Question about Locks & Locksmithing
Program tru bolt 419 lock - Locks & Locksmithing
Crown vic trunk release doesn't work
Do you know if your door locks are module controlled or non module controlled ?
Locks, Latches and Entry Systems - Module Controlled
Principles Of Operation
s5a~tr~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use a key, pencil or any other hard object to press the keyless entry keypad buttons. These objects may damage the keyless entry keypad buttons.
NOTE: The remote transmitter will not operate with the transmission in REVERSE or DRIVE.
NOTE: Upon installation of a new driver door module (DDM), the module must be reconfigured. Refer to Section 418-01 .
The DDM receives inputs from the digital transmission range (TR) sensor, ignition switch, brake switch, door lock control switches, lighting control module (LCM), keyless entry keypad and remote transmitter. The DDM outputs consists of keyless entry keypad illumination, door lock actuators, luggage compartment lid release solenoid, and LCM.
For DDM removal and installation information, refer to Section 419-10 .
Inspection and Verification
s5a~tr~en~file=ani_caut.gif~gen~ref.gif WARNING: If equipped with fire suppression system, refer to Section 419-03 for important safety warnings.
NOTE: Before starting electrical diagnosis, check for mechanical binds by manually operating the door locks. Operate lock system several times from each switch while observing the operation of all door locks. Be sure battery is fully charged.
  1. Verify the customer concern.
  1. Visually inspect for obvious signs of mechanical and electrical damage.
  2. Visual Inspection Chart Mechanical Electrical
    • Binding latches
    • Battery junction box (BJB) fuse 8 (20A)
    • Central junction box (CJB) fuse(s):
      • 10 (5A)
      • 18 (10A)
      • 25 (10A)
    • Circuitry
    • Connectors
    • Door lock actuator
    • Door lock control switch
    • Keyless entry keypad
    • Luggage compartment lid release switch
    • Luggage compartment lid release solenoid
    1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
    1. If the cause is not visually evident, connect the diagnostic tool to the data link connector and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
      • check that the program card is correctly installed.
      • check the connections to the vehicle.
      • check the ignition switch position.
    1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
    1. Carry out the diagnostic tool data link test. If diagnostic tool responds with:
      • SCP or ISO circuit fault; all electronic control units no response/not equipped, refer to Section 419-10 .
      • No response/not equipped for the DDM, refer to Section 419-10 .
      • No response/not equipped for the LCM, refer to Section 419-10 .
      • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs and carry out self-test diagnostics for the DDM and LCM.
    1. If the DTCs retrieved are related to the concern, go to the Driver Door Module (DDM) Diagnostic Trouble Code (DTC) Index or Lighting Control Module (LCM) Diagnostic Trouble Code (DTC) Index to continue diagnostics.
    1. If no DTCs related to the concern are retrieved, GO to Symptom Chart .
    Drive Door Module (DDM) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1352 Ignition Key In Circuit Failure DDM Go To Pinpoint Test H . B1396 Door Lock Circuit Short To Battery DDM Go To Pinpoint Test C . B1526 Keyless Entry Keypad Circuit Short To Ground DDM Go To Pinpoint Test E . B1553 Luggage Compartment Lid Release Circuit Short To Ground DDM Go To Pinpoint Test B . B1751 Park/Neutral Switch Circuit Short To Battery DDM Go To Pinpoint Test L . B2425 Remote Keyless Entry Out Of Synchronization DDM Go To Pinpoint Test M .
    DTC Description Source Action B1300 Door Lock Circuit Failure LCM Go To Pinpoint Test N . B1310 Door Unlock Circuit Failure LCM Go To Pinpoint Test N . B1396 Door Lock Circuit Short To Battery LCM Go To Pinpoint Test N . B1397 Door Unlock Circuit Short To Battery LCM Go To Pinpoint Test N . B1677 Alarm Panic Input Circuit Failure LCM Go To Pinpoint Test J . B1679 Alarm Panic Input Circuit Short To Battery LCM Go To Pinpoint Test J .
    NOTE: For a complete list of DDM and LCM DTCs, refer to Section 419-10 .
  3. ????????????? Do you have a professional scan tool ?
Sep 17, 2016 | 2005 Ford Crown Victoria
Tru bolt electric lock quit working with codes
Replace the batteries. May need to reprogram the code.
Aug 17, 2016 | Home Security
Random recurring buzzing sound.
Local results for television repairs Toledo Ohio Bing Local http://www.bing.com/search?q=television+repairs+Toledo+Ohio+&qs=n&form=QBRE&pq=television+repairs+toledo+ohio+&sc=0-14&sp=-1&sk=&cvid=047a43a19bff4df998a213e38cb181ce
Oct 28, 2015 | Televison & Video
How do i turn off the fpa on my tru flat tv
this is what I found http://www.ehow.com/info_12211261_fpa-lock-rca-televisions.html
Feb 20, 2015 | RCA 20" Tru Flat Color TV with Remote
How do i Unlock my tru flat tv with no remote
I have onida 29 tru slim tv how can i unlock the volume because its lock?
how to unlock the all programes in onida true slim 29 inch tv
May 13, 2012 | Televison & Video
How to program my viesat remote control
TRY THESE - TOSHIBA
112 313 413 419 506 510 512 517 613 902
Jul 04, 2010 | Toshiba Televison & Video
Fpa lock on my rca tru flat tv
here is my solution. somebody either needs to give me a solution without a remote or fuckin mail me a remote. and if i ever run into these RCA dipshits, ima beat some ***** *** for puttin the damn lock on there in the first place.
signed,
Jay and Silent Bob
Dec 26, 2008 | RCA TruFlat 27F520T 27" TV
Locks & Locksmithing Logo
74 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
