Question about Kenwood KDC-MP5032 CD Player
How do I eject a CD from the player - Kenwood KDC-MP5032 CD Player
I put a cd in my cd player and it will not eject
start up holding down eject button,
go to file menu and hit eject cd,
good way to start,
Feb 22, 2014 | Computers & Internet
Cds are stuck in the default cd player of 2001 Dodge Intrepid. How do I get them out?
The first step is turning the car off. Then before turning the key back on, push and hold the Eject button then turn the ignition on. If the CD fails to eject then you can use a old CD and try to insert it into the CD Player, just as it try's to take your second CD pull it out and hit the Eject button again. This will usually get a Dodge CD player to Eject.
If this fails then the CD player must be removed and a manual eject can be performed.
May 15, 2010 | 2001 Dodge Intrepid
Cd is stuck inside how to eject
if there is a tiny hole on front place a paper clip in there it will eject it does on other systems
Apr 16, 2010 | Pioneer CDJ-1000 CD Player
I put my CD into my CD player and it says ERR but
Bang on the fascia as close as possible to the cd player a few times it will eject.
Regards
Phillip
Sep 12, 2009 | Car Audio & Video
Cd jammed in player
MY DAUGHTER PUT A CD IN THE CD PAYER AND NOW MY CD PLAYER DOES NOT WORK.I HAVE A 2005 NISSAN ALTIMA.THE KIND OF RADIO IS A BOSE 6 CD CHANGER.I PRESS THE CD BUTTON AND IT SAYS PUSH EJECT.I PUSH EJECT AND IT SOUND LIKE IT'S TRYING TO EJECT BUT NOTHING COMES OUT.CAN YOU HLP ME
Jun 13, 2009 | 2005 Nissan Altima
Stanton C303 wont eject CD
Remove the power completely replug and then quickly turn it on press eject emediatly..... this should work
Jan 01, 2009 | Stanton C-303 Single Top Loading CD Player...
Sony CD/DVD Player DVP-NS501P: It says LOCKED when I try to eject
What you have to do is unplug it and plug it back in it resets the dvd player
Nov 15, 2008 | Sony DVP-NS501P Progressive-Scan DVD/CD...
2008 Durango Limited
The eject button is the load button on our 2005, maybe the same for you. Just hold it in for a few seconds and it should spit out your cd. You should be able to lightly put the cd up to the insert space and it should take your cd. If your cd player holds multiple cds then perhaps there are some in there that have not been ejected. Hope this works for you.
Oct 27, 2008 | JVC KD-AVX1 Car DVD Player
Jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Nov 30, 2007 | Jensen VM9510 Car DVD Player
CD player won't eject CD and does not recognize the CD
You will have to remove the player from your Sierra and disassemble it sufficiently to remove the stuck CD.
May 30, 2017 | Car Audio & Video
Kenwood KDC-MP5032 CD Player Logo
15 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
