Question about Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Oasis alternates between saying SD and F51.
I have only used HE detergent. Sears replaced my computer board a few months ago when I was having a similar problem (clothes wouldn't spin dry, had gotten code LD), and all seemed to be fine. Now the clothes are not spinning dry again. I have different codes (SD and F51, rather than LD), but the same problem.
  • 15,935 Answers
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump...
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the Cabinet....
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&^%
Posted on Sep 27, 2010
I had a problem with washing kenmore oasis he 110.27062600 it came on sd, f51 codes when it reaches to spin. clothes didn't dry .
Hello, welcome to FixYa.
The scenario you describe is usually associated with a item stuck under the tub or a loose stator or a faulty "RPS" device or connection at the "RPS"...but I don't know if you checked that yet or if you know how, thus the error F51.
As I mentioned the F51 is usually associated with the rotor and stator/RPS assembly and quiet often it is initiated due to a loose rotor or bad RPS...I'd start by checking the bolt.
There is a repair tip regarding this from sears which suggest checking the wires to the RPS and then the rotor, while insuring the center bolt is really tight via applying some "lock tight".
I actually see a lot of these and most times it's a loose rotor bolt. Here's an exert from my files directly from sears...(I'm privy to them from being a Sears tech.)
You may want to check the rotor, I've seen the center bolt become extremely loose, thus causing the F51 error, this where and what to look for shown below...
...but either way let me know how you make out with the repairs and good luck.
Regards,
Macmarkus :)
Oct 18, 2011 | Kenmore Oasis HE 27082 Top Load Washer
I have a kenmore elite oasis washing machine model # 110 2706201. during the sheets/towels cycle i keep getting an error f51. what needs to be done to correct this?
Call your Sears customer service representative and not repair people. Our repair representative for Sears in Houston flately denied there was a problem. I called the right people and took care of that. Make sure you give them the model and it manufacturing ID number. No matter what they tell you it is a defective board made by Whirlpool who also made your machine. It is covered under a warranty( recall) . If you Google oasis kenmore problems your computer will light up. It took me a while, but they fixed mine. Two weeks later it was another problem. I spent 1200 new in 2007. We have hade no less than 6 service calls. My old washing machine is being used by my inlaws and is 15 years old. The way sears has handled this they have done a great deal of damage to thier loyal customers.
May 06, 2011 | Kenmore Oasis HE 27062 Top Load Washer
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Stops in middle of wash cycle and F51 codes keeps flashing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the Bad Board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Control Unit Assembly
We are researching for new laundry machines (10) for our condominium laundry room. I'm glad I found this site, and I guess we won't be buying Kenmore products.
Saratoga Condominiums
Oct 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Piece if **** washing machine and dryer kenmore elite oasis
I called sears recall dept 1 888-548- 1509 told to make a service call about F problem and if that is the cause your charge for service call will be refunded and a new control board installed at known charge.The 27082 is not on the recall list yet but sears is aware of this condition.Don't give up just keep calling and ask that a copy of your call and complaint be forward to your address ,sears receives numerous call's each day about F1 control boards.
Cal them your self now and see if they will do this repair 1 888-548- 1509
Please leave a rating !
Sep 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
122 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
