Question about Baby Gear
Rear seat belt stuck on a pajero
Can not release the rear seatbelt
  • 619 Answers
SOURCE: Holden Astra rear middle seat belt
Just pull slowly until become long enough to bucle it /straight the belt and release pull again slowly , then ok
Posted on Jan 10, 2008
  • 6 Answers
SOURCE: Rear Facing Installation
That is the common installation process for a convertible carseat in rear-facing position. It is important that the shoulder/lap seatbelt be as tight as possible. This can best be achieved by putting as much of your own weight as possible on the carseat (without the baby of course), clicking into the seatbelt fastener and then pulling as much slack as possible out of the seatbelt strap. If you have the assistance of another adult, one should provide the weight on the carseat from inside the vehicle while the other pulls on the seatbelt strap from outside to remove as much slack as possible. If you have an I-shaped locking bracket, it should be installed over both straps 1 inch from the seatbelt fastener.
Some, but not all, manufacturers provide a metal locking bracket to be placed on the seat belt after the carseat is installed to prevent excessive slippage. You could contact your manufacturer to see if one should have been provided or you may purchase one at most major baby product retailers.
Be aware, a little movement of the installed carseat is considered normal and acceptable.
One last note, many fire stations, police stations, children's hospitals and even car dealerships offer free carseat safety checks. Call those in your area and ask if they offer this service.
~Alkara
Posted on Mar 10, 2008
  • 1861 Answers
SOURCE: replace rear seat belt in 1993 Toyota Corolla
OK. On the front edge of the seat bottom cushion, pull up hard, both sides. This will dislodge the 2 clamps that holds the seat cushion to the floor. Pull the seat cushion out & set it aside. You will now see the female latches bolted to the area where the rear of the seat cushion meets the rear seat back bottom. Remove the bolts (14 mm I think).
Posted on Oct 07, 2008
SOURCE: Rear facing latch problem
I had trouble getting mine tight too and my sister said what she did was kneel in the seat and then pull up on the strap. I tried that and it worked! I think it pushes the seat down more so that you have more strap to pull.
Posted on Oct 20, 2008
tommyboinow
  • 324 Answers
SOURCE: Volvo V70 rear seatbelt jammed
i know this sounds rough, but pull the seat belt with both hands as hard as you can, this will more than likely free the seat belt, some of the seat belt may have jammed in the gear inside the roller box.......
Posted on Nov 26, 2008
My 2016 nissan sentra middle rear seat belt is stuck in the retracted position. I can't use the seatbelt. how do I get it to release?
The likely cause is a broken spring/mechanism in the belt coil. I'm sure you can get a replacement for this belt.
May 22, 2017 | Nissan Cars & Trucks
Replace Rear seatbelt in 2005 Ford Ecape is stuck
I've repaired a few seat belts in the past. Depending on where your mechanism is located, you need to get to it and remove it. Every one that I've repaired had a locking mechanism that is based on G forces and I've removed the side cover of the seat belt to release it. If it's a SRS seat belt, be careful to not trip the circuit. Do your work with the battery disconnected. Once you get the seat belt mechanism apart, small screwdrivers and a pick set would be the best tools to have on hand.
Aug 10, 2014 | Seat Belt Extender: Fits 2007 BMW 328i...
Middle back seat: seat belt is locked up & will not release!!!
DO NOT CUT YOUR SEATBELT!!! Simply unbolt the seat from the body, unbolt the seatbelt from the body under the seat, tilt the seat forward, pull the seatbelt and part that attaches to the body between the seat cushion and backrest and release the tension. Not the easiest fix, but it only takes 30 minutes to do, and will save you a LOT of money. If you cut that seatbelt, you will be buying a new rear seat.
Apr 08, 2013 | 2009 Pontiac Torrent
Rear seatbelt stuck behind head rest in locked position
haha we know you didnt do it on purpose, without seeing your problem and the hard to describe issue, i can only recommend to maybe try folding the seat to the cargo position, if that helps. if not, then you will more than likely need to disassemble the rear quarter panel, and unbolt the seat belt retractor from the body of the vehicle. sorry but there is no other way
Oct 25, 2009 | 2008 Ford Explorer
Rear seat down and wont go back up; locked middle belt
middle seat belt shouldn't have anything to do with it. The seat locks down for stowage in the rear cargo area. you can pull the release handle on the back of the seat to release it back into the up position.
Jul 01, 2009 | 2006 Saturn Vue
1998 Subaru Outback right rear seatbelt stuck.
you need to pull the belt out all the way to release it ,they have a locking mechanism for baby seats that stops them retracting,you pull them all the way out and they are reset and retract,common in modern cars,rare to give trouble
Mar 19, 2009 | Subaru Outback Cars & Trucks
I have a 1997 Ford Escort. The rear seat belt is stuck
make sure that the rear seats are properly locked into rear catches as this can stop your seatbels from working if ok then sounds like your seatbelt is faulty req new seatbelt.
Mar 07, 2009 | 1997 Ford Escort
you can remove the bolt that holds the seatbelt to the floor by pulling off the seatpad where the belt goes to the floor and then raise the seat and the belt should reset. this happens on my passenger side rear seat.
Dec 12, 2008 | 2001 Volvo V70
Nov 24, 2008 | 2001 Volvo V70
Rear seat tumbled forward for more room in back and seat belt jamed. now back seat can not go back into position.
To fix that scenario, I have to get to the bolts anchoring the seat belt which can be found under the rear seat. Which a socket wrench, remove the bolt freeing the seatbelt to allow you room to release the lock to pull the belt out from the top of the back seat. You may now push the back seat into its upright position and then refasten the seatbelts with the bolt to it's former position under the back seat.
When I in later times need to lower the back seat, I will either loop the seatbelt around the head rest or tie two belts together allowing for slack in case the belt tightens again when trying to move the seat back to its original position.
.....Very frustrating!!!
Jul 29, 2008 | 1999 Volvo V70
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
