Question about Craig CTV-41331 13" TV
Lost channel 3 on Emerson TV - Craig CTV-41331 13" TV
How do I change from channel 4 to channel 3 without a remote control?
Why not purchase an inexpensive universal remote and use it to operate your Emerson TV?
Jul 30, 2015 | Emerson Televison & Video
Have a used Emerson tc1375a hooked up to cable only gets channel 3 and 4 picture is great. Does it need to be reset or what can I do
Usually a TV must be set to either channel 3 or 4 to receive a TV service provider such as cable or Direct TV. The service provider now controls your channels and broadcasts on either channel 3 or 4. You choose channels from what ever equipment they gave you which is usually not the remote that came with your set. You may need to check the way you are set up. If you are using an antenna go into the menu on the TV and make sure it is set to antennae not cable. This may also be the problem. Good luck.
Feb 19, 2015 | Emerson Televison & Video
Lost remote sand need to be ablr to put TV on channel 3 for DVR hookup. problem is i had clean antenna and the channel is 3.2. or 3.1 who do i fet to channel 3 manually?
go to your menu button bring up add/delete start at 1 and and when it gets to 3 add it add 4 also just in case 3 doesn't work ! or go to ebay and buy a remote that is what i did .. good luck
Jul 03, 2014 | Emerson LC320EM2 32" LCD HD Television
Channel setup without remote
Hi I attached product manual link for your Emerson EWC19T4.
I believe that you can find solution.
pdfretriever com
Mar 25, 2014 | Emerson EWC19T4 19 in. TV/VCR/DVD Combo
Emerson 20
Use the channel change button go under channel three you might see Av and others
Aug 28, 2012 | Emerson EWF2004 20" TV
Can't get channel 3
connect the antenna cable---enter in menu and press autoprogram.
Apr 22, 2010 | Emerson EWF2004 20" TV
My daughter lost her remote control for her tv. I just connected the digital tv converty box. When I turn the tv on I can't tune it to channel 3 as I don't have a remote. When I push the channel...
Hi..
its better to purchase a universal remote...I suggest using the Logitech harmony remote. It comes with all features of any OEM remote Including video input etc.
pls rate my suggestion...
Jul 20, 2009 | Emerson EWF2004 20" TV
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Televison & Video Logo
13 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
