourself if you pay attention to how you take it apart. I hope this helps you out.
Apr 04, 2010 | Mtd Bronco Rear Tine Tiller
Recoil starter will not engage engine when stater rope is pulled
The tooth/notches in the housing are worn out or broken,if the pull cord returns to the original position than the return spring is still good and you will only need to worry about replacing the gear/housing that attaches to the crankshaft .Good luck on the repair job ..BOB
May 02, 2009 | Craftsman Garden
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
