Question about Panasonic SC-HC30 Audio Shelf System
How to navigate a digital radio? - Panasonic SC-HC30 Audio Shelf System
I bought a used Honda civic 2002 the radio serial number is 24163257. I need an unlock code for it.
    Honda Radio / Navigation Code Retrieval and Reset ...
    https://radio-navicode.honda.com/
    The official Honda site-instructions for radio/navigation code retrieval. Learn how to find your unique code ... Retrieve Unlock Codes for. Radio and Navigation Devices ... Information You Will Need. Vehicle VIN Number; Device Serial Number ...
  1. Radio Code For Serial Number‎
Jan 13, 2016 | Honda Cars & Trucks
How do you activate touch screen
Dear Dodge user,
This device comes with a pre activated touch and need not be tweaked for activating the touch feature. However, please follow the following,
Media Center 730N(RHR) NOTE: Uconnect® Phone and Voice Command are vehicle options which must be ordered separately. The buttons on the radio will only be active if the vehicle has been equipped with the option.
  • This navigation radio requires digital data from a navigation database. The data in the navigation database is licensed from Navigation Technologies. Not all roads are digitized.
  • For software updates, visit the MyGIG® page, visit http://www.navteq.com, or contact your authorized dealer for the latest available software.
Seek Up/Down
  • Press to seek through radio stations in AM, FM, or SAT bands. Seek through tracks in CD or iPod® modes or through songs in the HDD playlist.
Radio Mode
  • Press the RADIO / MEDIA hard-key to display the different radio modes, then press the desired soft-key to select AM, FM, SAT, HDD or AUX.
Auxiliary Mode
  • The auxiliary (AUX) jack allows a portable device, such as an MP3 player or a cassette player, to be plugged into the
Regards,
Sid
Nov 12, 2014 | Dodge Challenger Media Center 730N RHR...
How to reset the transponder honda pilot?
I presume you want to initialize or"sync" up your navigation
system to the satellite. You will need the 4 digit navigation
code and the 5 digit audio code. Make sure your vehicle is
parked out in the open where there are no trees over it. Turn it
on and the nav screen should be asking for 4 digit code.That
is the navigation code.If entered correctly the display should change to the disclaimer screen. For the radio to work turn
that on and you should see in the space where the station
frequency appears,the words ENTER CODE.When the 5 digit
radio code is entered correctly the radio should start working.
I hope this helps as it is as short as I can make it. If you don't
have those codes then you will have to get them from a Honda
dealer. Good luck
Jul 18, 2014 | 2005 Honda Pilot
How to activate my navigation on the Harman Kardon radio
Not all Harmon Kardon radios have navigation. Have your dealership hook the bike up to Digital Technician to check. This is also how radio upgrades are installed.
Jun 16, 2012 | Harley Davidson FLHTC Electra Glide...
Code for land rover radio 2003 v8
If you're looking for a radio code, all you have to do is call the service department at your local land rover dealer and give them the VIN. If it is a factory radio, it will require 4 digits. They should do this at NO charge. You can also call Land Rover corporate for this information too. If it is a navigation system, there is usually a sticker in the glove box and the last 5 digits of the serial number on that sticker are the radio code.
Jul 09, 2011 | 2003 Land Rover Discovery
My radio needs a code
"i have a 2004 honda accord my radio needs a code"
I had the same problem on my Honda Accord.
After several attempts to fix and many error messages I called a Honda house and the lady in service said "No problem". She then asked for the two codes listed by using the procedure described above (the "U" and "L" codes which both contain 4 digit numbers following the U or the L.
I gave her this and she "looked it up".
In a couple of minutes she returned with a 5 digit code which I immediately tried.
Of course it didn't work because it only has room for 4 numbers.
I went thru the battery disconnect reset (for 5 minutes) and while that was going on, I remembered that the code for the navigation system was located by another service tech once before.
All he did was pop the top off the fuse panel under the hood.
On the cover, along with the fuse identification was a white sticker with some numbers on it.
One of the typewritten numbers had a "N" written with a pen on it.
Another number was 4-digit and had a "R" in blue ink, like the N written on it.
I thought "If N stands for navigation, would R stand for radio?"
The rest is history.
When I plugged that number into the radio in the code entry mode - everything started working.
If I hadn't seen that tech open and retrieve the navigation code, I never would have related "N" and "R". The under hood fuse box is located on the driver's side up near the windshield.
May 24, 2009 | 2004 Honda Accord
2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
Apr 02, 2009 | BoxWave Corporation 2007 Honda Civic...
The sales person said i could receive fm radio on this mp3 player
When it's booted up use the +/- buttons to navigate to radio, press play/pause to enter the radio tuner, it's default station is 88.something , use the |<< and the >>| buttons to navigate stations, hold the player around in the air to fin good reception, look around in the radio menu and you can record songs/talk shows off the radio, be careful, if you're recording and you hear static, it will record the static. good luck!
Mar 29, 2009 | RCA TH1602 MP3 Player
Panasonic SC-HC30 Audio Shelf System Logo
37 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
