Question about Jandy Pool & Spa
Jandy lx400 wiring diagram
Instructions on how to connect a high limit harness
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
If talking about firemans switch take off jumper white wires then replace with wires to the system contoller to heater
Posted on Nov 06, 2014
4 Suggested Answers
  • 128 Answers
SOURCE: Jandy LX250 LT Pool Heater High Limit Switch
Jump the High limit switch. If it fires the switch is bad
Posted on Aug 23, 2009
john224
  • 1378 Answers
SOURCE: How much time would a
Thank you for posting your question here on Fixya.com.
It should only take a few minutes to actually replace the part; quite a bit longer to diagnose the problem depending on the way the switch failed and overall condition of the heater. It would not be unreasonable to get a bill for an hour to troubleshoot and repair a heater with a defective high limit switch.
John
Posted on Sep 21, 2010
  • 990 Answers
SOURCE: my jandy lxi say's fault high limit switch..is
Yes you can jump past the limit switches one at a time. That will tell you which one is bad. Then you will need to replace it.
Posted on Sep 27, 2010
Lx400 pool heater gets very hot on outside of unit is this ok
check gas pressure if too high it will get too hot or if too low it will soot up then overheat
Jul 07, 2014 | Jandy Laars Lt 400,000 Btu Heater
Tip
Laars LX400 Manual Download
Laars LX400 Installation & Operation Manual
Models: LX250NL / LX250PL / LX400NL / LX400PL
Models: LT250NL / LT250P / LT400NL / LT400P
Have you lost your Users Manual / Owner's Guide for your Laars LX400 Pool Heater?
Would you like a digital copy of the Installation / Operation Manual for easy searching of terms and quick reference?
Click here to download your pdf version of the Laars LX400 Pool Heater guide.
I hope that helps.
on Apr 19, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy Lite 2 Pool Heater won't stay lit
This could be a number of things, high limit switch, temp sensor or clogged burners. If the heater does not get much use cob webs could be the culprit. To test the high limit switches you can disconnect them temporarily and use a jumper wire , if it fires and stays lit then you have found your problem. Just disconnect the 2 wires , and use a separate wire to connect the two together bypassing the switch. This is a safety feature and should only be jumped as a diagnostic tool and not left to operate this way.
Dec 06, 2013 | Jandy Pool & Spa
HI LI SW
check hi limits by plumbing can jump to check
Jan 17, 2012 | Jandy LAARS LX400 - NATURAL GAS, DIGITAL...
I have a Jandy LX400 that won't ignite. Check ohms on ignitor and the0y are around 70. Check voltage at gas valve and it is 10vac vs. 24vac. Any ideas?
check wiring 220 vs 120 volt you might have to change wires if wired 120 volt change wires on ignitor to 120 volt see schematic inside front cover
Feb 08, 2010 | Jandy Laars Lx 400,000 Btu Heater
I get a message saying Hi Lim SW when trying to heat my spa. What does this mean
Temp control failure (thermostat) high limit is safety to prevent over heat.
Jul 26, 2009 | Jandy LAARS LX400 - NATURAL GAS, DIGITAL...
I get a message saying Hi Lim SW when trying to heat my spa. What does this mean?
hi limit switch heating unit getting too hot what type of heater are you using
May 09, 2009 | Jandy LAARS LX400 - NATURAL GAS, DIGITAL...
Pool & Spa Logo
74 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
