Question about Palm TX Handheld
Palm TX: Launch Memo App - Crashes Device - Reboots
Hello. When I try to launch the Memo application on my TX the device crashes and does a soft reset. I've seen this kind of behavior in the past with third party applications but this is the first time with one of the core Palm apps. Any ideas would be appreciated. Thanks. TG
Bubbabear64
  • 2794 Answers
SOURCE: Palm crashes with message "installer not compatible with my device" when I do magnifying glass icon search on Contacts
You should reinstall Palm OS and everything else after that.
Posted on Jun 21, 2008
  • 4 Answers
SOURCE: Palm TX Touchscreen does not work
Search youtube for Palm TX Digitizer Replacement and Palm TX Take Apart Direction. If you think you can do it, or know someone who can, you can order a replacement digitizer on ebay for from somewhere like www.pdaparts.com.
Before ordering the part, you may want to start by opening the palm and cleaning the connecting ribbon cable contacts to make sure that a loose cable or oxidation has not caused your problem.
Posted on Mar 13, 2009
hellonnnewma
  • 26 Answers
SOURCE: I have an entry in the memo feature of my palm.
When a Palm OS device reboots like that, it shows that there is a driver conflict. Somewhere along the line some software that was installed is conflicting with other software on the device and causes the reset. I would suggest deleting applications from the device one by one and testing after each to see if the reset is still happening. If you are using the Palm Desktop software that came with the device and performed a Sync (backup) after you created the Memo... it should be saved and accessible in the Desktop software (Memo tab). If no Sync was performed after creating the Memo, you will need to remove applications one at a time until the software conflict is removed allowing you to run your device without the constant reboots. It's a bit of a tedious process, but the only solution if you didn't back up the device after creating the memo you are trying to retrieve.
Hope that helps
Posted on Sep 05, 2009
Geangama
SOURCE: The status bar on my Palm TX no longer is
Hello, I had the same problem for 10 long months until today, I needed my palm for a specific work I can only do with my T|X, and I resumed my research for a solution for this issue, and I found an app called PowerDigi, after I installed it (480 resolution version) and executed it in my T|X, (it has a 70 target points calibration mode so it's far more accurate than the default software that comes with the T|X) I reallized the problem was gone!! You should try this too, maybe it's the same problem of extreme discalibration that my T|X had until today. This is the link:
http://rapidshare.com/files/133856784/PowerDigi_PrefRem.rar.html
I hope it could be usefull for you too.
Posted on Oct 03, 2009
  • 47 Answers
SOURCE: Have a palm tx ,When calendar is chosen,the handheld crashes.
You probably need hard reset because there is most likely a corrupted program that is messing it up. I've gone through over ten different times where I had to hard reset. Get used to it.
Posted on Feb 13, 2010
Tap ranch crashes whenever I launch it.
First try restarting your ipod by holding the button on top and powering it off, then restart it by holding the same button. If that does not work, uninstall the app and go back to the app store and re download it, if it cost money to download it the first time it wont cost anything to reinstall it. If it still crashes on you there may be a problem with the app and you should go to the app store and report a problem with it.
Jun 23, 2011 | iPhone Apps
Feb 12, 2010 | Palm TX Handheld
I have an entry in the memo feature of my palm. Everytime I try to access the information the palm goes black and reboots? What causes this to happen and how can I retrieve the information?
Hope that helps
Aug 12, 2009 | Palm Treo 650 Handheld
My Palm TX is crashing with increasing frequency. Sometimes one push of the reset button will get it back, but mroe often it requires several pokes with waits in between. It crashes when I 1) start it up...
I would check for Application compatibility.
there might be a conflict issue with your Palm TX and some software in it. there is a site for you to check for compatibility to see if there is a risk or if they are "Approved" for use in the Palm TX
http://www.palmfocus.com/txsoftware.php
I hope this helps you out in figuring out whats going on with it.
8-)
Jun 07, 2009 | Palm TX Handheld
Slow start up and overall operation
you can try to launch disk utilities (/applications/utilities/disk utilities.app) and repair disk and authorizations
Apr 13, 2009 | Apple iMac G4 Desktop
My TX crashes every time I try to hot sync
You could delete that app if you want, however I would go into hotsync config and sync only one section at a time, such as Notes, but not contacts or calendar (or anything else). If it works then add a section, such as contacts. Keep adding sections until it malfunctions. Pimlico software makes a product dbfixit ($) that can fix database (blob errors). You can download and install it, and it will report on (but not fix) any errors it finds.
Feb 04, 2009 | Palm TX Handheld
Palm Tx crashes constantly when I do search on Contact
You should restore your Palm software.
Have you docked it recently?
Jun 15, 2008 | Palm TX Handheld
Memos soft resets device
Sounds like you may need to clean out your memos. Are you talking about the memo icon on the screen or do you have a memo button on the button panel. If you have a memo button, there may be something wrong with it, and you may have to use the icon.
Apr 01, 2008 | Palm TX Handheld
Program Buttons
The manual says the buttons Launch [App Name], or turn on the device.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Palm TX Handheld Logo
223 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
