Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
"in recovery" mode on thermostat - a/c not working
We had the same problem over the winter with our heating in that the "in recovery" mode was on and the heat was not working.  It was checked out and nothing was found except to make sure the vents were properly ventilated.  It would randomly right itself.  We now have the same problem with the a/c in that the temperature is set at 71, the in room temperature is 77 and the a/c is not running.  The "in recovery" mode is stated on the temperature controls but the fan is not turning on - even when I turn it to on instead of auto.  We've spent a bundle on three different repair visits but they can't find anything wrong.  What to do??
  • Adam Millstein Apr 22, 2012
    I am having the same exact problem as above. Any ideas on why this is?
I just sent an email to Honeywell on this "in recovery" message and await their response. Yesterday I set my a/c to t/on in off peak hours 6pm and it came on about 45 minutes earlier, then I reset my a/c to come on at 645pm and today it came on 20 min. earlier, this is so fustrating! When I get a response from Honeywell I will share with the world :(~
Posted on Jun 03, 2010
Heater and defroster don't work well
Connie this sounds like your thermostat in the engine is stuck open not letting the water stay in the engine block to heat up. The fix is to replace the thermostat with a new one that will allow the water to stay in the block to warm up. The typical symptoms of a stuck open thermostat is that the air will blow somewhat warm but never hot in the winter time, but it will take a few miles for the air to warm up at all. I would check with the dealership and find out what degree thermostat to replace it with. I run a 180 degree in the summer and a 195 degree thermostat in the winter just to have hot heat in the winter. I hope this helps
Nov 20, 2011 | 1992 Honda Accord
My robertshaw thermostat works well in summer when using my Air conditioner. I have a heat pump. but in the winter the thermostat frequently displays "ER" during cold winter nights when the unit...
what it sounds like happening is the unit is realizing it is falling behind most thermostat s have a 3 degree deadband if they fall 3 degrees or more at a time after running for so long then it will bring on the emergency heat which is located in your inside unit... when it gets really colds and you see this you need to go outside and look is the outside unit still running and is it freezing up on you...also if running check the larger of two pipes make sure the large pipe is hot to touch...based on the description you have given the thermostat is calling for emergency heat but for some reason is not bringing it on or there is a problem with the emergency heat.... hope this helps out some
repost with any additional questions...
Jan 08, 2011 | Honeywell Electronic Programmable...
Should the direction of my fan be counter clockwise when I want to reverse it in the winter?
Hi, and no. The fan on the outdoor condenser always turns in the same direction on a heat-pump. What changes is what is called the reversing valve located by the compressor. It reveres the flow of freon in the winter on its own, with the help of the control board and thermostat. There is nothing for you to change but putting the thermostat into the heat mode, and the unit will do the rest. Good question though.
Sincerely,
Shastalaker7
A/C, Heating & Refrigeration Contractor
Jan 07, 2011 | Heating & Cooling
Now is winter,so cool,when i turn the A/C to heat,but no work,turn to cool,it work,but i need the warm air,not cool
Check thermostat setting +29 and also mode should be in "Heat" mode. Still the problem, Check Reversable Valve's connection and function.
Dec 09, 2010 | Heating & Cooling
Ac works no heat
I am not sure if you checked your thermostat. It may be clogged or it may have failed altogether. If it failed their is a safety mode which make it stay fully open so your engine wont burn up. I dont know the model of your vehicle but if you follow the radiator hose back to the engine where it connects to your block. You should find your thermostat there. Just google how to change it. Make sure your vehicle hasnt been running when you start disconnecting ( the coolant will be very hot)
Also some areas in Canada and US has summer and winter thermostats. Winter build up much more heat.
Dec 03, 2010 | Dodge Ram 2500 Cars & Trucks
Auto recovery mode raises the temperature above
Hummm... how far is your Thermostat from your heater? I am reading your extensive manual but there is no mention of that distance? There was a early mention of batteries? Are yours fresh?
Is this a 'new' problem? Has it worked properly before?
Then there is this from the manual:
The installer can set SYSTEM functions once the thermostat is installed. The
default settings are shown in bold in the following list. Options are listed inside the
parentheses. Example: the default SYSTEM TYPE is CONVENTIONAL with (HEAT PUMP) as a second option. See pages 28-29 to change these settings.
Have you tried resetting your Thermostat?? Sometimes these basic 'onboard' computers get confused... especially true with lots of 'options'...
It's a little hassle to get a DIGITAL copy of your manual (I am not a Robot ~ etc) ~ but here it is:
Download manual
TROUBLESHOOTING begins at Page 68
Anthony
Dec 22, 2017 | Hunter Fan Company 5/1/1 Programmable...
Hunter thermastat, model 44860 not working
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Jun 01, 2009 | Ruud UAMB Air Conditioner
THANK YOU
Are you saying your air conditioner does not work? If so, make sure the ac is mode is select and not on heat. Then turn your thermostate down to around 74 degrees . The heat/cool select is on your thermostat. Good luck and keep in touch.
May 26, 2009 | Heating & Cooling
Error Message RE CO on Indiglo
Auto recovery – allows heating and cooling systems
to gradually recover from an energy-saving setpoint
temperature to a comfort setpoint temperature. Auto recovery
calculates the time needed to adjust the temperature to
the next program setting. When the thermostat is in Auto
Recovery mode, the display will flash alternating messages of
RECO and the time. Auto Recovery can be disabled by sliding
the recovery switch on the back of the circuit board to the
disable position.
(Auto Recovery will not operate if Permanent or Temporary holds
are on.)
Press Hold/Return during the Auto Recovery process to
manually cancel the recovery.
Jan 05, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
5,652 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
