Question about Cycling
Caint get the gear shifter to work on my roadmaster mt sport 16 gear bike
The shifters wont turn so I can shift gears
cogdoc
  • 7 Answers
SOURCE: Ultegra Flight Deck shifter problem
My guess is the shift cable has slipped, only allowing you the top end of the rachet positions. Drop the shifter to the very lowest cog, make sure the cable is tight, and adjust the tension at the derailleur so that on the first single click it climbs one gear, and isn't noisy there. More tension 9 winding the barel out ) causes it to rise, less, to drop down. It should then hopefully select all the gears, unless the upper stop, the L screw is set too low. This screw stops the derailleur hitting the spokes and going past 1st gear. That shouldn't ever change though.
Posted on Jul 01, 2009
  • 61 Answers
SOURCE: shimano tiagra 9 speed shifters how to change gear
Go to http://techdocs.shimano.com/techdocs/index.jsp
Search in drop down list to go to all tiagra items and identify your particular components. Shimano are good at numbering their parts and you should find the number you seek on the bicycle component. You will usually be able to download an exploded parts diagram and service instructions. The service instructions are prefixed by the letters SI.
Posted on Nov 22, 2009
dunnbiker
  • 8546 Answers
SOURCE: Hi, Just bought a new bike with shimano tiagra
You don't mention which shifter(s) malfunction or if you're even pedaling the bike while shifting (I make NO assumptions).
If you operate the inner shift lever (NOT the brake lever) on each side through several clicks that should RELAX any tension in the shifter cables. Then if you pick the bike up and pedal it forward a couple of turns the front shifter should drop the chain the the lowest chainring and the rear derailleur should shift out the the smallest cog.
With the bike suspended (say, hanging from a low tree branch by the tip of the seat) you should be able to turn the cranks and manually pull sideways on either exposed shifter cable where it runs down along the downtube then release it.
This should cycle each respective derailleur through its entire range. If the cables don't travel sufficiently in this manner, the shifters will never make them do it either.
Perhaps you could CALL the Bike Shop and they would talk you through a quick operational check.
Posted on Apr 27, 2010
agent91
  • 2100 Answers
SOURCE: how to use thumb shifters on a 21 speed Schwinn Highplains bike
OK, for a beginner in the world of 18 speed bikes, put the chain on the big sprocket up front, it should be about 46 teeth, make sure it is center and doesn't make noise, if it does, adjust it just a hair either way, now, the rear, put the chain on the big sprocket in the rear, make sure the front didn't start making noise, if it did, adjust it again. You are now ready to take off, in low gear, as you start out, it is easy to pedal, soon you will be peddling air, shift into second gear in the rear only, don't touch the front. Just a little push with the thumb will make it shift, now were going faster, easy peddling, shift into 3rd, then 4th, etc, coming to a stop, down shift the back sprocket back into low gear (big sprocket) and be ready to take off again. Soon you will be shifting that thing like a Ferrari! The front sprocket, will be used for moderate terrain, wheelies, and mountain climbing, that will come later, learn how to shift the rear first. As each gear climaxes, hit the shifter, it will get smoother as you go, and keep the chain quiet, no climbing on the next sprocket or falling out of gear. Hope this helps.
Posted on May 03, 2010
  • 190 Answers
SOURCE: My daughters mt sport sx
phililisa03-
This problem is caused by improperly adjusted derailers/shifters, the mechanism that move the chain from one gear to the next. It is not uncommon for the derailers to be out of adjustment after sitting unused through the winter. Over time the cables that run between the shifters and the derailers stretch just a bit and the derailers no longer work as well without a little tuning up. Unfortunately, for the novice, adjusting the derailers is frustrating at best. The effort and patience it requires is nothing to take lightly. If you're game for giving it a try, there are a number of websites out there that will provide extensive guidance on the process - just "google" how to adjust bike derailers" and you will find plenty of options. My local bike shop will make adjustments like this for a small set price, around $20 or so - you may have a shop nearby that will do the same.
Hope this helps.
Regards,
DIYpro
Posted on May 03, 2011
Can only select 1st neutral an 2nd gear
Hi Meihana and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. Shift lever is loose on the shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://pnwriders.com/threads/r1-wont-shift-past-2nd-gear.169723
Can shift above 2nd gear
Wont shift past 2nd gear
Shifting stuck won go past 2nd gear
Apr 06, 2016 | Motorcycles
My shifter on 1100 shadow is bound wont move. when unhook all linkage transmission shifts fine
You have to turn shifter up or down 1-2 teeth, or you have a problem at link betwen right and left connet. rod, you can see correct position if you take of round plug, it is behind and down from outer shifter.
Apr 04, 2013 | 1994 Honda VT 1100 C Shadow
2000 ford mercury 3.0, shifter wont move. had a fender bender, put it into park and it wouldn't come back out.
For car not changing gears it can be shifter assembly issue, or it can also be transmission issue. Get the shifter assembly inspected with ignition OFF.
For more troubleshooting, I suggest you to get the Following help link checked, its complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
These will help.
Thanks.
Feb 15, 2013 | 2000 Mercury Sable
Gear shift wont work
there should be a release hole by the shifter stick a pin in it and press the button to release the shifter. if not press brake down and try to shift
Feb 13, 2013 | 2008 Jeep Compass
Buick gear shifter moves freely and wont shift gears
you can shift it at transmission by hand to neutral or park and have someone inside start the car and you manually put in gear under hood and drive it to shop or garage, wherever
Feb 06, 2013 | 2000 Buick Century
2007 chevy impala won't shift into gear, shifter moves, but doesn't go into gear
It is either the shifter cable or maybe the shifter linkage came undone..
Rate well ;o)
Jul 30, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
Shifter wont shift the pickup into gear
Let's start with the basics. Key has to be in the ignition and ignition turned to the run postion. Battery has to be charged up. Brake pedal has to be depressed so the shifter will unlock, . If the shifter will not move, it could be several things. A faulty shifter unlock cylinder or wirng problem. A binding shiter cable or shift lever problem at transmission, or a problem with the shifter assembly on the steering column.
Mar 03, 2009 | 1996 Ford F150 Regular Cab
Car wont shift into gear
did you check that you still have brake lights ?
Ford has the shift interlock, so if you loose brake lamps, the shifter will not move out of park.
Quick test, turn the key to the on position ( do not start ), and see if the gear shifter will move to neutral.
Dec 08, 2008 | 2006 Ford Mustang
Cycling Logo
41 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
