Question about Brother Sewing Machines
How do I thread a brother 1351 sewing machine?
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 10 Answers
SOURCE: HOW DO i THREAD A BROTHER BM2600 SEWING MACHINE
They have several brother diagrams and threading instructions @ http://www.sewusa.com. I hope this helps you.
Posted on Jul 24, 2008
SOURCE: brother vx-950 sewing machine
Place thread spool on the spool pin at back right top of machine. From there, thread through 1) rear thread guide (little hook), 2) front thread guide (front hook), 3) down and up through the thread tension dial from right to left so that thread picks up the thread spring check (the little spring on the left of the tension dial). 4) Through the thread take-up-lever, from right to left (the little lever that goes up and down). 5) Through the thread guard and guides (one on the front, one on the needle arm). 6) Through the needle, front to back. Good luck johntrev800 (at) yahoo.com
Posted on Jan 19, 2009
  • 46 Answers
SOURCE: Error message on Brother SE-270D sewing machine
The safety device will activate if the machine has a bind or is unable to run at correct speed. If you turn the handwheel is it tight/hard to turn? if it is than thats it. Now what is binding the machine has to be diagnosed.
Posted on Jul 25, 2009
  • 1126 Answers
SOURCE: I'm new to sewing. I was given a Brother LS-1217
Page 15 in this users guide.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1217_EN_186.PDF
Posted on Sep 17, 2009
Why does bobbin make thread bunch up
Thread tension is incorrect. See the links
Incorrect thread tension - Brother Solutions Center
support.brother.com/g/b/faqend.aspx?c=au&lang=en&prod=hf_ns55eas...
Jul 30, 2014 - Turn the thread tension dial to select an appropriate thread tension. The appropriate thread tension differs according to the type of fabric and thread being used. ... If the upper threading and lower threading are incorrect, the thread tension cannot be adjusted correctly, even by turning the thread tension dial.
Sewing Lesson 10: How to Fix Tension on Your Sewing Machine - Oh ...
ohyoucraftygal.blogspot.com/2013/10/sewing-lesson-10-how-to-fix-tension-on.html Incorrectly threaded machine: Did you use all thread guides? Did you thread with the presser foot down,which would keep the thread from slipping fully between tension discs? Is thread unwinding freely from the spool, or catching on the spool's slash? Are you using a bobbin as a spool (which can interfere with the thread ...
Understanding Thread Tension on Your Sewing Machine - Threads
www.threadsmagazine.com/2008/11/02/understanding-thread-tension Nov 2, 2008 - When the bobbin thread shows on the right side, the needle tension is too tight or the bobbin thread, too loose, as shown in the middle drawing at right. When the needle thread shows on the wrong side, the needle tension is too loose or the bobbin thread, too tight, as shown in the bottom drawing at right.
Correct vs Incorrect Tension: Your Tension Troubleshooting Guide
www.sewingreviews.org/correct-vs-incorrect-tension-your-tension-troubleshooting-gu... I've seen many sewers make the mistake of using the same tension setting for all their sewing projects and then they wonder why the finish isn't perfect. The fact is, the wrong tension is a sewing disaster. It can ruin your sewing project and literally give you a tension headache. Knowing how to troubleshoot your tension ...
Sewing Machine Thread Tension - Updated - YouTube
? 8:51
https://www.youtube.com/watch?v=sf6oPMbLPzo Jul 12, 2016 - Uploaded by Professor Pincushion
Learn how to correct thread tension so that your stitches come out perfect no matter the type of fabric you're ...
Thread Tension - The Sewing Directory
https://www.thesewingdirectory.co.uk/thread-tension/ When sewing fabrics together problems can occur when the thread tension is not correct, the needle or bobbin is not inserted properly, or the machine is not threaded correctly. Threading instructions for sewing machines and overlockers are included in the machine's manual and should be consulted before you start sewing ...
Incorrect thread tension ' Brother CE1100PRW User Manual ' Page 89 ...
www.manualsdir.com > Brands > Brother manuals > Sewing machines > CE1100PRW Brother CE1100PRW User Manual • Incorrect thread tension • Brother Sewing machines.
images for Thread tension is incorrect.
More images for Thread tension is incorrect.Report images
How to Adjust the Tension on a Sewing Machine: 13 Steps
https://www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine
Apr 08, 2018 | Sewing Machines
Threading the bobbin
hi Sharon.
not sure if this will help you out because its saying its for the, ls 2125i.. but try this step by step link.
How to Thread Brother Ls 2125i Sewing Machine
or this youtube video link.
How To Thread Bobbin on Brother LS 2125 Sewing Machine
this link might be the best one for you to watch.when you go to this one scroll down the page a bit and you will see where you can watch the video,
How to Thread bobbin on the Brother LS 2125 sewing machine
Nov 25, 2017 | Brother Sewing Machines
A 1958 home.mark how do you therd it
I am looking for parts of sewing machines. My old sewing machine is HOMEMARK the model is 1351
Jan 02, 2010 | Brother 929D Mechanical Sewing Machine
My brother sewing machine jams threads under the needle and will not go, all the thread has to be pulled out gently as not to break the machine. It will not sew at all now.
hi there, why is it that i can't sew at all..both thread are not working instead eating each other thread under....but i have a good brother ls 2125. ty...
Mar 08, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother ls-2125 how to thread bobbin
all manuals for a brother sewing machine are downloadable at www.brother-usa.com
Apr 02, 2008 | Brother LS-2125 Mechanical Sewing Machine
Feb 22, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
49 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
